Projects 1962-ish era 1940 Ford pickup build
Discussion in 'Traditional Hot Rods' started by 40panel348, Aug 14, 2026.
  1. 40panel348
    40panel348
    I've wanted to build an early '60's style 1940 Ford Pickup, and have collected some cool parts over the years. I've done most all of the work so far by myself, with some ***istance from my father, with the major exception of the upholstery, which is being done by my buddy Dominic Olson of Big O Fabrications.
    It has a .060 over 1960 283, that has Power Pack heads with slightly larger exhaust valves and some port and polish work done, and 097 Duntov Solid lifter cam. On top is a Man-A-Fre setup that was built by Tim Bowman, who worked for Man-A-Fre back in the day. It has a set of Fenton Black Widow headers that I built custom collectors for that go back into a stainless exhaust that I welded up, then smoothed and polished the welds. The mufflers are C1 Corvette "off-road" mufflers that I polished the aluminized coating. The engine is mounted in the ch***is with a vintage Hurst mount. It's all backed up by a 1962 T-10 4-speed, and a 1960 Chevy rear axle with a 3.55 posi center section. I drew up a custom mount for the Hurst shifter to move it up and forward on the trans, and had it machined by a Horizon Machine. I wanted to go with finned Buick drums on the front, but since they are hidden, and its a driver, there are disc brakes up front on the 4 inch drop Super Bell axle that's set in place with split wishbones and a Posies reverse eye spring. The rear is set up with a Posies parallel leaf kit and sway bar, and there are Bilstein shocks on all four corners.
    I ended up going with a new bed from Mack Hils that I ***embled myself on the original bed subframe. I made some hidden tailgate latches, and a custom aluminum tonneau cover with hidden latches that is being upholstered to match the interior and running boards. I mounted 1948 Buick taillights in the pan under the tailgate. Below all of that, I used a 1940 Ford car rear bumper and brackets with a Chevy overrider to frame the license plate. I then hand formed a rear pan to go from the bumper to the rear frame crossmember.
    Inside, I have a 1940 Ford Deluxe car dash with some vintage Stewart Warner gauges hanging below it. The steering column is 1940 Ford car as well that I modified to accept a C1 Corvette turn signal bell that mates up to a C1 Corvette steering wheel on a custom adapter that I came up with using an early ford wheel adapter and a C1 Corvette factory wheel mount that were machined to fit together, then welded solid. I used a third row seat out of a 1993 Suburban, and made my own mount, then reinforced the cab floor to be more sturdy underneath. I'm installing electric wipers as well as a mini Vintage Air heater/defroster hidden behind a modified 1941 Ford heater case.
    On the cab itself, I welded up 54 holes in the firewall, then made custom mounts for the the heater, gas pedal, and parking brake so no fasteners will show through the firewall. I also modified the drivers door with some original Ford parts to put a door lock on the driver's side. Someone had welded up the cowl vent in the past, but I was able to cut the welds and have a functioning cowl vent again. The transmission cover inside has been modified, as well as the floor for more room for the shifter, and better access to the trans.
    I know not everything is period on it, but I've been trying to keep anything that's readily visible of the era. I still have a lot of work to do, and I'll do my best to keep this updated as I progress.
    Enjoy!
    IMG_20130924_185039_298.jpg 20180724_160215.jpg 20230706_172147.jpg 20230831_163659.jpg 20240414_140008.jpg 20250223_155327.jpg 20250308_172058.jpg 20250309_165241.jpg 20250309_174555.jpg 20250321_130510.jpg 20250406_164858.jpg 20250418_174242.jpg 20250419_161649.jpg 20250505_175219.jpg 20250512_181920.jpg 20250526_115848.jpg 20250526_160831.jpg 20250528_081435.jpg 20250607_093327.jpg 20250614_165451.jpg 20250614_164827.jpg 20251011_171511.jpg 20251012_144217.jpg 20251130_094459.jpg 20251219_104954.jpg 20251214_171037.jpg 20251214_102016.jpg 20251226_144231.jpg 20251226_185133.jpg 20251227_125049.jpg
  2. 40panel348
    40panel348
    More pictures. I had some vintage Badger air cleaners I wanted to use, but they all had different base sizes. I couldn't find enough matching original bases in the size I needed, so Justin Frensko was up to the task of making me new bases that looked like original ones to fit the 2G carbs. Amazing work! 20251228_132613.jpg 20251229_180054.jpg 20251229_175504.jpg 20260116_102058.jpg 20260116_105008.jpg 20260118_165342(1).jpg 20260118_165357(1).jpg 20260118_165417(1).jpg 20260118_165448(1).jpg 20260118_165503(1).jpg 20260118_165515(1).jpg 20260118_165523(1)(1).jpg 20260118_165538.jpg 20260123_115008.jpg 20260215_121637.jpg 20260215_155706.jpg 20260221_154130.jpg 20260226_174256.jpg 20260306_093200.jpg 20260320_161329.jpg 20260322_182851.jpg 20260404_183101.jpg 20260417_134604.jpg 20260417_161303.jpg 20260418_171536.jpg 20260418_175614.jpg 20260425_113536.jpg 20260425_173601.jpg 20260605_074222.jpg 20260605_074231.jpg
    shortypu, 40FORDPU, rod1 and 14 others like this.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    cool man... I enlarged the pics... always select "full image" when posting pics
    Just Gary and 40panel348 like this.
  4. 40panel348
    40panel348
    Some final pictures up to where I am currently. 20260605_073451.jpg 20260605_154740.jpg 20260605_074306.jpg 20260613_164745.jpg 20260614_170539.jpg 20260614_170728.jpg 20260614_170751.jpg 20260627_100957.jpg 20260627_101048.jpg 20260627_101118.jpg 20260627_101242.jpg 20260612_111808.jpg 20260612_111812.jpg 20260612_111817.jpg 20260612_170128.jpg 20260612_112049.jpg 20260725_110342.jpg 20260725_123246(1).jpg 20260801_112500.jpg 20260801_112507.jpg 20260802_141439.jpg 20260802_151002.jpg 20260802_161546.jpg 20260802_162458.jpg 20260802_162833.jpg 20260802_162845.jpg
  5. 40panel348
    40panel348
    Ok. Thank you, Mark!
    rod1, Dave Mc and Moriarity like this.
  6. Nailhead Jason
    Nailhead Jason
    Love the truck!, that is really gonna be a great ride, your gonna love that 283, the one in my 39 is basically the same, it rips all day long!
    Roothawg, rod1, Dave Mc and 1 other person like this.
  7. Nailhead Jason
    Nailhead Jason
    I love the white Running boards! did a similar treatment to my 39 sedan. My target year was also 1962
  8. goldmountain
    goldmountain
    Great looking truck but the whitewalls are mounted backwards.
    Dave Mc and 40panel348 like this.
  9. hotrodA
    hotrodA
    As I am in the middle of a similar truck build, I definitely will be following this!
    You do nice work! Thanks for sharing with us.
    shortypu, Dave Mc and 40panel348 like this.
  10. 40panel348
    40panel348
    They are temporary tires with a weird whitewall on the back. They aren't narrow, but they aren't wide either. I'm probably going to end up with wide whites.
    rod1 and Dave Mc like this.
  11. richard noble
    richard noble
    Wow, what a nice build. Can’t wait for more pics. This was my brothers 40 pickup in 1962…. IMG_0253.jpeg
    shortypu, Okie Pete, Phillips and 5 others like this.
  12. treb11
    treb11
    Outstanding build. Whay color are you planning on?
    40panel348 and Dave Mc like this.
  13. Mikko_
    Mikko_
    from Sweden
    Nice work so far, I'll tag along and watch the rest come together.
    shortypu and 40panel348 like this.
  14. jaracer
    jaracer
    Very nice work.
    40panel348 likes this.
  15. 40panel348
    40panel348
    Thank you. It's going to be '54 Corvette Pennant Blue 1954-Chevrolet-Corvette-Roadster_IMG_8313_2_4.jpg 14707732-1954-chevrolet-corvette-std-e1614274279657 (1).jpg
  16. hotrodA
    hotrodA
    Once again, that is some nice work!i
    In the pic with the freshly chromed pieces, are those taillight bezels at the bottom 41 Studebaker, per chance?
    iIf you aren’t using them and want to p*** them on,
    PM me.
    rod1 and 40panel348 like this.
  17. 40panel348
    40panel348
    I'm sorry, those have already been sold. I had two complete sets of Stude lights, and I was going to use one of them, but changed my mind.
  18. rusty1
    rusty1
    this is the way every build should go, nice work.
  19. stuart in mn
    stuart in mn
    I like it a lot! 1962 was the first year the car companies went to narrow whitewalls, so they would be appropriate on your truck (***uming someone back then wanted to follow the latest trends.). The blue color you've chosen is nice but it would also look great painted gold to match the engine.
  20. AHotRod
    AHotRod
    Job well done
  21. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Excellent work.
    Killer Build
    VR&C.
  22. 40panel348
    40panel348
    Th
    Thank you, I'm not sure how the narrow whitewalls will look with the rest of it, but that is an option. I do like the gold, but there are a few gold 40 PUs out there already, and I wanted to be a little different.
  23. Roothawg
    Roothawg
    Man, I can't believe I missed this. That is perfect. I am collecting parts for a 36 pickup that same era. I love 59-62.
  24. 40FORDPU
    40FORDPU
    Nice project, watching.....looking forward to your updates.
