Hot Rods Zip's Water pump riser
Discussion in 'The Hokey Ass Message Board' started by krylon32, Jun 30, 2026.
  1. oldolds
    oldolds
    Reengineer it a bit.Move the pump to one side and incorporate a mount so an alternator could fit between the thermostat housing and the valve cover?
    Someone that has one should send it to @SDS so he could scan it. Then push the ****on on the printer and it is done? Sounds easy.
    SDS likes this.
  2. 325w
    325w
    Maybe one without thee alt and ac brackets
    .My coupe with ac on 97 outside shroud an 6 blade steel fan yesterday was steady at 180. Beat the big electric that it used to have
  3. krylon32
    krylon32
    from Nebraska
    You ask about copying. Never bothered Speedway. If Vintage Air thinks it's a viable part then maybe they'll start making them????
  4. I'm no machinist by any stretch, I didn't even have a dial caliper larger then 6" (need to find one).
  5. Not letting me upload pics....more later.
  6. goldmountain
    goldmountain
    A few years ago, I ***umed that I would need one for a car I was building but being a cheapskate, I took my existing Zip's housing and built a crude jig from it so that I could make my own out of s**** stuff I had laying around. When it was finished, turns out I didn't need it so I gave it away to a friend who was building a Model A.
  7. SDS
    SDS
    IF they have a patent, you only have to change it by around 20% to avoid their claims. Changing from a casting to CNC and moving a few things around should satisfy. There is plenty of prior art showing un-pateneted devices that do similar.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Casting to CNC? Like manufacture it out of a chunk of aluminum?
  9. SDS
    SDS
    Yes, read my above description and see the pic of the CAD model. Zero overhead that way.
  10. DDDenny
    Heaven forbid!
    Johnny Gee likes this.
  11. Could the riser be made of composite material, maybe with metal reinforcing points for pump mounting?
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Since I only know manual machining, how would a CNC machines cutter navigate it way thru to make the runners so coolant can p*** thru is why I’m asking. Or is that a parting line I see? As in a 2 piece construction? IMG_6165.jpeg
    alchemy likes this.
  13. SDS
    SDS
    Yes, 2 pieces. From an earlier post...
    With today's CNC and laser-cutting technology/availability, it could be made without casting relatively cheaply - especially en-m***e. you'd have to have the front plate bolt-on with a gasket to create the inner chamber - as it's CNC'd, a gland for a large o-ring could be easily machined and that could eliminate the need for a gasket
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Two things. One positive the other a factor needing further attention. L6 blocks do not have a raised mating surface for the water pump like the Zip riser does so a flat plate will do. IMG_6168.jpeg The concerning factor is proper clamp force along the four straight edges. Bosses along the outer edges would need to be added.
    So, will the m***es like/accept this?
  15. 19Eddy30
    19Eddy30
    from VA
    My self thought I hade a extra.
    billet or cast 2 pice , carbonfiber with like 15 or so 1/4 bolts O ring like 2 pice timing cover .
    If those do want look cast , sand could be added for texture.
    Most drive there vehicles Not with tire's they want
    Algoma56 likes this.
  16. krylon32
    krylon32
    from Nebraska
    I think if they were CNC machined they would have to be in 2 pieces and bolt together. I can't see how a milling machine could reach down inside the runners?
  17. SDS
    SDS
    Yes, not having the raise area will make it easier to produce the "lid".
    There will be screws around the perimeter to clamp the halves together.
    Everything will have attention to design detail as for it not to look too modern.
    One accurate measurement I really need is from the pump mating surface to the block mounting surfaces. That offset is VERY important.
  18. SDS
    SDS
  19. SDS
    SDS
    2 hours in a ********y tumbler and it will look nice...more like a die-cast part.
    curbspeed and Ken Smith like this.
  20. 34Phil
    34Phil
    legs could be bored from ends and fitted with pipe plugs but billet aluminum that thick is expensive.
  21. krylon32
    krylon32
    from Nebraska
    In the 90's we made a Flathead billet timing cover to compliment the 409 pump kit. That was all CNC machined.. Back then we had to get $500 to make a few bucks. With the increased cost of CNC time and the cost of a chunk of aluminum that big the cost today would be prohibitive.
  22. 19Eddy30
    19Eddy30
    from VA
    @SDS
    I would like to be in same town ,
    I have so many Idles ,
    I think even Sbf easily could be mad in way like Zip .
    Back in 90 I shared a Thought on a freon /ac type deal , 15-20 yrs Mopar made .
    I was in old shop few yrs back racers
    they where into Super Stock & pro comp
    They had 4 B-P's all connected together
    To duplicate parts .
    When younger I had a Pro mod & Mountain motor pro stock was arrested and some things & me
    I also hung around sealocks shop
    Who did some R&D for Enderle
    90's
    Like to make it to Oz to be @ Joe Blow shop
    In my vision I could make from crude to som way Eye appealing,
    Not a sbf pump thoe
    SDS likes this.
  23. Ken Smith
    Ken Smith
    Alliance Vendor
    If you have a clean CAD model, you can get online quotes pretty easily. Domestic or offshore machine shops. Price goes down as the quan***y goes up.
    SDS likes this.
  24. goldmountain
    goldmountain
    There is an old build thread here on the hamb posted by reyn from Saskatchewan on his building a Model A hiboy. In it, you can see the water pump riser setup he made.
  25. DDDenny
    IF anyone cares......
    There are tons of videos about CNC machining on THE TUBE, some are a little boring (pun), some are crazy to watch chow down stock, especially aluminum.
  26. pprather
    pprather
  27. 19Eddy30
    19Eddy30
    from VA
  28. 325w
    325w
    This was from Speedway.
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
  30. patsurf
    patsurf
    regarding a few posts above 'simple way' discussion-could you just make a simple one w/ 4 flanges and two pieces of sq/rd tube ( even pipe?-)--i know this ignores alternator and accessory stuff-but.....
