Featured Hot Rods 4 Post vs 2 Post
Discussion in 'The Hokey Ass Message Board' started by panhead_pete, Jul 24, 2026.
  1. RICH B
    RICH B
    Used a single post lift down at the gas station; kinda like a 4 post with the channels the tires rode in; can't remember what we did to jack up the car for tire or brake work; been too long. Never knew how pushing the air valve on the wall turned into a big shiny ram coming out of the floor; but it always worked good. The owner, John used to say he wished he had a "modern" 2 post like in @41 GMC K-18 's post.
  2. Budget36
    Budget36
    Those are the only ones I’ve used in service stations. Large cylinder and 4 arms you could position and slide in/out some.
    The ones I used and a little latch on the floor you’d flip over and lock the cylinder from coming down.
    Thinking back on it, not sure how safe that was…
    alanp561, leon bee, Driver50x and 2 others like this.
  3. saltflats
    saltflats
    from Missouri
    I worked under those old in ground two post lifts at an old Midas shop in Kansas City when going to school. That thing had more trick than a monkey on 60 foot of g**** vine.
    We also had a jack they called a bay lift, you would lift the rear of the car by the rear end axle tubs till it was 4 plus feet off the ground then set some jack stands under the frame up front. When you let it down it would pivot on the jack stands and set it on a lock on the jack. With that one action you would have all four wheels off the ground. Wouldn't mine having one of those.
  4. saltflats
    saltflats
    from Missouri
    51 mercules, RICH B, leon bee and 5 others like this.
  6. 51504bat
    51504bat
    I want to be 60 years younger so I could take shop cl***es in the new building.
  7. panhead_pete
    panhead_pete
    For those of you running a 4 post how much space have you got either side of the lift? Any thoughts on a minimum? Thanks!
  8. BJR
    BJR
    3 foot minimum.
  9. Adriatic Machine
    Adriatic Machine
    ^^^ 3 feet. You need to have enough space to fall down :eek:
    seb fontana and alanp561 like this.
  10. Glenn S
    Glenn S
    You only need enough room to be able to squeeze past on one side and walk past with your elbows out on the other side. Remember to allow for growth as you get older. I have a 2 post and a 4 post. Work on the 2 post and store on the 4 post.
  11. saltflats
    saltflats
    from Missouri
    I would want it that you could leave the doors open on the car and still room to walk around without having to close the door if I was using for working on cars.
  12. RodStRace
    RodStRace
    Open the door of the widest thing you plan to lift enough to get in and out. Measure how much it is open away from the widest part of the body. Check where the thing sits on the hoist. Figure half the width and the extra so you don't have to climb in and out. That is your bare minimum. Also, if it's up close to the wall but the garage door isn't aligned there, you do not want to have to angle onto it. Your width and ceiling height may enter into the placement, too.
    Glenn S and X-cpe like this.
  13. Mr48chev
    Three feet between the rail and the wall Is comfortable if you are going to work on the car with the wheels off doing brake jobs or service work. My stall in a dealership I worked in for several years was against the end wall with the front end pit between it and the next stall over with five total stalls and a double overhead door on that side of the shop.I had an air over hydraulic single post hoist but had plenty of room to work on the right hand front suspension on big Pontiacs.
    1933_willys_77 and saltflats like this.
  14. At least enough room to slide out an axle
    1oldtimer, ffr1222k, BJR and 3 others like this.
  15. panhead_pete
    panhead_pete
    Thanks fellas much appreciated, thats kind of what I was thinking, just great to get it confirmed.
  16. 40FORDPU
    40FORDPU
    A little late to the party.
    I struggled with which way to go 2 post or 4 post, in the end I opted out for a 4 post, with a sliding jack.
    I went with a 9500 lb capacity, and the highest lift (I'm 6' 6").
    Now I'm wondering how I ever did without one.
    I installed it myself, once understanding the logic, it was just a matter of brute strength, with the help of my floor jack, and engine hoist.
    warbird1, ffr1222k, Budget36 and 2 others like this.
  17. hrm2k
    hrm2k
    I have a 4 post in my garage. 22 foot ceiling works real well with the lift. It’s used primarily for storage which is something I need to change .
    saltflats and panhead_pete like this.
  18. krylon32
    krylon32
    from Nebraska
    4 post tall/narrow Bend Pak in my shop. 12 ft 6 inch ceiling. Best shop money I spent in a while. At 81 my getting down on my knees and crawling or laying on the floor days are done. I bought mine about 8 years ago delivered and installed $5k. Installers came 175 miles one way. I'm happy.
  19. mohr hp
    mohr hp
    from Georgia
    2 post for me! Probably extending my working years a bunch, no going back. I sometimes pine for a second one!
    leon bee, Budget36 and ffr1222k like this.
  20. panhead_pete
    panhead_pete
    Thats actually the lift Im looking at Gary. Easy to source here in Japan too :)
    1oldtimer and Budget36 like this.
  21. Budget36
    Budget36
    Can a 2 post lift be set up with 9 feet of access between the posts?
    Thing is I need to put one outside in the driveway. I’d need, on occasion, to get an 8 foot wide truck or trailer through it.
    Ofcourse that’s ***uming the lift arms move out to be in line/equidistance with the posts.
    I’ve never seen a 2 post in person.
  22. panhead_pete
    panhead_pete
    If you jump on the benpack website they have a lot of measurements.
    seb fontana and Budget36 like this.
  23. @Budget36 , you could always uninstall one post to give you room to get by. My buddy used to take his posts down, in the garage to do other types of work, and re-install when needed. Hydraulic hoses to the lift cylinders had quick-connects, so that was a cinch to dismantle. Power unit for hydraulics was portable, lift was from Costco.
    Budget36 likes this.
  24. At work we had less then 2 feet at the posts, the 2 post lift was about 1.5 foot. It made it ****y to walk around with wheels in you're arms or anything big.
    I'm at that point now and I'm a couple of decades younger. Knees are pretty close to shots and my back isn't too far behind. No need to beat yourself up anymore if you don't have to.
    At work with the 2 post we would us it on F-350/F-450s and those are over 8ft with the mirrors (according to google). I could nose in a T880 about 2 ft. Like said above look at the website, there are different models and different widths. Just get a good brand (Rotary, Bendpak, Mohawk....) because there has to a better to go out then getting squashed by a ****ty lift.
  25. Budget36
    Budget36
    So what kind of man power is needed to move a post?
    I can use my forklift to set it up, but where it resides is near an act of congress to get it out and in, etc.
  26. Budget36
    Budget36
    I agree, two years away from retirement, I’d like to collect my SS benefits;)
  27. I'll try and find what brand it was, it had built in roller/wheels at side of column bottom, so you would tip it slightly, and walk it away.
    Think it was MaxJax 2 post portable by Bendpack.
  28. Sporty45
    Sporty45
    I've made my decision to get a 2 post. My only problem now is getting concrete guys to call me back with a quote. I've only gotten 1 quote out of 7 places I've reached out to :mad: I've been doing the site work, and have it close to ready for gravel to be brought in, then do the forms and rebar. I'm hoping to have this done before it gets too cold here.
  29. seb fontana
    seb fontana
    from ct
    Greg Smith Equipment
    I got a 4 post from the above 19 years ago, very happy with cost/***embly/adjusting for level.
  30. BJR
    BJR
    Every time I drive a car onto my 4 post I thank god that I don't have to crawl on the ground to set those damn arms like I did at work for a bunch of years. But I have one knee replaced and am 76 years old.
