Projects Cutting my Hotrod Teeth (57 Chevy Budget build/revival)
Discussion in 'The Hokey Ass Message Board' started by RaginPin3Appl3, Aug 5, 2017.
  1. RaginPin3Appl3
    RaginPin3Appl3
    Yup, torqued back down to spec! I’m sort of at my wit’s end with the leaking at this point and I’m not about to take it all back apart again. I guess next week when it goes back to the shop, I’ll ask them to look at it. Done screwing around with it.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Pressurized oil from the oil pump p***age (arrow) running between the cap and block. IMG_6123.jpeg
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Super clean mating surfaces needed before hand as well.
    chryslerfan55 and RaginPin3Appl3 like this.
  4. RaginPin3Appl3
    RaginPin3Appl3
    Man I feel like a m***ive idiot. It’s always the simplest things…
    Turns out my p***enger side valve cover gasket was folded over on the back bottom corner…
  5. RaginPin3Appl3
    RaginPin3Appl3
    Well, on the plus side, the rear main should be leak-free now if it wasn’t already. The old seal was pretty stiff when I took it out, so a leak was probably eventually going to start.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    You’re learning valuable lessons here. Always check the easy stuff before tearing into the hard stuff….
  7. Have you looked into valve cover studs? They make install a breeze
  8. warhorseracing
    warhorseracing
    from cameron wv
    What I said in post 2592.;)
    Remember what else I said Gr***hopper. Learn. Continue learning. Never give up. Remember your mistakes and learn from them. You have come a long way. There is still a very long path for you to take in your life journey. By your journeys end, you will be a genius in your own mind.:)
  9. RaginPin3Appl3
    RaginPin3Appl3
    That’s a neat idea. I usually glue the gaskets to the covers with gasket maker but didn’t want to do that with my fancy Vette covers.
    chryslerfan55 and The Chevy Pope like this.
  10. I have some on my 53 I got from O'Reilly. They claim to only work on stamped steel valve covers but fit my finned aluminum covers just fine
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    You will not hurt your alum valve covers by gluing the gaskets to them. I do it all the time
  12. RaginPin3Appl3
    RaginPin3Appl3
    I’ve been chasing this ticking sound for about a week so figured I’d just post a video of it. I hear it constantly at idle, and at higher RPM it’s either too quiet to hear, or it goes away. I have adjusted the valves twice, first time 1/2 turn after 0 lash, and second time 3/4 turn after 0 lash which it was originally at. I’ve also taken the p***enger side valve cover off and backed off each rocker nut until it clacks, then tightened until it stopped clacking. Nothing has fixed it. What does this sound like?
  13. 427 sleeper
    427 sleeper
    Sounds like an exhaust leak. Possibly between the head and exhaust manifold.
  14. RaginPin3Appl3
    RaginPin3Appl3
    That’s what I though the other day so I made sure all 6 bolts were tight, and no change. The gasket on that side was replaced about 6 months ago.
  15. 427 sleeper
    427 sleeper
    There's not supposed to be any gaskets between the head and the manifold. The gasket may have blown out, even though the bolts are tight. Take the gaskets out, clean the mounting surfaces and put it back together, and see if that stops the problem.
  16. RaginPin3Appl3
    RaginPin3Appl3
    No gaskets for rams horns manifolds?! You’d definitely know better than me, but that’s a new one. I always thought you needed them with manifolds, not just headers…
  17. warhorseracing
    warhorseracing
    from cameron wv
    ^^^^^^^^Correct. Even though they sell them in a lot of different gasket sets they are not needed.
  18. RaginPin3Appl3
    RaginPin3Appl3
    Wow! Well, like is often said I’m learning a LOT from this thread! Okay, I’ll try removing the gasket. It seems like no gaskets would make it more likely for the bolts to snap off while tightening, no?
    chryslerfan55 and Algoma56 like this.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    I was under the impression that it wasn't until later that parts were machined well enough to seal without gaskets (like maybe mid 80's an newer?). I always use em on the old stuff
  20. RaginPin3Appl3
    RaginPin3Appl3
    Not to mention it’s now 60 years later and these parts are probably less flat/straight now than ever before.
    chryslerfan55 and Moriarity like this.
  21. Budget36
    Budget36
    Are they new or used manifolds?
    Heck, even now the manifolds may be wonky.
    chryslerfan55 and 427 sleeper like this.
  22. warhorseracing
    warhorseracing
    from cameron wv
    I never used exhaust manifold gaskets on my 60's Shivrola and Ford engines with manifolds and never had an exhaust leak. Headers, yes. Manifolds, no.
  23. Squablow
    Squablow
    Dang, I used gaskets on the rams horns on my '57, I would not have guessed they'd be machined well enough to seal without gaskets.
    As much as it probably ****ed doing that rear main and oil pan to fix a valve cover gasket, it's definitely nice to have a new rear main seal and oil pan gasket done and in the car, that's just nice for peace of mind.
  24. RaginPin3Appl3
    RaginPin3Appl3
    Random manifolds that aren’t even a matching pair. One’s an 80s “corvette” manifold, the other is a ‘57 manifold. Nothing has been machined since I’ve owned it, so for all I know they’re warped to hell.
  25. RaginPin3Appl3
    RaginPin3Appl3
    Yeah I’m glad I bit the bullet and did it, even if I have other leaks to fix still. I know the timing chain cover is leaking too, but I’d rather work on the front of the engine than the back.
  26. Budget36
    Budget36
    I’ve not had manifolds warp that they didn’t seal, I have had to spread used ones to get the bolts to line up.
    But you’d think the gaskets would take care of anything out of kilter.
  27. mrorbit
    mrorbit
    from NE IL
    Maybe that manifold has a crack in it.
    See any soot?
    chryslerfan55 and Budget36 like this.
  28. Squablow
    Squablow
    Next question would be how does your pipe seal to the manifold? Many use a "donut" gasket, which can fail or leak if it's not lined up right. I eliminated the heat risers on mine so my pipes have to bolt to a flat, 3 bolt flange, and I got some gaskets and flanges that were actually made to be repair parts for catalytic converters but they worked well to bolt exhaust pipes directly to the manifold without the heat risers. A leak at that point could easily cause a ticking sound, too.
  29. RaginPin3Appl3
    RaginPin3Appl3
    So are you guys fairly certain it’s an exhaust leak instead of inside the engine? I ask because, before I spend MY time and money continuing to diagnose it, since It’ll be going back to the shop that did exhaust next week, I’ll just ask them to check their work since they only installed the exhaust a month ago. If it developed a leak in that short amount of time I expect them to be the ones to fix it, not me! Especially considering the amount the full exhaust cost me.
  30. Budget36
    Budget36
    Well, you could see if they have a “smoke machine”, pump the smoke in from the tail pipes and see if it’s coming out anywhere.
    My buddy bought one a few years back, not sure what he paid, but will check with him when he’s off work today.
