Event Coverage The Edsel adventure is over
Discussion in 'The Hokey Ass Message Board' started by squirrel, Aug 14, 2016.
  1. TrailerTrashToo
    TrailerTrashToo
    Maybe some dingleballs?
    squirrel and Sharpone like this.
  2. squirrel
    I'll leave the t***el fringe alone for now, and let it continue falling apart.
    Got the registration and insurance taken care of this morning. Played with the gas tank, it had about a gallon of slightly bad gas in it, I added a gallon of fresh gas, and drained it, then put in another 4 gallons of fresh gas. I borrowed the old battery from the Volvo. It started up and runs pretty well. Went for a little drive to the gas station. Drives like a dream! Seller said he needed to work on the clutch, as it chattered. I guess letting it sit for several years cured it, at least temporarily, because it works fine for me.
  3. Pontmerc
    Pontmerc
    from Finland
    https://kuttilanautolasi.fi/en/
    All of you who wonder where to get new windshield or anything else gl*** for old car.
    We have this company in finland.
    bchctybob and porkshop like this.
  4. Sharpone
    Sharpone
    Sounds good
    Dan
    porkshop likes this.
  5. DDDenny
    Clutch?
    I thought that thing had an automatic, what it needs is a 430 Lincoln and a four speed!
  6. 57 Fargo
    57 Fargo
    Maybe it needed you back in its life.
    porkshop and Sharpone like this.
  7. squirrel
    The 292 is sweet.
  8. bchctybob
    bchctybob
    How many cars have you sold and bought back? I don’t think I’ve ever done that. I thought about it a couple of times but it never worked out.
    SS327, porkshop and Sharpone like this.
  9. squirrel
    Only a**** family members before.
    y'sguy, bchctybob, porkshop and 4 others like this.
  10. Beanscoot
    Beanscoot
    Nope, won't work. They only make metric windshields.
    squirrel and porkshop like this.
  11. squirrel
    The gl*** is all fine, fortunately.
  12. sidevalve8ba
    sidevalve8ba
  13. squirrel
    Oh, kind of, but not quite. The "new" hood on mine is the same color as that one, but the rest of it is mostly different. They're both 4 door Rangers with the 292, which was the most common 59 Edsel made.
    compare the data tags, nothing matches.
    y'sguy, bchctybob, Sharpone and 3 others like this.
  14. squirrel
    Anyways...the Edsel had been running poorly since I got it back. The carb was leaking, so I got a carb kit and installed it last fall, but it still ran bad...in fact, it got worse. I ended up getting involved with other stuff for a while, and finally decided to look at the Edsel again today.
    I did a little troubleshooting and test driving, and it sure acted like the power valve, or something similar, was leaking. So I pulled off the carb, and sure enough the power valve compartment was filled with gas. Turns out the gasket that came in the carb kit was a bit too thin, so it would bottom out before compressing it, resulting in a little fuel leak ,just enough to make it totally undrivable.
    Working better now.
    61Cruiser, Lil 32, saltflats and 17 others like this.
  15. Pontmerc
    Pontmerc
    from Finland
    Good thing those old autolites is, they take holley jets till 63 model year. Many mine has really like few number bigger jets.
    squirrel, Sharpone and bchctybob like this.
  16. T. Turtle
    T. Turtle
    My impression is that many of the gaskets you get with the kits nowadays deteriorate very quickly with modern fuel, I found some viton O-rings that were the right size and are etahnol-safe and used that instead. Seems to work so far...
    y'sguy, bchctybob, Deutscher and 2 others like this.
  17. squirrel
    I've found that when stuff deteriorates with modern fuel, it's usually because I let it sit for a while...
    but a paper gasket is still a paper gasket, if it's the right size, it will last OK and work well.
  18. T. Turtle
    T. Turtle
    Did not work for me but maybe it's the particular Chinesium it was made from;)
  19. Sharpone
    Sharpone
    What I do if I’m not using Indian Head or Gasket cinch is I lightly coat the paper gasket with a light grease, seems to help the gasket from becoming brittle.
    Dan
    Deutscher likes this.
  20. RodStRace
    RodStRace
    Way back in tech school, the engine cl*** instructor had all the students use white grease on both sides of gaskets except head gaskets. Made teardown to fix issues and reuse gaskets a lot easier! :D
    I've tried the usual, chapstick on Holley bowl gaskets, etc. As Jim says regular use helps, but modern fuels are not designed for old seals and if they aren't as designed (thin) it's never going to work right.
  21. T. Turtle
    T. Turtle
    X2. But the ***umption is that whatever fluid the gasket is supposed to seal would not dissolve the grease, and that is why I went to a completely different material for the PV gasket.
    Sharpone likes this.
  22. Beanscoot
    Beanscoot
    But it wouldn't matter if the power valve gasket leaked just a tiny bit, would it?
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Vacuum would just pull the tiny bit of fuel away is all.
  24. squirrel
    if it leaks just a tiny bit, vacuum pulls the fuel into the engine, and it runs rich.
    You have to define "tiny".
    bchctybob, sidevalve8ba and Sharpone like this.
  25. Beanscoot
    Beanscoot
    Tiny meaning what could seep through a paper gasket properly compressed but with no sealer.
    Like less than a drop a minute, for instance.
    I guess I should have said "seep", not "leak".
  26. squirrel
    mine was a leak, not a seep :)
    bchctybob and Sharpone like this.
  27. squirrel
    Here it is the end of July, and the 10th Anniversary Hell On Wheels rally is just a couple weeks away!
    and my Edsel won't make it more than a mile down the road. Hmmm....
    When I got the car, the fuel tank was missing, and they're kind of hard to find. So I adapted an early Chevelle tank, it's about the right size and shape, filler neck in the right place, etc. The Chevy sender is backwards from the Ford design, so I put new E and F marks on the gauge, and it's been working fine.
    But I think that during it's long sleep at the home of the guy I sold it to and bought it back from, the gas went bad, and there's **** in the tank. It worked ok for a while, then recently it's not been reliable. But it has almost a full tank now, and since I can't get fuel to run out of the sending unit, it's kind of hard to drop the tank safely to work on it. Oh...it's close...the sender is in front instead of on top, so if it were just a tad lower, I could maybe pull it out, but not quite. Maybe I'll siphon some out of the filler neck.
    dwollam, ClarkH, HemiDeuce and 6 others like this.
  28. RodStRace
    RodStRace
    You just need a (insert state with low standard of living) credit card.
    I'm sure you have a 12 volt battery, some jumper leads, some fuel hose and an electric fuel pump. ;)
  29. squirrel
    yeah, lots of work to do all that, but I'll probably end up going that route.
    dwollam, HemiDeuce, porkshop and 2 others like this.
  30. squirrel
    We always called an Oklahoma credit card.
    y'sguy, dwollam, HemiDeuce and 8 others like this.
