Projects 1956 Chevy Carryall new wood body
Discussion in 'The Hokey Ass Message Board' started by mamllc, Mar 17, 2025.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Not till now on your thread did I catch this filler piece (arrow) that aids the stile some what in strength by reshaping it. The upper mid rail does a good job of keeping the grain from wanting to break easily. IMG_6017.jpeg
  2. mamllc
    mamllc
    That piece is deep enough that it had to be cut out of a laminated block, so there is some opposing grain that reinforces it too. I always try to hide the glue lines when I have to do that.
  3. mamllc
    mamllc
    This door is done for now. It will come apart one more time to veneer the panels, install the gl*** and for final sanding. Everything works, the gl*** (pattern) rolls up and down and the inside and outside handles work. Door locks turned out to be an engineering project that wasn't worth the effort. And a couple pictures of a start on the drivers side door, more of the same. IMG_6013.JPG IMG_6014.JPG IMG_6015.JPG IMG_6016.JPG IMG_6010.JPG IMG_6012.JPG
  4. Six Ball
    Six Ball
    from Nevada
    Your craftsmanship is amazing! Having the right tools for a job is one thing. Using them at this level is altogether another thing. Here I am stumped over the relatively few pieces of wood for my '26 Chevy roadster. Great work, thanks for sharing.
  5. 1934coupe
    1934coupe
    I know how to use a hammer and what end of the saw goes against the wood, but the workmanship here is on another level. Like I tell my friends in my wood turning club I'm in the first grade and you guys have your Phd. You are both a craftsman and artist.
    Pat
  6. Sharpone
    Sharpone
  7. rockable
    rockable
  8. rod1
    rod1
    You never cease to amaze! Incredible work .
  9. patsurf
    patsurf
    lamb's tongue on the door instead of the stair!(well,kind of close...)--perfect!
    rod1 and Bill's Auto Works like this.
  10. ronzmtrwrx
    ronzmtrwrx
    Simply put: Amazing.
  11. 1952henry
    1952henry
  12. Great progress, keep the updates coming.
    rod1, Bill's Auto Works and Sharpone like this.
  13. mamllc
    mamllc
    This should look familiar, a mirror image of the other side. I still have a few details on the drivers door to wrap up but I'll be on to the back doors soon. IMG_6024.JPG IMG_6025.JPG IMG_6027.JPG IMG_6028.JPG IMG_6053.JPG IMG_6054.JPG IMG_6055.JPG
  14. Okie Pete
    Okie Pete
    Beautiful craftsmanship. Thank you for sharing your progress
    What will you coat the inside of the doors with ?
  15. 41 GMC K-18
    41 GMC K-18
  16. patsurf
    patsurf
  17. mamllc
    mamllc
    Thanks, and thanks for looking!
    Eveything has to come apart to do the finish work, so the first coat will get put on both sides of everything. I'm not doing the finish on this one so I don't know whether it will be varnish or clear coat.
  18. mamllc
    mamllc
    I don't have a steel door to compare them to, but I can hang a fully ***embled door on the body by myself without too much trouble. Getting them adjusted is another topic altogether, but if they are heavier than a steel door I don't think it's by much.
  19. Baumi
    Baumi
    Wow, that´s a work of art!
  20. ronzmtrwrx
    ronzmtrwrx
    I appreciate your vision and the talent to bring it to life. Beautiful work.
  21. SS327, mamllc, Six Ball and 1 other person like this.
  22. RodStRace
    RodStRace
    Staring at hose I am amazed with your talents and the original designers and craftsmen who did these originally.
    I do have a question; most all metal doors with windows have some sort of drain at the bottom for any water and dirt that gets in between the window and the seal. Was this feature built into these? Was that part of some annual (?) service to pull the inner panel and clean?
  23. 1-SHOT
    1-SHOT
    from Denton
    Love the craftsman ship
  24. mamllc
    mamllc
    Yes they do have drains. I'm not sure that opening up the door to clean the drains was part of factory recomended maintenance, but I'm pretty sure nobody did it.
    Six Ball, Sharpone and RodStRace like this.
  25. mr.chevrolet
    mr.chevrolet
    my compliments on the woodwork, but, I'm more impressed with the amount of engineering that went into each piece. keep those pics coming.
    Six Ball and Sharpone like this.
