Technical Bird Poop on White Paint
Discussion in 'The Hokey Ass Message Board' started by 5window, Aug 5, 2026.
  1. 5window
    5window
    Roof poop.jpg I've got several stains from bird droppings on a 61 year old white painted roof. Turtle Car Wash and Oxyclean didn't touch the deep stain. Any suggestions for stain removal? Thanks.
  2. Wanderlust
    Wanderlust
    Time for a cut polish
  3. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Bird Poop is acidic so it may have burned into the paint.
    Try Wax and grease remover to soften it up and see if that helps.
    Then a cut and polish try that.
    If not and still burnt in the paint, lightly take 1200 or 1500 grit wet sandpaper ( sand very lightly a mil or 2 mil at most) removing the remaining poop.
    Make sure not to sand too much down to the primer / then light finish fluff polish.
    Wobbly likes this.
  4. Doublepumper
    Doublepumper
    from OR-WA, USA
    I've never used them, but you might try a Mr. Clean Magic Eraser sponge. I've been told they work well for removing stains like this. Good luck!
  5. Bandit Billy
    Bandit Billy
    Roofs are easy. Bright base coat, metal flake, candies, pinstriping and a liberal amount of clear and it should cover that doo doo.
    Like said above, the avian excretion may have etched the paint. a 65-year-old paint job likely doesn't have enough depth remaining for a cut and polish deep enough to remove the stain. A rood repaint is likely in order. How do you feel about lace?
  6. ClayMart
    ClayMart
    Maybe try The Pink Stuff.
    Haven't used it myself but claims to clean safely and remove stains from most surfaces. They show it cleaning white shoes. Maybe it will even clean white wall tires.
    https://www.thepinkstuff.com/pages/all-products
    Maybe even try one of the kitchen and bath stain removers, though they might be a little more aggressive on paint.
    Also Arm & Hammer Super Washing Soda makes a surprisingly potent cleaner. But read up on the mixing and usage instructions before deciding. Not for use on aluminum.
    https://www.armandhammer.com/en/articles/super-washing-soda-laundry
  7. 5window
    5window
    Update: Magic Eraser did a pretty good job. I may have to wax the whole roof to get an even sheen. There's a caution not to use it on "vehicle bodies" but I figured that was newer paint methods not 50 year old enamel.
    Doublepumper likes this.
