Technical Distributor Gear Indexing
Discussion in 'The Hokey Ass Message Board' started by GlassThamesDoug, Jun 30, 2026.
  1. GlassThamesDoug
    GlassThamesDoug
    Maybe I'm the last to know this,
    I was just going thru my sbc distributor collection to build a few to use. Going with points (hp) higher tension. 32oz.
    Had 1 or 2 last few years that didn't seem to arc at the correct spot when static timing engine?
    FYI: Fellow Jr Stock racer asked if the distributor gear was "indexed" . All the years messing with SBC's never heard of that. Shimmed distributors for clearance, most times I put gear right back on, as it was removed. Maybe lucky.. who knows.
    Gear Indexing is aligning the rotor location to the cap. 13T gear. Pin can be between 2T or align with 1T.
    I picked 5x random distributors.
    1x wrong
    3x correct(divot aligns with rotor)
    1x after market gear, no markings. On line sites, note align after market gear to original location.
    SS327, saltflats, swade41 and 3 others like this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, I knew about that....
    squirrel and Sharpone like this.
  3. GlassThamesDoug
    GlassThamesDoug
    I'm going to look close at the after market distributors I have as well. Made in China might be interesting.
    I've only checked caps with a fully degree balancer, only found one that was grossly off on 1 cyl in my buddies sportsman dirt car.
    Sharpone likes this.
  4. GlassThamesDoug
    GlassThamesDoug
    Did some digging, found some more sites noting Vac Advance is key, for clearance indexing. I've had issues where factory intakes with firewall or intake runner fouling. Going to check my 62 dual point, dual window cap distributor, it was always difficult to drop in/ locate with a GM factory high rise intake. I had gear off that one 15yr back.
    SS327 and Sharpone like this.
  5. anothercarguy
    anothercarguy
    I was not aware of this...learned something new...another good day!
    Sharpone and GlassThamesDoug like this.
  6. GlassThamesDoug
    GlassThamesDoug
    All the years looking at distributor gears, I (missed) never paid attention to the divot.
    SS327, Sharpone and anothercarguy like this.
  7. Sharpone
    Sharpone
    Amazing, learn something every day
    Thanks Doug
    Dan
    GlassThamesDoug likes this.
  8. tubman
    tubman
    I had a '68 Corvette, and when I tried to install the ignition shielding, it would not go on unless I turned the distributor. When I did that, I could not get the timing set right. I lived without shielding for about 6 months until I found out about this. I removed the distributor, and yep, the gear was indexed incorrectly. I changed it around, and everything went back together just like it was intended.
  9. GlassThamesDoug
    GlassThamesDoug
    Did not even think about Corvette shielding. Thx for that information. I know my dual window cap, I ended up putting the windows on back to time properly.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Great! Now you got me wanting to pull out at least two unit’s.
    GlassThamesDoug and Sharpone like this.
  11. Budget36
    Budget36
    Put me in the “I didn’t know that” crowd.
    Thanks
  12. GlassThamesDoug
    GlassThamesDoug
    I need to pull 2x as well, I'll wait until the wife is in the house.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Mine are fine. See I’ve always spiked the shaft and gear on the underside because I counted the number of teeth many many moons ago. Odd number told me one way only. Never have I looked and made the connection of the dot to rotor. Always thought why the need to balance such a small gear???
  14. GlassThamesDoug
    GlassThamesDoug
    Although the one distributor I would have bet, was never apart, was off.
    I remember making gears in swing boxes on cranes, good fail safe journeyman practice.
    Sharpone and Johnny Gee like this.
  15. saltflats
    saltflats
    from Missouri
    I always put a mark on the shaft and gear so it went back on the same. Now that doesn't mean someone before me didn't put it on wrong.
  16. GlassThamesDoug
    GlassThamesDoug
    This 327 hp intake always problematic with some of my distributors.
  17. squirrel
    I figured out the divot thing many years ago...I think I wondered what it was, then noticed that it was always where the rotor was pointing.
    good thing to know
  18. 19Eddy30
    19Eddy30
    from VA
    If you take apart a distributor
    you will see there quite a few timing precision in machining .
    Point & none
  19. tubman
    tubman
    Huh?
  20. bschwoeble
    bschwoeble
    Yeah,WHAT?
  21. GlassThamesDoug
    GlassThamesDoug
    I have purchased gear shim kits since the late 70s, do not remember instructions noting the alignment. But who reads instructions... might be in a drawer. :D
  22. GlassThamesDoug
    GlassThamesDoug
    I better be careful, I am stealing parts from one to build another. Any characteristics on switching the point cam mech to another. Early 60s cast iron dual point, to early 60s dual point distributor. DP Shaft,Tach Gear are fine... weight pin was damaged.
  23. GlassThamesDoug
    GlassThamesDoug
    Point Plates.... most have Patent Number. I found one Patent Pending...is that from 1955?
  24. squirrel
    57 or 58 I think was the first year of the distributor with the weights on top, the 55-56 used a different distributor. I had a pat pend cap on a 58 Chevy I had years ago, didn't realize I should have saved the cap!
  25. RodStRace
    RodStRace
    As a tune up guy, I always took care to mark before dis***embly if needed.
    Ran into the doesn't flip offset Ford drilling deal on later stuff, but didn't add up the divot to rotor on these. Learning!
    SS327, GlassThamesDoug and Sharpone like this.
  26. MMM1693
    MMM1693
    I'll be damned. Three quarters of a century old and still learning. I guess that remark could be taken a couple different ways.:(:D Makes a lot of sense though if you think about it.
    SS327, Sharpone and GlassThamesDoug like this.
  27. ronzmtrwrx
    ronzmtrwrx
    Interesting. Add me to the list of “did not know this”.
  28. 19Eddy30
    19Eddy30
    from VA
    There are Adjustable rotor ****ons for phasing.
    I think most think just a distributor,
    All parts from gear to Machined areas to rotor ****on , terminals in cap
    Affect timing Not so much on DD
  29. GlassThamesDoug
    GlassThamesDoug
    How bout the centrifugal advance spacer many time missing on rotor pin. I remember an article way back, where a speed shop also brazed up the advance slot and filed it to the advance desired. Dang we are getting old...
    SS327, BigRRR, Sharpone and 1 other person like this.
  30. Sharpone
    Sharpone
    I did know about the advance slot. If you mess with MOPARs you’ll find that setting the total mech advance to a reasonable amount say 34 or 35 degrees your initial timing will be too low, and you’ll have to narrow the slot.
    One thing for sure nobody knows it all.
    I’m not sure how many Chevy distributors I’ve pulled - quite a few- but I only remember tearing one down, I must of match marked or something I sure don’t remember a divot.
    Dan
    RodStRace and GlassThamesDoug like this.
