Cutting firewall on a '32 for channeling, where??
Discussion in 'The Hokey Ass Message Board' started by Ken Carvalho, Jun 17, 2012.
  1. Ken Carvalho
    Ken Carvalho
    Looking for suggestions, ideas, and pictures for the best and least hacking up of the firewall to channel my '32 Ford sedan about 3". I thought about drilling out the rivits holding the feet on and making new feet 3" shorter and putting in place of the originals. Open to ANY other suggestions, and any close up pictures would be great. Thanks
  2. 32coupedeville
    32coupedeville
    from cincy
    i think just taking it off the bottom is the best. take the legs off and trim the firewall where you need . then put the legs back on.
  3. Hackerbilt
    Hackerbilt
    I've never done it so take it with a grain of salt...but I think I would cut it at the top of the toeboard and leave the whole bottom area intact including the feet.
    You would have a straight, clean slice to deal with for much less fabrication...in MY opinion anyway.
  4. Ken Carvalho
    Ken Carvalho
    Couple of ideas there, thanks, anybody else??
  5. mgtstumpy
    mgtstumpy
    I would use a strait edge on either side of the ch***is and scribe vertical lines on firewall. Mark it with tape and determine how much you are channeling it. Measure up that distance from the ch***is and scribe a horizontal line, that is where the body will sit when channeled. Now cut that section out, move it up to where the horizontal line is scribed and voila, done. Now weld section back in. You should have 2 x rectangular sections of metal that were removed from firewall.
  6. nanos1932
    nanos1932
    I haven't done one before but this is how I would tackle it. In my opinion the feet are the best part of the firewall and I wouldn't want to make them short and stumpy...
  7. Hackerbilt
    Hackerbilt
    Won't that put you in the angled part of the toeboard?
    I'm saying do the same basic thing but make the horizontal cut just above the toeboard bend.
    Your vertical cuts are a bit longer...but everything will basicly line up and the toeboard remains stock in size and shape.
    Must be 50 variations on how to do it I suppose.....:cool::D
  8. SUPERSTOCKGALAXIE
    SUPERSTOCKGALAXIE
    from ASHLAND OH
    I just took the feet off,moved them up 3" and plug welded them back on on my pickup,looks factory.clearanced around bell housing and that's all it took.simple,clean,and factory looking.
  9. 31whitey
    31whitey
    You can section it... 3 out the middle, long ways, then drop it and weld the top and bottom back together.
    Or
    You can remove the band that runs along the top and sides, cut 3 inches off the top, leaving the toe part and legs stock., replace the band.
  10. hammeredt
    hammeredt
    I found this surfing for inspiration for my own channeled deuce project. I think this is JimmyB's photo (came from another sight). I hope you don't mind Jimmy. If you look close you can see the cuts made. This was done to accomodate a 6" (ish) channel.
  11. SUPERSTOCKGALAXIE
    SUPERSTOCKGALAXIE
    from ASHLAND OH
    I dont think any of these ideas are bad or wrong,but I think some of u guys are looking too deep into this,I did my truck exactly 3",it's a partial channel over the frame and I didn't have to section it,or cut the toe board area all up,just trimmed them back a little,but not enough to give any headaches,and it's way less work than sectioning.3" isn't alot,on a channel,plus you don't wanna ruin the lines of a deuce firewall by sectioning it.i can email some pics if ya like.let me know.
  12. Lets revive this thread and show how you cut your firewall on your channeled '32 Ford.
    This is one that Father Ray did not long ago.
    I am curious how others have done it?
    Thanks eh!
    -Shiny
    19Eddy30 likes this.
  13. rod1
    rod1
    Beautimous!
    29EHV8 likes this.
  14. ronzmtrwrx
    ronzmtrwrx
    Very nicely done.
  15. TCTND
    TCTND
    Don't know where it is now, but years ago I had one of the mid 50's small format mags with an article " How to channel your car with an axe". They weren't kidding (better wear steel toed boots). If anyone can dig that up it would be fun to see.
  16. Olcars
    Olcars
    Not sure if this is clear but I re-shaped the stock feet and moved them up. Still looks authentic to me
  17. 19Eddy30
    19Eddy30
    from VA
    @Olcars
    What shown is how I would do
    with cowl leg & feet
    29EHV8 and Nailhead Jason like this.
