How do you "coil" fuel lines?
Discussion in 'The Hokey Ass Message Board' started by ckdesigns, Mar 15, 2006.
  1. stealthcruiser
    stealthcruiser
    I've used a piece of small cable,(aircraft cable),inside of tubing before to help control kinking,although not in an aircraft application.
    Find something a little smaller than the I.D.,insert in your tubing,lube well,and bend around an appropriate sized mandrel for your desired coil or bend.
    Remove the cable afterwards,(you did leave a tail hanging out to grab it by,didn't you?),and you're set.
  2. kustomolds
    kustomolds
    I didn't read all the replies, so I hope I don't repeat what others have said.
    I was frenching some antennas into my Olds, and had an idea about tacking on a coil of brake line to top off the tubes for the antennas. Well, I just took the 1 1/2 tubing I was using and started to "Roll" the line around it, went around a few times and slid the "coil" off the tube. Quick, dirty and looked good......hope this helps
  3. I've had SOME luck wrapping them around a spray can/aerosol can
  4. HeyMang
    HeyMang
    from So Cal
    To Straighten- uncoil the coil as much as possible by hand, clamp one end to a solid object, the other end to your tractor and floor it.
    A natural gas pipeline is not a solid object. :D
  5. hows that tub coming along Chris??
  6. ckdesigns
    ckdesigns
    from Ogden,Utah
    Hopefully there will be an update within the next couple of weeks:)
  7. cbndrhsr
    cbndrhsr
    from Layton, UT
    IN '65 I bolted a coffee can to my inner fender well on my 442 then had my fuel line coiled in a smaller dia. and had it running into and out of the coffee can that i had packed with ice. Idea was to keep the fuel cool before it went into the carb. Cooler fuel atomized better,so I was told by my neighbor, who was an old stock car racer transplant. Don't know how much it helped but it sure looked cool
  8. rustfarmer
    rustfarmer
    from Hawaii
    The ends of a barbell set with the screw in plate holders work well for making tight coils. It gives you a nice groove to follow when you are coiling the line.
