Hot Rods Building a Hot Rod with David Freiburger!
Discussion in 'The Hokey Ass Message Board' started by SamIyam, Jun 27, 2026.
  1. Hi everyone! I haven’t posted since I bought the remnants of the Roach Rod, but my latest project with David Freiburger is something you guys and gals will like. I’m hoping our effort will bring awareness to old hot rods. I feel that with so many people aging out, old hot rods and parts are going to be cheaper than ever… sadly, because of a high supply and low demand which, if the demand gets too low… these things will be headed to the s**** yard. So, check it out and p*** it on to a few friends!
  2. lake_harley
    lake_harley
    I would guess that hanging out and working with Freiburger must be quite an adventure.
    By the way, as easy as you drove out those spring perch pins from the axle, they must have already been out before filming began. LOL
    Lynn
  3. Blues4U
    Blues4U
    from So Cal
    That video was posted in another thread, and you were identified as the culprit helping Freiberger. :D
    It looks like a great start to a great hot rod Sam. Looking forward to more episodes.
  4. panhead_pete
    panhead_pete
  5. Roothawg
    Roothawg
    I watched the forst episode.It was good. I enjoyed it. You should try out for Mr. February
  6. HOTRODNORSKIE
    HOTRODNORSKIE
    Watched the video a couple days ago I thought to myself that mono leaf up front seams dangerous if it snaps David is eating asphalt what's your thoughts on mono leaf springs? Great video by the way.
  7. A Boner
    A Boner
    With so many engines D.F. is familiar with, it was cool to see him choose a SBC…and for the most popular reason to choose a SBC!
    Do the wishbone slices need any sort of fishplating?
  8. I’ve had two in two different cars that get beat on… they’ve held up. You have to make sure they don’t bottom out on the frame by notching the frame.
    missmuriel, Outback, rod1 and 6 others like this.
  9. Not that I know of. I’ve never seen anyone fish plate em. Factory they were **** welded.
  10. Where do I apply?
  11. 19Eddy30
    19Eddy30
    from VA
    One of best I road in had a Mono .
    There no diffrint mono or Multi spring if it breaks .
    Chevy Vs Ford sb engine in A's & 32
    Ford driver side issues oil filer , engine mount
    Exhaust , ds head back further into stock fire wall , interference using Vega steering box .
    scoop, Outback, chryslerfan55 and 5 others like this.
  12. Mart
    Mart
    Hi Sam. I enjoyed following the ch***is build. You have a depth of knowledge and are prepared to share it. Great to see you again and I am still thankful for the time you spent showing me around all those years ago.
    Mart.
  13. swade41
    swade41
    from Buffalo,NY
    So did you two agree on the final pinion angle with just two different ways to get there or was the angle in question ???
  14. Jalopy Joker
    Jalopy Joker
    Yep, video of a Hot Rod build by two experienced guys, and a trainee, great to see.
    Outback, lemondana, Driver50x and 7 others like this.
  15. AHotRod
    AHotRod
    So glad David is allowing you to bring traditional work ethic and design to his project, I'm following along.
    Great work as always Sam.
  16. RmK57
    RmK57
    The sbc is a no brainer….literally!
  17. Marty Strode
    Marty Strode
    Very interesting video, I like the cutting, modifying brackets, and placing them correctly on the frame. What it showed, was setting up the ch***is properly and the reasoning behind it. No fancy frame table, a torch, Sawzall, and a drill press, things that are easily acquired these days. Having "No Sham" Sam involved is a real ***et, with all of his experience, he knows how to build on a budget. I applaud you for doing this, just think about all those stock Model A's in Estate sales that could get a second life as a Hotrod, and perhaps getting some younger folks involved as well. Mine came from an Estate Sale, the name on the ***le was Glen Bone. So, I have a real A-Bone ! IMG_1539.jpg
  18. Yep. 6 in one, a half dozen in the other!
  19. Hi Mart! We had some great times! I’m pretty sure the Roach Rod and your roadster were the very first build series cars on the HAMB! Do you still have the bee hive oil filter?
    Outback, rod1, chryslerfan55 and 5 others like this.
  20. 41 GMC K-18
    41 GMC K-18
    A great video indeed, very cool that Davids son Jimmy is helping out as well.
  21. HOTRODPRIMER
    HOTRODPRIMER
    I have built 3 cars with the mono springs up front and one with the mono springs front and rear, never a problem. HRP
  22. HOTRODPRIMER
    HOTRODPRIMER
    Sam, enjoyed the video, HRP
  23. swade41
    swade41
    from Buffalo,NY
    Hey, that garbage bag tire mounting trick was pretty trick !
    I might have to try that the next time I'm doing a set, I normally use bondo spreaders to try and save the vintage aluminum rim lips.
  24. 19Eddy30
    19Eddy30
    from VA
    Trash bag works
    In your pic you are taken to much @ a time with your s****s,
    You need to only be 1-2 inch from where tire has already below lip .
    & in my opinion your safety pieces are too big (long)
    Only need to be little wider then s**** , try A piece of Like antifreeze jug material thin
  25. flamedabone
    flamedabone
    Maybe Sam needs his own Youtube channel....
    One of my favorite episodes. Nice work.
    -Abone.
    rod1, chryslerfan55, AHotRod and 5 others like this.
  26. sodbuster
    sodbuster
    from Kansas
    Thanks for sharing SamIam.
    rod1, chryslerfan55, Sharpone and 2 others like this.
  27. bschwoeble
    bschwoeble
    Great video. One of the best on doing it at home. I had two concerns. (1) The use of Helix products. I think the majority of us have heard the horror stories related to Helix. (2) The use of Heim ends instead of bushed ends.
  28. CSPIDY
    CSPIDY
    Great video, love the detail and tips.
    Also enjoyed seeing Gumby getting nailed by the pin.
    Sharpone, osage orange and porkshop like this.
  29. lumpy 63
    lumpy 63
    IMG_20260522_110944.jpg Hey Sam really enjoyed the video. My pal Gordie said you and David stopped by his spot at the roadster show , he really enjoyed chatting with you about his 29 pickup
    rod1, Okie Pete, okiedokie and 5 others like this.
  30. willymakeit
    willymakeit
    I liked the video and tips.
    Ordered a set of those radius gages
    chryslerfan55, Sharpone and porkshop like this.
