Projects 37 Tudor family hauler/push car
Discussion in 'Traditional Customs' started by youngrodder1929, Jul 1, 2024.
  1. youngrodder1929
    youngrodder1929
    Take 2 on the brake bleed... The new fandangle duel pot 1940 master out does not operate as it should and a 2 leaking wheel cylinders we have a adapter made up for mustang master like I've run before in a couple cars new fittings back to where we thought we were before haha PXL_20260710_201740854.RAW-01.MP.jpg PXL_20260711_032018816.RAW-01.MP.jpg ..
  2. youngrodder1929
    youngrodder1929
    Brakes bled ,Body back on tell paint down the road PXL_20260713_230138727.RAW-01.MP.jpg !
    Hnstray, fordor, Outback and 12 others like this.
  3. youngrodder1929
    youngrodder1929
    Engine has a Merc crank .080 over pistons max1 cam Chev valves. Heads torqued pan on valves set and a coat of 2k primer. PXL_20260802_224920949.RAW-02.ORIGINAL~2.jpg PXL_20260803_000942525.RAW-01.MP.jpg
    Outback, brad2v, Tim and 4 others like this.
  4. guthriesmith
    guthriesmith
    Loving this build! Engine is going to look great!
  5. youngrodder1929
    youngrodder1929
    Thanks !
  6. youngrodder1929
    youngrodder1929
    Today was productive loaded car moved it across town unloaded painted engine and bolted it in not long now ! PXL_20260803_214937776.RAW-01.MP.jpg Screenshot_20260803-191544.png
    Thanks for following along!
    Dannerr, Outback, brad2v and 8 others like this.
  7. Okie Pete
    Okie Pete
    Very Kool thanks for sharing your build
  8. Dan Hay
    Dan Hay
    Even without the front clip I can tell the stance is spot on, and the chop still looks amazing!
    Outback likes this.
  9. youngrodder1929
    youngrodder1929
    Thanks Dan ! It's been wile since it's all been together looking forward to it
    Dan Hay and Okie Pete like this.
  10. youngrodder1929
    youngrodder1929
    PXL_20260805_034907935.RAW-01.MP.jpg Another day further along..
    Dannerr, Mikko_, Outback and 4 others like this.
  11. AmishMike
    AmishMike
    & a set of flipper caps - what we called those hub caps years ago. Full set?
    dana barlow likes this.
  12. youngrodder1929
    youngrodder1929
    Just a pair for the front not much to show on the rear.. PXL_20260803_184113520.RAW-01.MP.jpg
  13. Tim
    Tim
    from KCMO
    Oh man this is gonna be good!
    daylatedollarshort and Outback like this.
  14. Outback
    Outback
    from NE Vic, Oz
    Yes & Amen!
    Okie Pete and Tim like this.
  15. Bugguts
    Bugguts
    Very cool build! Thanks for bringing us along.
  16. Nice, keep up the good work, this is a cool build.
    Okie Pete likes this.
  17. youngrodder1929
    youngrodder1929
    Thanks fellas more to come soon
    Okie Pete and Outback like this.
  18. youngrodder1929
    youngrodder1929
    Runner!. Got the timing set checked for leaks ect. A few things to tie up but getting closer to driving.. Screenshot_20260810-213039.png
    As always thanks for following along
  19. Tim
    Tim
    from KCMO
    That’s awesome!
  20. youngrodder1929
    youngrodder1929
    For the clutch linkage sorted and adjusted it moves it stops ! PXL_20260815_003225022.RAW-01.MP.jpg
    brad2v, Okie Pete, jaracer and 2 others like this.
  21. Tim
    Tim
    from KCMO
  22. Outback
    Outback
    from NE Vic, Oz
  23. youngrodder1929
    youngrodder1929
    Got the front end back on still lots of little projects left. I definitely want to add a leaf or 2 in the front it's to low for me from its past life as a hotrod. I think there will be more body modifications this winter more to come...
    Thanks for following along !
    Davis
  24. Mikko_
    Mikko_
    from Sweden
    Coming along nicely.
    youngrodder1929 likes this.
  25. brad2v
    brad2v
  26. guthriesmith
    guthriesmith
    Very cool! And, I kinda like the stance now for what it is worth. I get where you are headed, but it sits pretty good now too. :D
    Okie Pete and anothercarguy like this.
  27. alchemy
    alchemy
    I also think it sits nice right now.
    Okie Pete and guthriesmith like this.
  28. youngrodder1929
    youngrodder1929
    Thanks fellas, you've talked me into it it's moved down the priority list lol
    Okie Pete, guthriesmith and Tim like this.
  29. youngrodder1929
    youngrodder1929
    Spent some time on hooking up the lights and putting a couple gauges. The factory gauge only goes to 50psi but needs a friend. I will eventually put a temp in when I find a one to replace the amp.
    (Hood sides are a must for me I keep forgetting to get them from the storage)
    I have been really thinking about the next round of metal that is the part I really enjoy. To me the fenders really do need moulded. The question is do the running boards need to go with channel with the fenders pushed up like the s
    Summers convertible.
    Thanks for following along and positive words PXL_20260819_023959508.RAW-01.MP.jpg 48f50419-111d-44e9-b597-5f68979e6113.jpg PXL_20260819_023942896.RAW-01.MP.jpg
  30. alchemy
    alchemy
    How about “coke bottling” the running boards? That’s something you don’t see often.
    Okie Pete, brad2v and guthriesmith like this.
