Technical Oil coming out the dip stick tube
Discussion in 'Traditional Hot Rods' started by deskjet894, Jun 25, 2026.
  1. deskjet894
    deskjet894
    from ma
    I have oil coming out of the dip stick tube under heavy acceleration. The 8BA is used in vintage drag racing.
    What could it be?
  2. Doublepumper
    Doublepumper
    from OR-WA, USA
    Crankcase pressurized from insufficient venting, would be my guess.
  3. Flathead Dave
    Flathead Dave
    from So. Cal.
    I agree with doublepumper. Poor crankcase venting. Is water in the oil causing it to over fill?
    alanp561 and 05snopro440 like this.
  4. Blow back my man.... Compression in the crank case area. :(
  5. big john d
    big john d
    from ma
    you may be able to minimize it with a pan vac system also be sure the dipstick seal is good i ended up with a pan vac system on my drag car and a dipstick seal corrected most of it the vac system stopped the rest you just have to know it will **** a bit of oil out with the pan pressure
    ClayMart likes this.
  6. Jack E/NJ
    Jack E/NJ
    from NJ
    > >heavy acceleration. The 8BA is used in vintage drag racing >
    Try lighter acceleration. It's gonna lose to vintage stovebolt 6s anyway. ;)
  7. Oneball
    Oneball
    I agree with the others about venting being in adequate.
    Also do you have a spring or clip to hold the dipstick down?
  8. shorrock
    shorrock
    from Germany
    On my (french) flatheads there is a rubber bung which gets expanded when the dipstick knob is turned clockwise. Thus this possible exit is completely air- (or water) tight. On my blown flathead I am sure I have a bit of blowby but the crankcase vent is open so there is no pressure on the dipstick.
  9. Clydesdale
    Clydesdale
    Has it always done it? or has it gotten worse over time?
    An answer to those questions might help point toward the possible cause.
    twenty8 and 05snopro440 like this.
  10. 19Eddy30
    19Eddy30
    from VA
    You could use a 0-10 or 15 psi gauge to see of over pressurized pan
    from blow by or Vent to small .
    Typical engine has 4 psi in crank case .
    Remove dip use hose & gauge .
    Check vent size like others said .
    jaracer likes this.
  11. 210superair
    210superair
    from Michigan
    You got a pcv in it?
    RmK57 and HOTRODPRIMER like this.
  12. Scooterfish
    Scooterfish
    If you prevent the oil from coming out of the dipstick tube without correcting the crankcase / blow by problem it`s going to find another outlet. Creating more problems.
  13. 1971BB427
    1971BB427
    from Oregon
    Never mentioned the oil level in the pan? If it's up near the full mark the crank might be slapping oil during hard acceleration. Might want to keep oil level down a half quart.
    big john d and 210superair like this.
  14. HOTRODPRIMER
    HOTRODPRIMER
    Installing a PVC stopped my flatty from pushing oil out the filler tube. HRP
  15. 210superair
    210superair
    from Michigan
    Yup, same. That's why I asked above. Cheapest and easiest flathead improvement there is Imho....
    Fixed other stuff too. No g***y smell wafts fr under the hood at stop lights. Lake pipes don't black up, etc.
    Deutscher and Okie Pete like this.
  16. Bandit Billy
    Bandit Billy
    The high the CR in the chamber, the higher the pressure in the crankcase. It blows out gaskets and seals, drips and smells. It also robs the engine of horsepower as the pistons have to fight that pressure everytime they slide down the cylinders. Add a PCV valve and you be happy you did. On an 8BA it goes in the road draft tube hole where it lines up with the crankcase vent tube under the intake. I bought this one. The adapter has an O ring to seal it, and the valve is from a late model jeep so you can stock up on them.
    1949-53 Ford Flathead PCV Valve Conversion
  17. 210superair
    210superair
    from Michigan
    If you do add a pcv gotta vent the oil fill as well.... Am I wrong on that?
    Jack E/NJ likes this.
  18. Jack E/NJ
    Jack E/NJ
    from NJ
    Yeah. You can add this xler style cap and vent it to the carb intake after the air filter.
    210superair likes this.
  19. RodStRace
    RodStRace
    Think of it like a soda cup with a lid and straw. If the soda is coming up thru the straw, the pressure in the cup is enough to push the soda up and out of the straw. Vent the cup.
    PCV is not original, a road draft tube is, but if it's been modified and you can get a good kit, I'd suggest that as the fix. If the engine has excessive blowby, that may not cure the issue.
    This applies to any engine.
    Blues4U likes this.
  20. Blues4U
    Blues4U
    from So Cal
    Everyone's on the right track here, but IME once the blowby reaches a certain point no amount of PCV is going to take care of it. If the rings are shot, if they're stuck, if the cylinders are worn, then blowby is going to happen, and there's nothing you can do but rebuild the engine. Surely try adding PCV first, but if it doesn't address the problem you know what you have to do...
  21. twenty8
    twenty8
    A road draft tube might get you a stern talking to and ejected from the track..........
    RodStRace likes this.
  22. RodStRace
    RodStRace
    @twenty8 Completely true. I tried to cover the basic question in a general way.
    The issue of the dipstick could be handled by a locking stick, but would not address the root cause (crankcase pressure).
    I haven't dealt with tech at an event where they have a lot of flatheads or other engines without PCV. Most racers do not have operational type 4 PCV.
    I know coolant overflow is not allowed to just vent to the track, but do not know if they check and enforce the same for crankcase. I have not seen this for trans and axle vents.
