Features Traditional wheel/tire combo
Discussion in 'The Hokey Ass Message Board' started by Red32cpe, Jul 23, 2026.
  1. Red32cpe
    Red32cpe
    So im new to the "hot rod scene. Ive been a VW aircooled guy forever and recently purchased a gl*** 32 3 window coupe. It's your basic small block chevy, TH350 ****** and some american racing wheels. I want to lean more towards the traditional hot rod with the steel or wire wheels and the bias ply look tires. My question is, where do I start? Do I stay with a 15 inch wheel or bump to 16's or bigger? What about the tires? what size on the front and rear?
    Thanks for any help!
  2. Bandit Billy
    Bandit Billy
    That's like asking a guy online what shoes you need. Fenders? Lowered? A picture would help (not of you or your feet, the car please). Budget?
  3. jimmy six
    jimmy six
    What’s the “hot rod scene?”
  4. DDDenny
    Welcome and brace yourself, you are gonna learn a lot here, some wanted, some not, you may need some thick skin at times but it will be worth it.
    There is NOTHING that hasn't been attempted on 32 Fords so one needs to be careful in the selection of components based on what others suggest, the only thing you can do wrong is combine components from different "build styles", makes for a confused looking car.
    Ultimately the end product only has to please you.
  5. Doublepumper
    Doublepumper
    from OR-WA, USA
    Start by looking at cars here on the HAMB. We're all about traditional around here. Good luck!
    Sharpone, Deutscher, Budget36 and 2 others like this.
  6. Red32cpe
    Red32cpe
    here is the car, i plan on adding the engine covers. Hate the wheel/tire combo.
    Ziggster, Sharpone, Lil 32 and 3 others like this.
  7. ***Area-51***
    ***Area-51***
    from Ohio
    Show us what kind of wheels you like,
    That will tell us where your mind is at and if you need tutoring…
    more pics of the 32 also, jus say’n
    Sharpone, chryslerfan55 and Stogy like this.
  8. Red32cpe
    Red32cpe
  9. Stogy
    Stogy
    Chrome Reverse 16" or 15" and 750x16 Firestone Champions rear and 550x16 FC front fit the bill...no caps...thinking Graffiti Coupe
    Steelies with trim rings and Old Ford Caps...
    The Coker Excelsior Roadster Radials really do closely match the Champions but they don't come in 550x16
    Others are running the Auburns that also are pretty close match to bias in look...
    Kiwi 4d, Sharpone, Deutscher and 3 others like this.
  10. Stogy
    Stogy
    Is your axle dropped? I don't think that top image front tire comes as a radial and combining bias and radial is not recommended...
  11. F-head
    F-head
    If your car has 5 1/2” bolt pattern you can get a pair of 16x4” 40 ford wheels for the front And 16x4.5 for the rear for a fairly reasonable price
    16x5 will cost more
    If you have 4 1/2” or 4 3/4” bolt pattern they make repop 16” steel wheels that look like early ford wheels and take a 40/48 cap
  12. HOTRODPRIMER
    HOTRODPRIMER
    It looks like your '32 is on a Model A frame. HRP
    Kiwi 4d, Ziggster, Sharpone and 3 others like this.
  13. 19Eddy30
    19Eddy30
    from VA
    Thats alot of parts not looking @
    Detail , just drive
    Looks A.I build
    Tire side walls , specially rear
    Octopus of Hoses
    Wonder if there Navigation & vehicle too close sensors?
    Sharpone, Kiwi 4d, Budget36 and 3 others like this.
  14. flthd31
    flthd31
    Your '32 looks a lot like it has a straight rail Model A frame under it. The big and little tires are close, size wise, but that frame seems to be giving it an uphill rake.
  15. squirrel
    just because someone had to crop the picture.... :)
    Kiwi 4d, Ziggster, Sharpone and 4 others like this.
  16. Stogy
    Stogy
    @Red32cpe as a New Member first off welcome...second no matter what you do this Hotrod the Thread belongs in the Hokey *** Message Board Forum...a Mod will redirect it...Traditional Forum is very Period Specific. You'll come to understand that if you hang around and you should...it's a cool place...
    Sharpone and chryslerfan55 like this.
  17. Dago 88
    Dago 88
    The usual 4” dropped axle, reversed spring eyes front & rear, 550 x 16 front & 750 x 16’s rear.:) IMG_3316.jpeg
    UNCLECHET, Kiwi 4d, Ziggster and 6 others like this.
  18. Stogy
    Stogy
    Not sure but www's are an option...
  19. Dago 88
    Dago 88
    [QUOTE="Stogy,
    [/QUOTE]Yes : IMG_3135.jpeg
  20. Not sure if it’s camera angle, or the chop, it looks like the original picture is running up hill a bit. All your chosen pictures are nose down, likely due to the use of a dropped axle. Your rear wheel wells are not filled out so you can use a taller tire in the rear. I doubt you can change the look any cheaper than with rubber rake. This one was popular at a show a couple of years back. 5CDA6676-6A68-4DA1-8959-25F8065CA97D.jpeg
    Sharpone, Lil 32 and Stogy like this.
  21. jimmy six
    jimmy six
    Hate if you want…. In the mid 60’s on the American Torque Wheels were the go to. Bigs and littles were alway right and for me narrow and not wide.
    Everyone has there style but seeing a 32 on a straight rail frame and not a 32 seems out of place. Good luck with your new project.
  22. Lil 32
    Lil 32
    Red welcome to site
    Lil32
    Sharpone and Stogy like this.
  23. Kiwi 4d
    Kiwi 4d
    Welcome and you seem to have the general idea of what traditional looks like. I 100% agree on tidying up the engine bay bag of snakes ,surely the AC can be hidden, at least down under we don’t need ugly AC in a highboy in our temperate climate . Loose the not nice side pipe exhaust please , that screams street rod and “ I could not be bothered fabricating it up and over the rear axle” so took the easy way out to look horrible.
    A little effort and you will have very a cool traditional car. Aha I just reread your first post and do you mean by engine cover , a hood top and sides ? That will certainly hide the ugly snakes and clean it up , but they are lurking beneath the surface ready to bite.
    Lil 32, Sharpone, bschwoeble and 2 others like this.
  24. Budget36
    Budget36
    Is that a supercharger at the front of the engine?
  25. redo32
    redo32
    Welcome Red32cpe. I haven't copyrighted the name, it's OK to use it. Congratulations for graduating from VW's, although I see you have a '66. A lot of VW guys here, we just don't talk about them. I bought a '61 for my son's first car.
    The pictures that you posted of cars you want to emulate, show that you have good taste and know what a 32 should look like. The most important thing for a hot rod is stance. The bad news is a change of wheels and tires are not going to do it for your car. The objectionable eyesore is the frame sticking out at the firewall and then disappearing under the back of the body. You could cut the floor and drop the front of the body down to cover the frame and it would look like a channeled car, but then you would have to chop the grille shell and radiator to match the new lower profile. This would likely require custom hood sides. Of course The real remedy is a '32 frame. Might be reasonable cost of $2-3K if you can use all your existing suspension, up to 10-15K for a complete roller. A stock off the shelf repo hood should fit. I won't give you a hard time about your opinion of the 5 spokes, but I graduated in 1967 and American 5 spokes were the most desirable wheels to have in this part of the country. Some guys love the Cragar SS chrome, but I hate them. To each their own.
    19Eddy30 and Stogy like this.
  26. custom_lettering
    custom_lettering
    from Wall, NJ
    If your going with the bias look a likes then your in the 15" and 16" size. Solids or wires. 16s are the way to go with those tires but 18s on 32s are smokin but your tire choice is small.
  27. jnaki
    jnaki
    Hello,
    Nothing other than lowering the front end so the coupe has a nice rake stance is all that it needs. The old painted rims and hubcaps is a nice look, but, does not show a hot rod as a fast build. The traditional look extends to American Racing Mags since they came out in early 1963. It was the "go to" rims for most cars. The only thing holding folks back was the initial cost of the wheels.
    The old statement is BTDT and those cars with painted rims/hubcaps/trim rings all look the same. Only the color is changed to make the coupes/sedans look different. Don't be swayed by the idea that it was the only "traditional" look for old hot rods.
    Keep the American Racing Equipment mags. They were the ultimate rims from the time they were introduced to drag racing, then when they p***ed the street legal build standards, became the go to rims for most hot rods. If they were not so expensive, they would have been on our 1958 Chevy Impala.
    As it ended up for a low cost teenager, we played with the spray painted rims of all colors and decided to finally put on some hubcaps and trim rings to make the final look. Low cost and not as expensive as American Racing Mag Wheels, which were the first choice of rims.
    An old newspaper photo showing the small center hubcaps and trim rings.
    Ziggster and slowmotion like this.
  28. slowmotion
    slowmotion
    I agree with Juni. Drop the nose and call it good! Not a thing un-traditional about those Torque-Thrusts. Although I think those coupes look pretty good with about anything non-billet (partial to chrome reverse myself). Sharp looking coupe ya have there!
    Ziggster and jnaki like this.
  29. squirrel
    looks more like an AC compressor?
    Budget36 likes this.
  30. Red32cpe
    Red32cpe
    Ill snap some more pics here in a bit. No supercharger, just a/c. I have new headers and exhaust for it just haven't had a chance to get it on there.
    dana barlow and Budget36 like this.
