Technical UH OH, FLATHEAD ATE MY PCV VALVE
Discussion in 'The Hokey Ass Message Board' started by Bandit Billy, Aug 5, 2026.
  1. Bandit Billy
    Bandit Billy
    So now I have the spring to add to the night horrors of my Ex and that weird dream where I show up at school without my pants. Great! And people wonder why I drink!
    hotrodA, 2devilles, kls50 and 11 others like this.
  2. CSPIDY
    CSPIDY
    With regards to early ford engines and filters
    When running the old non detergent oils, the design was the dirt was deposited into the oil pan, ie sludge. Periodic cleaning was required. But in reality the engine needed overhaul before that.
    With detergent oil the dirts floats in the oil, and that’s when they started using filters.
  3. Bandit Billy
    Bandit Billy
    I like the statement and the fact that your avatar is the chaos guy from the Allstate commercials. It makes me wonder which side of the argument you are actually on :cool:
    Johnny Gee, porkshop, CSPIDY and 4 others like this.
  4. gimpyshotrods
    gimpyshotrods
    Maybe, but I am not sure. That would take some testing.
    Pressure may be a problem, unless the pump is shimmed/modified. The typical Saginaw P-pump, depending on configuration, puts out somewhere between 1,200 to 1,450 PSI at 2.5 to 3.5 GPM
    That pressure would fragment all known oil filters. Putting the filter on the return side might stop it from scavenging properly.
    Pressure regulation is by byp***. Excess pressure is bled back to the reservoir. Reducing pressure via conventional means would have the oil going round and round in the pump.
    That aside, power steering fluid is between ISO 32 and ISO 46, which is roughly 5W to 10W on the SAE scale. Old school ATF, sometimes used for power steering fluid, is about 7.5 on the SAE scale.
    Weight and viscosity wise, it should work. There are Saginaw P-pump housings that are made for remote reservoirs, and that have AN/JIC fittings in and an adapter for out. I have one on my Falcon.
    Run the pressure side to a remote filter housing, and then back to the pan.
    The inlet is a generous -10AN, with the option of -12AN. The adapters for the pressure side are most often -6AN.
    AN and JIC are dimensionally interchangeable with the same number. -6AN is dimensionally the same as JIC-6.
    For maximum safety, you can build, or have built crimped hydraulic hoses.
    https://www.pscsteering.com/product...ir-saginaw-p-pump?_pos=6&_sid=a56eeeace&_ss=r
    While it might be possible to put this together, it might not work as well as desired.
    porkshop and Bandit Billy like this.
  5. gimpyshotrods
    gimpyshotrods
    I will need to model this.
    The pressure generated is dependent on pushing against a mechanism. Without the mechanism present, the performance will be very different.
    If the filter is on the inlet side, and an open hose back to the pan is on the pressure side, it might work.
    Much to figure. May messes to be made.
    SS327, porkshop, Bandit Billy and 2 others like this.
  6. Beanscoot
    Beanscoot
    So don't chrome the inside!
    SS327, porkshop, Sharpone and 2 others like this.
  7. AmishMike
    AmishMike
    Ok “gimpyshotrods” you know power steering pumps I do not. Good info, just trying to think of cheap small available pump might work. That why ended note with ????
    gimpyshotrods and Bandit Billy like this.
  8. AmishMike
    AmishMike
    Helped/watched guy build dry sump sprint car with DIY oil pump. First fire up blew oil lines off tank & lot of oil onto garage floor. Still interesting project for a flathead
    Bandit Billy and Sharpone like this.
  9. 19Eddy30
    19Eddy30
    from VA
    What type of pump ?
    Generally dry sump 10-15 psi @ idle
    To blow hose A/N Jic pressure must of been over 150 psi unless hose's not ***emble correctly
    Bandit Billy likes this.
  10. 19Eddy30
    19Eddy30
    from VA
    I wonder if any have experiment with
    polishing ,Knife edge crank lighting crank or the roughness helps sling oil ?
    Also hard to believe the F-H oiling can not be improved with a internal or external pump along with oil Gallies,
    The F-H over 70 yrs older then I .
  11. CSPIDY
    CSPIDY
    Well I have been accused of mayhem
    but
    With regards to my statement, this comes from old timers I have been around
    When I first picked up my roadster with a v8 flathead, it didn’t have a filter.
    I found an original canister by-p*** style that was an option for the flathead ford.
    Installed it with an orifice as recommended and there was a nil effect on the oil pressure.
    SS327, GuyW, warbird1 and 2 others like this.
  12. AmishMike
    AmishMike
    Builder had machined pump with 2 gears pulling oil from engine to large tank with inch maybe 1 1/2 inch hose. Other side of pump from tank to engine same design. Do not remember exact fitting on tank maybe just hose clamp. First start up hose off tank pumped oil to floor. No idea what pressure was. Redesign drive system to lower pressure.
  13. SS327
    SS327
    Has anyone ever considered using an oil spinner type filter? I hear they are very efficient. I know some big diesels use them.
  14. 19Eddy30
    19Eddy30
    from VA
    I would think that others where considering non oem style cartridges,
    of Pre 60's saying no gain / filtration.
    There are Cartridge high flow element & micron's.
    I think many just stick to automotive use in stead of other use's & part's .
    Industrial ,Marina ,Aviation ,Heavy as options
    Bandit Billy and SS327 like this.
  15. Jack E/NJ
    Jack E/NJ
    from NJ
    Perfect filter kit for Billy. Chrome-plated too. If there's room, double dispenser would look great next to chrome plated master cylinder.
  16. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    Have you looked into fixed orifice PCVs?
  17. Bandit Billy
    Bandit Billy
    Clean on the inside, shiny on the outside. How can you go wrong?
    I will. I like the AC Declo piece I bought, easy to find replacement and just $6.00.
    I had a bit of an oil leak getting it started back up after painting that pan. The breather leaked like a sieve. I welded a baffle inside the pan as well as nuts to make R&R easy, the result was a less than flat surface for that breather. I built a gasket and used RTV, let it sit overnight and still leaked. I bought some Permatex called Right Stuff with a one minute return to service. I ditched the paper gasket, squirted out a bead around the breather and stuck it on. Fired it up one minute later and no leaks. Took it for a drive, feels great and best part...no leaks.
    I did receive a tracking number for a new (to me) Merc pan from one of our own. I look forward to prepping it for chrome and getting it dipped. Those big Merc pans do not need to be modified to clear the Melling pump I am using. BTW, the hi-volume pup measures 5 5/8th from the pan rail to the bottom of the pump. The Merc pan measures 7". I won't be adding the breather to it since I have the PCV system.
    I am considering all the comments regarding filtration. I read once that it takes like 15 miles at 2000 RPM to cycle the oil through the filter. Is that correct? I mean, around town, is it really doing anything other than providing piece of mind? Perhaps I got that stat wrong, it seems ridiculous. Probably my bad, don't quote me..
    warbird1 likes this.
  18. 19Eddy30
    19Eddy30
    from VA
    I do not see that with a non by p*** or maybe even a byp*** & @ even 10psi .
    I would say you could pump 5 qt in few mints @ idle 3/16 hole
    If true taken 15mile's I am clue less to .
    GuyW likes this.
  19. Mart
    Mart
    I did note that my beehive oil filter on my roadster does get quite hot. To me that says it must be getting plenty of oil going through it. If only a dribble it wouldn't be as hot.
    Mart.
    Ziggster and Bandit Billy like this.
  20. twenty8
    twenty8
    Not sure with a flathead v8, but here is some info regarding more modern filtration systems.
    Seems to happen very quickly......
    Does oil flow through the filter continuously while the engine runs?
    Yes , in a full-flow system, which is what virtually all modern petrol and diesel engines use, every drop of oil p***es through the filter media every time it circulates through the engine. At idle, a typical engine might circulate its full oil volume several times per minute, meaning the filter is working continuously from the moment you start the engine to the moment you switch it off.
