Hot Rods Here I go again. 29 woodie
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Mar 16, 2026.
  1. rusty rocket
    rusty rocket
    I’ve been waiting for back order piano hinges so I can start building my doors. I ended up putting one coat of spar varnish on the tailgate so I don’t get it stained with my dirty hands. Guys on the national woodie forums say they put 10 to 15 coats of varnish on. Thats going to be quite the process. I also messed around with and original 28/9 pickup sun visor. I cut several inches off because I thought it was way too long and low. IMG_5318.jpeg IMG_5317.jpeg IMG_5316.jpeg
  2. rusty rocket
    rusty rocket
    Definitely time for a sawdust shop clean out. I received one set of stainless steel piano hinges last week and spent all day drilling and tapping into the metal A pillar. Pretty labor intensive being that I have to drill into the 3/8” steel with out going through and then tap a blind hole with a tapered tap and then a tap that I cut in half so the threads go to the bottom. 20 holes per hinge . Today’s project was the drivers front door ruff out. Lots of adjustments to do and window track to figure out. IMG_5339.jpeg IMG_5340.jpeg IMG_5341.jpeg
  3. Tim
    Tim
    from KCMO
    Man that’s looking fantastic! I bet once you get to the second side it’s gonna go even quicker.
    I’m curious if the back fender is stock and how they attach to the body?
    loving this build.
  4. rusty rocket
    rusty rocket
    I was going to try and use the original sedan fenders but it would have been a lot more work and they had a lot of vibration cracks. I ordered coupe rears.
    I made a piece to finish the inside of the coupe fender and they are bolted to the sub rail.
    Lil 32, Algoma56, porkshop and 5 others like this.
  5. Tim
    Tim
    from KCMO
    Great solution! Looks fantastic
    Algoma56 and porkshop like this.
  6. sodakmini
    sodakmini
    Looks like I may need to borrow you a broom...... ha! Looks killer, buddy; seriously need to swing the '37 up and check this thing out.
    Algoma56 likes this.
  7. Just checking in on the awesome progress.
  8. rusty rocket
    rusty rocket
    I have the rear upper tailgate door built. Need to take it apart and do all the sanding, routing and glue it up and screw it all back together. IMG_5347.jpeg IMG_5353.jpeg
    Tim, Okie Pete, porkshop and 11 others like this.
  9. fordor
    fordor
    from Finland
    Really nice work:)
    porkshop and continentaljohn like this.
  10. patsurf
    patsurf
    perfect!-how does gl*** mount?
    porkshop likes this.
  11. rusty rocket
    rusty rocket
    I have a dado on the back side. I talked with the guy that has done gl*** for me in the past and he steered me in the right direction on some rubber u channel that the gl*** gets wrapped with and then I will install a stop from the inside.
    Tim, Lil 32, Okie Pete and 4 others like this.
  12. warhorseracing
    warhorseracing
    from cameron wv
    ^^^^^^Safety gl*** or?
  13. HOTRODPRIMER
    HOTRODPRIMER
    Beautiful work my friend! HRP
  14. rusty rocket
    rusty rocket
    No just thinking about some single strength house window gl***.
    Okie Pete and porkshop like this.
  15. rusty rocket
    rusty rocket
    Just kidding it will be 1/4” auto gl***.
    Lil 32, Tim, Okie Pete and 3 others like this.
  16. warhorseracing
    warhorseracing
    from cameron wv
    ^^^^^^Just trying to keep everyone safe.;) Remembering some of those high school "Driver Safety" movies they used to show with the doors wrapped around trees and an ejected driver trapped between the tree and car, heads through windshields:eek:. Gruesome as they were they left an impression.
    Okie Pete, porkshop and Weedburner 40 like this.
  17. patsurf
    patsurf
    your last line was very fitting...
    Okie Pete and warhorseracing like this.
  18. You do know that they make bottom taps specifically for that purpose, right? You can cut down a taper tap, but if a 'corner' breaks off while tapping it can make a mess. AMHIK...
  19. rusty rocket
    rusty rocket
    I have the drivers rear door roughed in. I have some adjustments to do to get better gaps. Another step closer. IMG_5367.jpeg
  20. RodStRace
    RodStRace
  21. rusty rocket
    rusty rocket
    Algoma56 and warhorseracing like this.
  22. rusty rocket
    rusty rocket
    Been doing a lot of little stuff but going around fenders is time consuming. I now have the quarter panel Frame ruffed in. I ordered bear claw latch’s after I figured out I couldn’t use the original latch’s. I have one mocked in at this point. IMG_5398.jpeg IMG_5399.jpeg IMG_5400.jpeg
    Tim, anothercarguy, porkshop and 11 others like this.
  23. rusty rocket
    rusty rocket
    Have the panel cut and installed. Also put a detail on the curved piece sort of like the original woodies. IMG_5408.jpeg IMG_5410.jpeg
    RMR&C, Shadow Creek, Tim and 9 others like this.
  24. patsurf
    patsurf
  25. continentaljohn
    continentaljohn
  26. warhorseracing
    warhorseracing
    from cameron wv
    I am under the impression that detail was to mimic the rear door opening to complete the radius.
  27. rusty rocket
    rusty rocket
    That’s what I’m thinking.
    RICH B and warhorseracing like this.
  28. Tim
    Tim
    from KCMO
  29. rusty rocket
    rusty rocket
  30. warhorseracing
    warhorseracing
    from cameron wv
    Working on a construction job years ago there was a carpenter on the job named Sam. The laborer would hold the board in place and tell him to "Nail it Sam". Every board on that bridge Was cut by another carpenter carried and held in place by the laborer and all the carpenter Sam did was "nail it".
