Technical Help! Caster problem on '63 Thunderbird
Discussion in 'The Hokey Ass Message Board' started by Aaron65, Jun 27, 2019.
  1. Aaron65
    Aaron65
    from Michigan
    I just changed ball joints and lower bushings on my '63 T-Bird. Before the rebuild, I was only able to get 2* negative caster out of the p***enger side. Afterward, I can only get 4* negative, probably because the new bushing is tight so I can't use the slop to get more caster. The driver's side is fine...I can adjust anywhere from 1.5* negative to 1* positive or so.
    Any ideas? I did some quick measurements underneath, and the frame brackets look like they're in the right spots. Nothing else is obviously wrong to me. I'm stumped, and usually I can work my way through problems like this. I'd hate to just start throwing parts at it.
  2. Bird man
    Bird man
    from Milwaukee
    Perhaps a typo? 4 deg is plenty.
  3. BJR
    BJR
    Some cars get frame sag which usually affects camber, but maybe it has been in an accident and not straightened correctly? And yes I know it's a unibody.
  4. lostone
    lostone
    from kansas
    Measure from somewhere on the frame rail like under the seat area, there's usually holes in the frame rails in this area, and measure to the center of each lower ball joint grease zerk.
    That much caster difference I'm betting a lower arm back, it would be on the neg caster side. Check lower arms for bends too.
    Atwater Mike likes this.
  5. Atwater Mike
    Atwater Mike
    These days, one could take this 'Bird to a FRONT END SHOP, (says so on the sign!) and the 'tech' would no more take a measurement (they call that a 'hard measurement', LOL) so they just don't bother. "Hang the mirrors, look at the screen..."
    To detect bent members, all it takes is getting under, finding good factory holes, (they were 'locaters' at the factory) and do exactly as @lostone outlined.
    Likewise, check uppers as well.
    'Hard measurements' made easy...
  6. Aaron65
    Aaron65
    from Michigan
    Thanks guys...I actually called up a local frame/suspension shop that's been around a while and talked to the guy who answered the phone. They said they'd check out the frame measurements for me...I actually took it out to storage today and swapped another car because I was a little sick of looking at it. I find that when I get frustrated, it's best to take a little break before something breaks. Once I get it figured out, I'll post what I come up with.
  7. Mr48chev
    2019-06-27.png This chart is saying that a 63 bird has negative 3/4 to negative 2-1/4 caster.
  8. Mr48chev
    On thing comes to mind and that is that mounting point for the front strut on that side might be pushed back just enough to cause the excess negative caster by pushing the lower control arm back a bit extra. A hard bump on a high curb could cause that. .
  9. Aaron65
    Aaron65
    from Michigan
    I was a little surprised at how much negative caster these ran from the factory...
  10. bobss396
    bobss396
    They get whacked on those parking lot stops often. I saw some with ******ed threads on the 'Birds and other cars. I would see how it drives before doing anything too funky. Drive on a variety of roads to see if it has a pull first. The caster adjustment on those has an impact on the toe as well, make sure the front end guy knows that.
  11. Aaron65
    Aaron65
    from Michigan
    It is definitely nervous on the road (has been since I bought it last October). I think it's a combination of things...first, the ball joints and lower bushings were just worn out. Now, it's got a lot of cross caster, so it pulls to the right. I normally set up my own alignments because I have 7 old cars and I don't mind doing it, but if the frame guy can figure out what's bent and can straighten it, I'll let him align it.
    I was in a little bit of a red haze yesterday, but I called my dad over and we did a quick measurement of the wheelbase between hubs. One of the sides was .5 inches longer, and I can't remember which one it was. I actually think it was the side with the bad caster.
  12. bobss396
    bobss396
    The car will pull towards the side with the leading upper ball joint. Meaning the most negative caster angle. Which fits your pull to the right and that -2 to -4 angle.
  13. Aaron65
    Aaron65
    from Michigan
    I took the car in to the frame/alignment shop today, and he said that the major points measure out OK. The upper ball joint, however, is obviously forward of where it should be. He told me I could shim it out in front if I used a longer upper control arm attachment bolt, which was an option I was considering, but judging by the way things look, I'm wondering if someone used a driver's side control arm on the p***enger side. They look almost identical, but apparently they're different (Thanks again Jim (aka Squirrel), for looking in the Hollander manual).
    Either way, I've ordered a used control arm from a salvage yard and a new upper shaft. If that doesn't fix it, I'll shim it out. More to come as the parts come in.
    bobss396 likes this.
  14. lostone
    lostone
    from kansas
    Probably been hit in that wheel at sometime in its life, mustangs were bad about it and funny so is late model Chevy pick ups of the upper arm moving in and bending the tower on mustangs and frame rails on Chevy trucks.
  15. bobss396
    bobss396
    Good call on the wrong upper arm. I always mark them when I take them off the car just to be safe. A couple of dots with a hammer and punch is what I use. I only mark the right side parts.
  16. Aaron65
    Aaron65
    from Michigan
    I think I've got this problem under control...A lot of little issues seemed to stack up. First, someone installed the upper control arm shaft bushings incorrectly; the shaft wasn't centered. That caused the control arm to sit too far forward. The driver's side shaft is not centered either, but it's in the positive direction, so I left that one. Since I wanted to get as close to 0* caster as I could on both wheels (remember that maximum specs in the manual is .75* negative!!!), I installed a 1/8 shim behind the front bolt on the upper control arm, and I used a turnbuckle to pull the lower control arms as far forward as I could within the range of adjustability of the lower strut rods.
    So now, it's set up with 0.2* negative caster on the right front, and 0.2* positive on the left front. The camber on both wheels is 0.2* negative, and I'm running about 3/32 toe-in. It was a lot of work and thought to get it together, but at least I can check that off the list for now. On to the next item on the list...
    squirrel likes this.
  17. Mr48chev
    Cool beans, I do believe you have a handle on it. It's been so long since I did front end work every day I forgot about those shafts that have to go back a certain way or everything is thrown off. Most control arms are so obvious as to what side they go to that I missed that one too.
  18. bobss396
    bobss396
    Very important to get the shaft and arm centered! Ford made a tool for this, I never saw or used one in all the bushings I had changed. It will definitely have an impact on the caster if it is far off. I would clean up the shaft and arm, scribe a center line so I could get it as close as possible to where it was.
    Not that easy since the bushings have a co**** inner thread and fine outer, where it attaches to the arm. The big trick is not to strip the find thread out of the arm.
  19. ThunderbirdDude
    ThunderbirdDude
    Hi Aaron,
    a buddy of mine was here today with his 64 T-Bird. Beautiful car, but I think its undriveable. I have a 68 Coronet that drives like a charm, but the T-Bird is a death trap. Would you drive 80mph with this thing when it is in good condition?
    It cought my eye that it obviously has negative caster and I am stunned that this is normal. Did you compare the upper control arms once? Are they really different? because my first guess was someone changed then left to right.
  20. justpassinthru
    justpassinthru
    I have been aligning vintage cars for more than 40 years.
    I would like to know how you can visually see where the caster is?
    Position of the wheel/tire in the wheel well (forward or rearward) is not a good indicator of approximate caster. Many factors such as frame, fenders, position of the body on the frame can all change the wheel/tire position in the wheelwell.
    Camber on the other hand can roughly be seen visually.
    Inquiring minds want to know?
    Bill
    lostone likes this.
  21. lostone
    lostone
    from kansas
    Same here, over 40 yrs and still doing it to this day and I've never been able to eye Caster.
    I can compare tire to wheel well but that's worthless when it comes to caster.
    Unless you mean camber, that's a whole different dog to hunt....
  22. justpassinthru
    justpassinthru
    Think you have the caster backwards from L to R
    Generally we put 1/2* to 1* more positive caster in the right side, than the left side, to take account for the crown in the majority of roads.
    That way on most roads the car won't pull or want to steer to the curb.
    Bias ply tires seem more happy with more positive caster in the right wheel than radials.
    Bill
  23. lostone
    lostone
    from kansas
    BTW to answer your other question, yes negative Caster was the norm.
    Negative caster makes turning the wheels at slow speed or stopped easier. Start adding caster and it gets harder to turn. Also remember power steering either wasn't an option on some cars or people couldn't afford to buy all the "fancy" options when they bought a new car and power steering didn't become standard equipment in most cars until 1970, that's when many manufacturers redesigned front end geometry to make cars handle better...
  24. justpassinthru
    justpassinthru
    Just realized, 6 year old thread.
    Nevermind.
    Bill
