History Big and littles..or big and biggers. 21s and 19s, who has done it?
Discussion in 'Traditional Hot Rods' started by fatassbuick, Jul 17, 2026.
  1. fatassbuick
    fatassbuick
    from Kentucky
    As shown, this is my A/T coupe. I ordered some 4.50x21 Excelsior tires for some good rims I have. I've tried searching, but does anyone have pics of a 21" fat rear and 19" in front on a "traditional" Model A, T, or anything gowish? 20260612_214033(1)(1).jpg
  2. 3blapcam
    3blapcam
    Oh man... no love for this thread?! I have definitely seen some roadsters on tall wires that look good... but I do not have any save pictures of them. :oops:
    3blap.
    fatassbuick likes this.
  3. Outback
    Outback
    from NE Vic, Oz
    I tried to Gee up a friend to post, but he didn't bite, these are of his car. Lots of tricky little details 489487304_3997242407261708_7211577753263420820_n.jpg 729437932_4449965748656036_6030100596596398817_n.jpg 504316950_4057542631231685_5772358024998182198_n.jpg 496158222_4030866127232669_8789704984432727538_n.jpg 503691626_4057290937923521_8603009427206711263_n.jpg
    cactus1, Lil 32, Deutscher and 6 others like this.
  4. Outback
    Outback
    from NE Vic, Oz
    4.00 & 5.50 - 21" I believe
    Any one notice the wheel mod? ;)
    cactus1 likes this.
  5. I don’t know the specs on this, but seems to be in the vein of what you’re talking about. 24B1029F-C90E-4C4B-A270-4D0BE20A0AD9.jpeg
  6. 3blapcam
    3blapcam
    Nope. I'm guessing the later caps require a smaller opening?
    3blap.
  7. fatassbuick
    fatassbuick
    from Kentucky
    Welp, my 21s came in and they appear way too skinny (4.50-4.75) to look right with my 19s. It'll be next week before I can mount them up and see, but they obviously fit the wheel well better.
    Outback and 3blapcam like this.
  8. Outback
    Outback
    from NE Vic, Oz
    It's had 32-5 hub cap rings - the cone the spokes are welded too fitted to the 21's. If that makes sense. It's super subtle.
    That Rpu looks good, I'm guessing 18's
    Lil 32 and Deutscher like this.
  9. Stan Back
    Stan Back
    Here are 18" Halibrands on the back (and Mercury Monarch 14"s on the front). . . .
    69fury, Deutscher and Outback like this.
  10. Stan Back
    Stan Back
    . . . here's a gear change.
  11. Hitchhiker
    Hitchhiker
    That's the stock tire size. Not sure why you'd expect them to be fatter.
    Outback likes this.
  12. 3blapcam
    3blapcam
    It does. I think we're saying the same thing, but the way it was done was different than what I was thinking. I ***umed they cut & welded just the outer portion that holds the cap, but you're saying the whole center portion was swapped?! That sounds a lot more risky work, but given the right tools, probably a better process. It looks good!
    3blap.
    Outback likes this.
  13. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    Something you sometimes see is to use a 19 or 21" in the front, and then actually use a smaller diameter, slightly wider, Ford wire on the rear. 16, 17, or 18" will let you put a taller tire, like a 6.50 or 7.00 and still have the overall height be taller than the front. The smaller diameter wheel also makes the rear tire look bigger.
    clem likes this.
  14. fatassbuick
    fatassbuick
    from Kentucky
    I expected them to be the same width as the fronts (which are numerically the same width), but the tread width appears narrower. Again, I won't be able to mount them until next week, so I only took a quick glance at them. Make better sense?
  15. Outback
    Outback
    from NE Vic, Oz
    the centre where the studs are are stock A & The outside spokes cut & welded. Not sure if I can find a photo
  16. burl
    burl
    from Minnesota
    Casey is running these on the tub. Not sure where they came from sanford 2.jpg
    fatassbuick and 3blapcam like this.
  17. fatassbuick
    fatassbuick
    from Kentucky
    Damn those are meaty
