Projects Dirt Cheap Dart
Discussion in 'The Hokey Ass Message Board' started by Sharpone, Jan 18, 2026.
  1. oldiron 440
    oldiron 440
    Your correct about needing to cut 2 7/8” off the long end, I’m using the LD that came with the 8.8 but I a put carbon fiber clutch kit in it, I also replaced the crush sleeve with a shim kit from Quick Performance in Ames’s Ia. The cool thing about the 8.8 is that you can add modifications for the power increases you make to your car. With the 31 spline axles it will handle all the power and traction you can apply to it.
    chryslerfan55 and Sharpone like this.
  2. Greg Rogers
    Greg Rogers
    Shifter looks nice.
  3. Sharpone
    Sharpone
    Thanks
  4. oldiron 440
    oldiron 440
    Regarding the C-clip when I narrowed my 8.8 I had 9” ends put on each side then used 9” axle’s because at the time a c- clip eliminator was not available but I’ve heard there’s one now.
  5. gene-koning
    gene-koning
    Lots of Mopar rear axles used a "C" clip to hold the axle in place, the 7.25, the 8.25, and the 9.25. Mopar axles with "C" clips didn't cause a problem very often.
  6. oldiron 440
    oldiron 440
    I’ve seen a few Abody 8 3/4 have the wheel studs get sheered off usually at the drop of the clutch. Can’t say I’ve seen a 8.25 spit an axle but I’ve seen plenty of GMs do it.
    chryslerfan55, porkshop and Sharpone like this.
  7. Sharpone
    Sharpone
    Yikes
    chryslerfan55 and porkshop like this.
  8. oldiron 440
    oldiron 440
    Doesn’t the older Abody use a 7/16 stud and maybe sheer isn’t the correct word but the studs get broken off at the axle.
  9. Sharpone
    Sharpone
    Yes they are 7/16
  10. RodStRace
    RodStRace
    I'd guess half that is due to the rough treatment they got. Very few techs were torquing when new, you had confusion on left hand threads, and Dropping the clutch usually meant spirited driving, which usually meant running a wider tire than were out on the street when they were designed and built.
    Smaller bolt pattern (PCD) and smaller studs were carry overs from the A-Body design.
  11. Sharpone
    Sharpone
    I’ll bet a few of the LH studs were over torqued
    Dan
  12. RodStRace
    RodStRace
    I bet all of them were!
    brad2v, chryslerfan55 and Sharpone like this.
  13. Sharpone
    Sharpone
    chryslerfan55, porkshop and RodStRace like this.
  14. gene-koning
    gene-koning
    Interesting! I worked on these things for lots of years, I have never used a torque wrench to tighten lug nuts. We always winged them in with the impact gun! I never beat on them with the impact. My 1st boss always said you run all the lugs in until the wheel is in place, then you tighten the lugs in the star pattern and stop with the impact when the socket first quits turning with each lug. Did all the nuts on that wheel that way, then hit them all one or two raps with the impact going around the circle afterwards. I've broken a few studs removing them (turning them the correct direction), because they had been over torqued when installed, but I've never broken a stud tightening them.
    You should have seen the cross bar we used to hand tighten the 1/2" studs on the dirt track wheels! That bar was a 24" side to side reach, with an impact socket welded to the end, tightened as tight as that 200lbs guy could twist the bar! Every lug, on every wheel, before every trip onto the track, all season long. I don't ever remember changing the studs, but I do remember changing the rear axles every couple of years because they were twisting... I guarantee those studs saw way more then 90 ft-lbs of torque!
    If you take the car into a service center to get tires or anything that involves removing and reinstalling the tires these days, they will torque the wheels to 90 ft-lbs. "All of the lug nuts get torqued to 90 ft-lbs, company policy!" I was told.
  15. RodStRace
    RodStRace
    Yep, all the shops I worked at used air impacts and the common thing was to run them in, then hit once more with a couple or three uggas. Trucks got more, imports maybe less. Most impacts were usually turned all the way up after having something not come loose, but that wasn't universal. Obviously, these would be all over in amount of force.
    Couple that with the lefties, it's amazing.
    I looked up Std bolt specs in the pocket ref. All dry threads. 7/16 grade 5 is 54, grade 6 is 65, grade 8 is 79.
    chryslerfan55, Sharpone and porkshop like this.
  16. I love these lo-buck builds...
  17. Sharpone
    Sharpone
    Yes they are fun, I’ve drove several thousand miles already. Drive and work on as I go. Make sure everything is safe and functional. Once I get the interior and paint and body done it should look presentable - no where near show quality but good enough.
    I have an OT one in the garage that I completely tore down and am doing everything to the best of my ability. I’ve been working on it for a few years and am 1 to 2 years from finishing. Oh and I’ll have more $$$s in it than it’s worth ha ha
    Dan
    Deutscher, Squablow, brad2v and 6 others like this.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    Every Monday I ride my 72 Schwinn 10 speed out to Mayer Mn (30 mile round trip) to visit my pals at goose lake auto parts (I worked there part time back in the 80's) and then on to have lunch with the guys in town from the body shop. Anyhow there are a bunch of vintage cars still in the yard at Goose Lake and Larry the owner is a "mopar" guy so I asked if there were any 8 3/4 rear ends for your car today while I was there, They looked it up in Hollanders and there was nothing off on file but they fit 66-69 Valiant, Dart and Barracuda. I did go out and look under a couple of Barracudas, one with no rear and the other had the same one that your car does. It did show however that a yard in Idaho has one for 295 bucks complete. Seems like an ok deal but the shipping might be a killer
  19. Low buck build but a lot of talent!:)
  20. Sharpone
    Sharpone
    Thanks Mark, most were 7-1/4” my buddy has two wrecked Barracuda’s both with 7-1/4”s. The one in Idaho is a good deal if it’s for an A Body. Maybe I should call them. It probably has the the 5 on 4 bolt pattern. Wonder if it’s a sure grip. Wheels are spinning now.
    Road Trip!
    Dan
    Next time I’m up your way I’m going to have to stop by Goose Lake, they seem like good guys, I called them looking for a points distributor, they didn’t have one.
  21. Sharpone
    Sharpone
    Thanks Bill
    I sure have you fooled lol
    Dan
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    a few on car-part.com too
    chryslerfan55, Ziggster and Sharpone like this.
  23. No smoke&mirrors Dan,just good old fashioned know how bud!:)
    chryslerfan55, Sharpone and Ziggster like this.
  24. Sharpone
    Sharpone
    I didn’t see any on car-part, my search was for 63 - 72 dart and cuda, also 63-66 dart and cuda.
    Dan
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    i just found 3 for a 66 dart
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    ****py computer screen pic
  27. Sharpone
    Sharpone
    Thanks Mark I did find it, I was searching wrong
    Dan
    Moriarity likes this.
  28. Sharpone
    Sharpone
    Thanks for the show of confidence Bill
    Dan
  29. gene-koning
    gene-koning
    For what ever its worth, an 8 3/4 from a 66-70 B body car is only 3/4" wider at the wheel mounting flange to wheel mounting flange that an A body 8 3/4. The older then 66 B body cars had the tapered rear axles, and the original center sections had a flange at the U joint for the trunion bearing, you don't want either of those. The B body rear end comes with the 5 bolt on a 4.5 bolt circle as well. The axle housing pins for the leaf spring mounting on the B body is only a 1/2' wider then the pins on the A body, usually a guy can force the A body springs far enough apart to work (not that I would ever admit to doing such things, only that I've seen it work for a long time on a street car).
    There were millions more B body 8 3/4s then there were A body 8 3/4s, but a lot of them came with a 276 open rear gear center section. The center sections from 1966 to 1974 with the gears on them can be swapped as units into any 8 3/4 housing (that includes truck and van 8 3/4s, but the truck & van centers don't have the bolt holes for the pinion snubber). Some people will try to tell you the early 8 3/4 centers are weaker due to smaller pinion shafts, on a street car, that won't matter. If you intend to do the Caltracs and slicks, on a traction added strip, maybe there will be a problem, but not with normal the street equipment. Normal rear gears for 8 3/4 rears are : 2.76 (most), 2.91 (not many), 3.23 (many performance era cars, light trucks, & vans, getting very hard to come by), 3:55 ( special order cars, or many light duty trucks, & vans) and 3.91 (very rare performance cars), all were production gears.
    Deutscher, brad2v, Sharpone and 2 others like this.
  30. RodStRace
    RodStRace
    Also, there is a block between the axles in the center section. Do not lose!
    The adjustable parts on the right side are not as easy to source, so don't tear them up or lose them, either.
    I don't think there are a half dozen different service parts like the 9 inch, but try to keep track of what the donor is. The different strength housings also tend to have different yokes. You need to pay attention to this, they are different splines and u-joint sizes.
    It's Sur-Grip in Mopar circles, so don't say posi unless you want to be Joe Dirt. :confused:
    Deutscher, brad2v and Sharpone like this.
