Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Paul
    Paul
    Editor
    '50 Mercury centers get "slightly" narrower rims
  2. bjinx
    bjinx
    I have an O/T ‘70 and used a 3”spring and 1” lowering block to get 4” drop. For a little softer ride. You might consider adding lowering blocks if it doesn’t settle.
  3. DDDenny
    That right there is some nice work!
  4. 66GMC GUY
    66GMC GUY
    Youre awefully close to frame notch territory with that drop. Going to look good though!
  5. hrm2k
    hrm2k
    Always nice to hear a compliment. Thank you !!!!
    Today I added the polished pieces to get from the headers to the turbos. Next trip to the garage I'm mounting up turbos
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
  7. lo c dan
    lo c dan
    Thank you sir
  8. We ain’t skeered
    Changed out front springs to cut 3/4 ton
    I like em better so far
  9. milwscruffy
    milwscruffy
    I'd drive it !
  10. hrm2k
    hrm2k
    @lo c dan , really nicely laid out insert .
    Polished or plain or painted ?
    inquiring minds want to know
  11. deathrowdave
    deathrowdave
    from NKy
    Thank you to every one for the tips on the tube bending . I need lots at this time . TIG welded brackets for a Bud , hanging barn doors yesterday , raining here for a couple days now .
  12. lo c dan
    lo c dan
    Think it's goin to stay plain. .should be easier to maintain the finish, I plan on driving the **** out of it.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Put a whole new meaning to “ keep the shiny side up” :)
    Okie Pete, enloe, hrm2k and 5 others like this.
  14. William R. Horn
    William R. Horn
    from Virginia
    Be careful picking up someone else's "mid-project, need to sell for cash infusion for other projects"!! The "few items to p*** VA inspection" have turned into a re-wire, new exhaust system, going to need re-plumbing on the power brake upgrade he did..... My OCD kicked in on fixing one thing and seeing three other things that I can't let go. Because later I'll have to undo, what I just fixed, to fix the other thing.
    It is amazing how going into the garage and swearing, sweating, becoming poorer, and walking out later still make you feel better....
    ...waiting on parts...
    BigRRR, Okie Pete, sixty3 and 7 others like this.
  15. AldeanFan
    AldeanFan
    hrm2k, BigRRR, Okie Pete and 9 others like this.
  16. squirrel
    and I just put my Y block powered ride up for sale, after cleaning it up just a little bit.
  17. wauto
    wauto
  18. enloe
    enloe
    from east , tn.
    Wired on the Corvette wiring this evening. I still have to move the alternator to the driver side of the engine. I have to wire up the starter. I need to put new collector gaskets on. I have to fix the steering column wiring. There are a couple of wires out of the plug. I am hoping to drive it this week. I need to get some miles on it before Lloydfest.
  19. jimmy six
    jimmy six
    Like McCleod clutches but never had one of the hydraulic TO bearings that didn’t leak after sitting a while. Ram and Howes never leaked!
  20. saltflats
    saltflats
    from Missouri
    What fluid did you use?
  21. Custom Effies
    Custom Effies
    from Seattle
    S****ping the under cab mounted master cylinder for a firewall mounted one. As I get older (and more broken) I find crawling under vehicles to do simple tasks less fun.
  22. RMcCulley
    RMcCulley
    Post some more pictures! I had a 64 grand prix about 25 years ago, i just found some a few parts that I had kept (clock & a couple of fender badges).
    I toy with the idea of trying to find another one
    Got brake parts on the way
  24. kls50
    kls50
    Finally got the steering column and parts painted for my 1950 Ford coupe. It's been slow going but I managed to keep plugging away at it. Trying to get it all back together from mounting the rebuilt steering box to the Crestliner steering wheel I also restored by end of Thursday. DSC01398.JPG DSC01399.JPG DSC01400.JPG DSC01401.JPG
  25. Here’s the other angle
    nice roof:)
  26. Sharpone
    Sharpone
  27. kls50
    kls50
    I really need to get gl***es! I just noticed the SMALL dent in the top of the cab!
  28. kls50
    kls50
    Got the column tube and shifter back together today and put anther coat of paint on the steering wheel. Tomorrow installing it all back in the car (Hopefully). I haven't been able to drive it yet this year. DSC01402.JPG DSC01403.JPG DSC01404.JPG
  29. It's been a quite a few months since I've posted on here but I am now back on a on top of the car and it is moving right along although a little a little further behind than where I was hoping to be I am still making "Ford" (see what I did there) progress, I got the back window in earlier today, I had never done that task not real hard I am by far from an expert but it wasn't bad. I also had to remake all the wood around the rear window because of course what little bit was left was absolutely rotten, I gave the car a SOS scrub to get all the rust off since my last post but I'm not removing all of its so-called patina because I am tired of perpetual projects I just want to get this one up and driving and have fun. So I got the hood mounted, the body is completely mounted, the gas tank is completely mounted and cleaned out with a fresh gas gauge in it, I got about half of the electrical done (hopefully I will have it all done here in about a week it's been over a hundred and I have no shade on the side of my house so it's pretty brutal short of an easy up so I just cook out there. I've been buying all kinds of odds and ends for the car CW Moss and the Ford store in San Dimas probably love me. I also bought the lower window garnish molding for the rear widows on eBay and I managed to find the driver side upper garnish molding for the side window.
    Now I got to find the pieces that go on top of the doors, the part you grab to close the doors (I was going to buy these reproduction but everyone has been out of stock on them probably 2 years).
    I did however get the front windshield installed and the piece of wood for the header panel and the visor and I think I am going to weld in those pieces that go above the door I don't know what they are technically called but welding them in seems easiest and probably the strongest.
    I got to find the rain gutter pieces next because the car has to have rain gutters I don't care if they function or leak or anything like that but I can't have those open holes and I'm not going to fill it because personal opinion not looks terrible.
    Hopefully in the next few days I will have some better pictures, I am pretty bad at do***enting my work I took this before I came in this evening I was done sweating. The picture in the daylight was taken on August 8th it don't look much different but it's definitely moving along.
