Technical Tips Needed: cutting coils on my 53 Cadillac
Discussion in 'Traditional Customs' started by 55CadillacTed, Jun 27, 2026.
  1. 55CadillacTed
    55CadillacTed
    Hey gang. I’ll be putting 4” lowering blocks on the rear. Yes i want it very low.
    Could you offer me some tips on cutting the coils?
    Is my sequence correct?
    —jack up the car + remove wheel
    —put another jack under the a-arm holding pressure on it
    —remove the shocks
    —detach sway bar?
    —which is the best place to remove spindle? Circled in yellow?
    —at this point i should be able to slowly lower the a-arm using the jack….being mindful that the spring is under huge pressure here.
    —eventually the arm will be low enough and spring under no pressure and I can just reach in and remove it now?
    —cut 1.5 coils = 3” roughly?
    —re***emble.
    —Dream big. Fart loud.
    —am i missing anything?
  2. clem
    clem
    I would never lower a car by cutting coils, so I cannot give you any tips apart from the one I just gave you………
    bttt………..so others can advise you ………..
    Wobbly likes this.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    I have lowered dozens of cars by cutting coils and never had any issues. Do you have a shop manual for this car? If not you should get one. The part you have circled may be an eccentric for adjusting the alignment ( I do not know for certain). One thing I do know is that 4” lowering blocks almost always require C notching the frame and or raising the drive shaft tunnel in the floor
  4. lostone
    lostone
    from kansas
    I'm with Moriarty, rather cut a coil then replace.
    Cutting a coil doesn't change ride (to a limit as in too low bottoming out) it only changes the height of the spring not spring rate.
    Thru the years of doing this to dozens and i mean dozens of cars, it always seemed that lowering springs seemed a lot stiffer/higher spring rate and drove so much harsher then just cutting the oem springs. Figured it was either a "it's close enough to fit application" to " make it stiffer so it don't bottom out" thing.
    Moriarity likes this.
  5. bobss396
    bobss396
    I cut the new springs in my OT Belair in 2024, lopped 2 coils out and it rides well.
    lostone and Moriarity like this.
  6. rusty1
    rusty1
    I cut coils without removing them, use a long all-thread and a thick barstock that is longer than the coil width, jack the front up so the lower a frame drops, insert the bar just above the bottom coils you want to cut, draw up the all-thread until the bottom coils are off the bottom of the a frame, cut and remove the all-thread....a lot faster than removing everything
  7. lostone
    lostone
    from kansas
    @rusty1 They actually make a tool to do that. It's kind of a pain to use the first couple times until you get the hang of but once you do it works well.
    It's a steel plate with two 1/4" chains welded to it. The chains go around the bottom of the lower arm and back down to locks to the plate. So the plate is basically floating below the arm. Then another curved plate goes into the spring coils. Then you take a 4-ton ram, slide it up thru the shock hole and it locks into the curved plate and sits on the floating plate and you just jack away.
    Used it all the time to cut springs, works really well too for putting in aluminum spring spacers under the spring into the spring pockets.
    Don't know if they even make that tool set anymore.... beeline if I remember correctly...
  8. BJR
    BJR
    The adjustment on Buicks is at the top A frame. So it’s ok to remove the bottom trunion, and cut the coil.
    Damon777, Bangingoldtin and Moriarity like this.
  9. The front suspension arrangement looks to be the same as Buick. Cutting coils is a good way to lower it, but other factors come into play that warrant consideration- Because of the un-equal A-arm design, as the lower A-arm rises, its arc changes the length affecting the camber. Adjusting the eccentric in the upper arm may compensate for a reasonable drop, 3" maybe not. That much drop will also require heating and bending the steering arms or bump-steer may happen. I studied this for a while on my cars and decided to go the dropped spindle route. Uprights.JPG
  10. 50chevytx
    50chevytx
    Don’t know for sure with your Cad, the manual for my fifty Chevy says to remove the four bolts from the other end of the lower control arm at the frame.
  11. rusty1
    rusty1
    ...I made my own tool for this, mite try to post pics later
    Algoma56 likes this.
  12. vtx1800
    vtx1800
    Screenshot 2026-06-28 at 8.31.48 PM.png For what it is worth, on the Studebaker (same basic suspension) you would remove the A arm bolts from the frame. I'd advise against dis***embly of the trunnions.
  13. krazee
    krazee
    I'm not sure that is entirely correct, cutting coils does increase the spring rate because you have less active coils, however if you are lowering the car a slightly increased spring rate helps with bottoming out and also can help ride quality. I too prefer to cut OEM springs. Double check your shock length and make sure the spring pocket matches what was originally there. I have probably done more than 20 this year for guy's with off topic race cars. My '60 Parkwood wagon has cut springs for 30 plus years (1 1/2 coils from memory)
  14. Clydesdale
    Clydesdale
    This is correct, a shortened spring will have an increased rate and thus feel 'stiffer' but those consequences are often a bonus for a lowered vehicle.
  15. BJR
    BJR
    I did this 3 weeks ago on a 50 Olds 88 which has the same suspension as the Cadillac. Jack the car up so the front wheels are off the ground by about 6 inches. Remove wheels, remove swaybar links, remove tie rod ends from steering arms. If there is a shock in the center of the coil remove it. Put a jack under the lower A frame, and remove the lower trunnion from the A frame. Lower the jack slowly until the spring will come out. Read this backwards to ***emble. :D
    southerncad, BigRRR and Uncle Ronn like this.
  16. 55CadillacTed
    55CadillacTed
    QUESTION: Remove the shock first…then the thick threaded rod feeds up from the bottom?
    RIGHT ON! Thank you. So it is correct that this is where I should dis***emble? (Circled in yellow) IMG_4769.jpeg
  17. ^^^^ When removing the lower trunnion, count the number of turns it takes to remove it. There is a slight adjustment there for the caster.
  18. Tim
    Tim
    from KCMO
    Didn’t read all of the replies but 1: put the car in jack stands not a jack. Then you only need one jack and it’s got less of a chance of killing you.
    2: let the coils cool off really slow after cutting them. Don’t quench them
    panhead_pete likes this.
  19. BJR
    BJR
    Yes, and don't use a torch to cut the coils, use a cutoff wheel, you get a cleaner cut and you don't change the spring metallurgy.
  20. 50chevytx
    50chevytx
    If you can get it out, you don’t have any leverage on that short side. That’s the reason the manual says to remove on the other side a lot of pressure on the spring!!!
    RMR&C, Ken Smith and vtx1800 like this.
  21. Hot Rods Ta Hell
    Hot Rods Ta Hell
    And if you don't have a cutoff wheel, use a hacksaw with a really high-quality blade, you'll cut through it in less than 2 minutes. Did this a couple of times when I was 15/16, when I only had basic hand tools to work with, lol.
    Cheap dental insurance: get a couple foot long length of chain. Thread it through the coil spring and around the frame, then lock the ends with a padlock. If your jack slips off the lower A arm when lowering, the spring will stay with the car instead of nailing you.
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    Really? I have cut dozens and dozens with a torch. the heat affected area is really very small and does not hurt the spring one bit
    ronzmtrwrx and Clydesdale like this.
  23. alchemy
    alchemy
    Forty years ago when we’d cut coils on cars, we would remove them from the inside of the A arm. Much easier to remove a few bolts than to remove the ball joint.
    We would cut them with a torch back then, but nowadays I’d use a cutoff wheel.
    We did notice the shorter spring is stiffer. But as said above, that’s not a bad thing.
    And I think the most important advice is, cutting a certain amount of length off the spring does not drop the car that same amount. Geometry, spring rate, and all that will actually multiply the amount of drop. Sneak up on it. It’s easier to cut more off than put it back on.
    winduptoy likes this.
  24. Damon777
    Damon777
    I would do a half coil at a time. When I did my Buick, I went straight to 1-1/2 coils. I ended up having to cut the bump stops in half to have any sort of suspension travel. But man, did it look cool. I could probably extract a spring, cut it, and have everything back together in 45 minutes or so, so it's not a big deal to sneak up on it, IMO.
    I subsequently purchased drop springs, and if I were to go lower on the stock suspension, I'd be looking for drop uprights. I am planning on doing OT things to get that low ride height in the future, and they do not involve airbags or hydraulics.
  25. 55CadillacTed
    55CadillacTed
    Hey fellas. I’m about to cut the coils, which of these 3 bolts do I remove? Many thanks. Snapshot 13-07-2026 07-03.png
  26. BJR
    BJR
    #2 is the shock, that needs to be removed.
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    your job will be far easier if you completely remove the shock. so you will need to unbolt the top attachment point and remove bolts 1, 2 and 3 so you can drop the shock out of the bottom
    Ralphies54 and BJR like this.
  28. 55CadillacTed
    55CadillacTed
    ….that was my su****ion but wanted to hear it from people w
    very cool. Thank you. That was my thought also. I did this proceedure to my 55 Cadillac about 10 years ago. I cut 1.5 coils and it sat low and drove great.
  29. 38Chevy454
    38Chevy454
    Take some safety advice and wrap a chain around one coil and something like the A-arm or frame nad connect them with a bolt or similar to complete the loop. Just in case the spring flies out when are lowering the A-arm. Allow enough slack for the spring to become loose, but not loose enough for the spring to hit you. Even once you have the A-arm lowered the spring may still be slightly under pressure, so use a pry bar or similar longer tool to help wedge it out if necessary.
    Another thing which I have no idea on your car, but sometimes springs are flattened on one or both ends; or pig tailed into a smaller circle. Those need to stay flat or the spring won't sit right in the pocket. Those type springs need a shorter replacement spring, can't cut them since the end will now be non-flat or too big of diameter to fit back in.
  30. 55CadillacTed
    55CadillacTed
    HEY GANG.
    So i just removed the coils from my 53 Cad. I cut 1 full coil of both springs (from the open ended side obviously, not the smoothened flat side.)
    When i was removing the springs I noticed the flattened end of the coils were on the bottom so the open ended coil was at the top.
    Isn’t that the opposite of what supposed to be? This car was definitely dis***embled at some point, i can tell by some after market shiny bolts holding the lower shock mount and a few other things.
    On the upper and lower spring cup…i do not see any little recessed pocket where the pigtail would sit; both spring pockets are smooth.
    How should I reinstall the springs? ….smooth end at the top or bottom?
    I found this old photo online and I think it said for GM cars 1950 & older.
    It obviously shows the flat side at the top.
    Anyone know definitively?
    MANY THANKS!
    TED
