Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. DDDenny
    You, me and a gazillion others!
    Sharpone likes this.
  2. GuyW
    GuyW
    My '36 PU with 327 had front & (stock CI) bellhousing engine mounts only - no trans mount for the Muncie, it worked perfectly. No experience with aluminum bellhousing applications tho.
    lothiandon1940 and chevy57dude like this.
  3. HOTRODNORSKIE
    HOTRODNORSKIE
    Good question I'll have to check the other side has the dash guage prob.
    lothiandon1940 likes this.
  4. skooch
    skooch
    Yeah, nice clean install but it didn’t work for me. Probe will need to be submerged next to thermostat. If you do decide to try it, get yourself a $25 thermal gun from harbor freight and confirm your actual temperature.
  5. HOTRODNORSKIE
    HOTRODNORSKIE
    That's strange that it didn't work for you its a water inlet outlet for the heater core so its getting plenty of hot coolent in theory anyways I'll find out as I don't want to drill a hole in that Crager intake.
  6. Dick Stevens
    Dick Stevens
    That sounds like you had an air pocket that didn't get bled out of the system.
  7. hrm2k
    hrm2k
    I need some new pants, these have gotten real tight
  8. chevy57dude
    chevy57dude
    @hrm2k - The kids in those imports have nothing on you! That's worthy of a clear hood. If it runs as good as it looks, you know... A friend had a mid engine turbo decades ago. The whine behind the mind is fine!
    Okie Pete, Sharpone, porkshop and 3 others like this.
  9. skooch
    skooch
    Could be.
    porkshop and lothiandon1940 like this.
  10. mgtstumpy
    mgtstumpy
    A little more progress, I updated the OEM shift gate and added Park & OD but lost the ability to engage lower gears until gate is modified further. These Hydramatics didn't feature a Park detent. For all intents and purposes it appears original. I just need to file another detent into casting. I had new shift ****ons 3D printed with the face plate milled to accept an additional ****on. I've NOS gear position/lamp ***embly and horn contact to finish off
  11. chevy57dude
    chevy57dude
  12. deathrowdave
    deathrowdave
    from NKy
    Nice work .
    Sharpone, porkshop, hrm2k and 2 others like this.
  13. Greg Rogers
    Greg Rogers
  14. kls50
    kls50
    I finally got the steering box I took apart last year together. After cleaning, polishing, adjusting, and painting it, I got it done. I installed a new sector shaft seal and spent some extra time to adjust the box. The parts I reused were not new and I had trouble adjusting the spring scale pull at the steering wheel. The worm gear on the shaft must have been worn slightly more on the center than on the ends which after adjusting made the resistance more at the ends of the shaft worm gear than in the center of the shaft worm gear. I adjusted it DSC01367.JPG DSC01368.JPG DSC01369.JPG snug at the center and slightly higher resistance on the ends. still almost within specs and I'm happy with the results so far. I will let you know when I have it on the road. I filled it with Castrol SAE 140 D oil and will top it off when I'm done. Next on to the column. A surprise coming at the end! Any guesses!
    Okie Pete, saltflats, hrm2k and 6 others like this.
  15. HOTRODNORSKIE
    HOTRODNORSKIE
    Ran into a little snag on the olds 303 the adaptor ring hit the presure plate,had 2 options find a long pressure plate with a diaphragm bolt pattern or replace the bell housing l chose a bell housing and Speed Gems sent me out one. Got it bolted up now I have to figure out the hydraulic through out bearing. 20260718_150705.jpg
  16. 57 Fargo
    57 Fargo
    Swapped a set of 3.91:1 gears in the little Barracuda for next weeks adventure
    porkshop, Robdski, saltflats and 7 others like this.
  17. What HAD been in it?
    Ben
  18. 57 Fargo
    57 Fargo
    3.55s
    saltflats, firstinsteele and hrm2k like this.
  19. Im working on spending less time on the internet and more time in my shop building ****boxes.
    porkshop, kls50, MMM1693 and 8 others like this.
  20. saltflats
    saltflats
    from Missouri
    Looking through this windshield
    Instead of this one
    On are way home from the meltdown drags.
    ffr1222k, Okie Pete, porkshop and 5 others like this.
  21. Dick Stevens
    Dick Stevens
    porkshop, saltflats, Sharpone and 2 others like this.
  22. saltflats
    saltflats
    from Missouri
    It was really hot so performance was down. I did however find my problem with the cars performance drop i have been experiencing ever since I got it going after it's 7 year nap. I will update my build thread when I get home later today.
    Okie Pete, chevy57dude, rod1 and 5 others like this.
  23. squirrel
    Bolting the front fenders on friend's 57, I ran into a problem, no mounting tab! so I fixed it.
    Hopefully the pictures tell the story.
    p*** side was OK
    driver side was not.
  24. AldeanFan
    AldeanFan
    Cleaning up this ranger 8.8 for the Country Squire,
    New seals and axle bearings installed
  25. Sharpone
    Sharpone
    Making a junk and drink caddy, also a shift console for the Dart.
    Dan IMG_4318.jpeg IMG_4320.jpeg IMG_4321.jpeg IMG_4322.jpeg IMG_4323.jpeg IMG_4324.jpeg
  26. kls50
    kls50
    Stripping paint from my 1950 Ford column tube with my wire wheel. No big deal. I forgot about the grinding wheel on the other side. Dang if it didn't bite me! All gooder!
  27. Wobbly
    Wobbly
    from UK
    I got the used fender shot blasted and quickly put a few coats of white epoxy on the outside and marine grade red oxide type paint on the inside. I'll revisit the front rust patch later but for now I just wanted to get the fender sealed asap what with the high humidity at the mo. Its gapped up pretty good but will be better when the excess filler is removed from the lower front door and they are patched properly. Installed an oil cooler for the trans. Removed the rear bumper for some mild straightening prior to going for replating along with the front end chrome. I was ill prepared for the weight of it when I took out the last bolts and it bounced off my chest :eek:. While it was off I took the chance to clean up the paint etc behind it and fit some nos indicator/reverse light lenses (will fit the lower ones when the correct screws arrive). Carried out another block coolant flush using Wynns (damn you previous owner for running it on just water). The Wynns seems to have done the trick this this time (damn me for cheaping out using a plain water flush prior) :D. Oh, and fitted the newly spruced up heater matrix box without core. The flow into the radiator has never been better and the car runs so much cooler.
    20260627_093559.jpg 20260626_093543.jpg 20260713_162142.jpg 20260713_164655.jpg 20260713_164712.jpg 20260713_141510.jpg 20260719_112109.jpg 20260719_145001.jpg 20260719_145022.jpg 20260718_173347.jpg 20260718_175340.jpg
  28. impala4speed
    impala4speed
    That's a very beautiful car Wobbly. Great work!
  29. Voh
    Voh
    WOW!
    Are those the for use wheels or mockup?
  30. Sharpone
    Sharpone
