Hot Rods Curious, Your 1st Impressions, 1st Thoughts? AND MORE NEW PICS
Discussion in 'The Hokey Ass Message Board' started by 6 Shooter, Aug 5, 2026.
  1. Those aren’t as bad
    chryslerfan55 and Sharpone like this.
  2. warhorseracing
    warhorseracing
    from cameron wv
    Rattlers? They do have them there.
  3. Yep
    Don’t see em much
    They make noises, spiders don’t
  4. warhorseracing
    warhorseracing
    from cameron wv
    At night you do.:( NVG's are not as good as thermals to spot them when moving through the desert at night.:cool: There are more there than you think.:eek:
    Sharpone likes this.
  5. ronzmtrwrx
    ronzmtrwrx
    I’d like to see this pic, if it’s one of this car. Looks to be a good side shot. IMG_3586.jpeg
  6. 1971BB427
    1971BB427
    from Oregon
    Looks like a m***ive amount of work, even if you want to keep most of it looking run down and neglected as it is. I'm not sure leaving delaminated gl*** is a good idea, and definitely not a safe idea! Not only will it restrict vision, but if it comes apart while you're driving down the road it could result in an accident hurting the driver, or others. Some things need to be replaced.
  7. bowie
    bowie
    I would think his sawzall batteries would have recharged by now…also a couple profile pictures, might quell some of the doubts… it’s a cool ‘32, but right now it’s like a fish on the line; that you are only getting glimpses of!
  8. ronzmtrwrx
    ronzmtrwrx
    C’mon @6 Shooter , drag this pic out of the pile and show us a side shot. We are waiting, not so patiently. :cool: IMG_3588.jpeg
  9. 49ratfink
    49ratfink
    bump to the top:)
  10. Okie Pete
    Okie Pete
    6shooter , I for one hope you save it and get it back on the road . Get rid of what isn’t safe , make it yours and drive it .
  11. 6 Shooter
    6 Shooter
  12. 6 Shooter
    6 Shooter
    Built sometime before 1958, that tubing runs from the firewall, inside the frame rails, over the hump, and out the rear pan... I was thinking that it was his way of stiffening the frame... way before P&J boxing plates...
    there is a hole in each, past the rear panels/ grille area... I thought one bolt through each could've been a quick rear bumper removal...
    Then I realized that the tubing was also the exhaust...
    I think that the two rear tube shocks are laid down pretty flat, so not so much for suspension travel, but to keep the rearend centered? I'm just guessing here...
    I am sure that the PO that I got this 5W from, did not / could not have thought / designed / built this suspension,,, he was in high school... I'm not knocking him, but I just don't think that he could've been the designer / engineer / fabricator...
    I cannot imagine him. / anyone in their backyard with a hacksaw, cutting out the bracket mounting for the banjo...
    Or welding everything together...
  13. 6 Shooter
    6 Shooter
    The grille was not attached / bolted down to anything... I think that it might be a 34 35 Chevy commercial/ truck grille... but I'm really guessing here... I've asked some guys with early Chevy stuff and cannot get a good answer...
    What I said about the last owner designing this 5W... the headlights are mounted on flatstock bent 90°... which is fine... it worked, it's simple, and got the job done... it's all I would expect for the time and his experience... he was in high school and did not have alot of money... but he was able to drive it for five or six years...
  14. 6 Shooter
    6 Shooter
  15. 6 Shooter
    6 Shooter
    The front frame horns were cut and pinched, so I'm guessing that there was a track nose at one time...
    Also there is a panel underneath which has somehow gathered alot of dirt and rocks...
    And a tach drive mounted on the front crossmember...
    If you look at the pics of the reared, you can see part of / what's left of the louvered bellypan...
  16. 62pan
    62pan
    Thanks for taking the time to share, this is quite interesting.
  17. hotrodA
    hotrodA
    So, have you dragged it home, yet? Yes, it’s a project, but with some cautious cleanup and dissection there could be a great starting point. Maybe it could use another frame, after the body removal.. To get the project rolling (pun intended) :rolleyes:
    chryslerfan55, SS327 and Sharpone like this.
  18. 6 Shooter
    6 Shooter
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    has this been dragged out of the weeds yet so we can see a picture of the entire car?
  20. gene-koning
    gene-koning
    I was thinking the same thing.
    It looks like there was some very creative suspension designing going on. I can't imagine it was very fun to drive. That may be why it appears there were a lot of things added to the suspension...
    6 Shooter, if you intend to actually drive this, that de-laminated gl*** has to go.
    If its going to be a static display, I think I would still be replacing it, I wouldn't want to worry about someone getting cut badly when that gl*** falls apart..
  21. RaginPin3Appl3
    RaginPin3Appl3
    The most suspenseful thread on the HAMB…
  22. 41 GMC K-18
    41 GMC K-18
  23. 6 Shooter
    6 Shooter
  24. 6 Shooter
    6 Shooter
    Says Error, not a valid file, or something like that...
    Hairpin Initials... driver & brother? Builder & wife? Cousins? How difficult to find a last name beginning with 'V'?
    Did you notice that the fabbed Pitman arm has two holes? For diff steering ratio...
    Need to get ready for friend's memorial service...
    chryslerfan55, rod1 and catdad49 like this.
  25. 6 Shooter
    6 Shooter
    Cannot upload pics, again... ‍‍
  26. 49ratfink
    49ratfink
    why are you taking pictures of pictures? do you not have the car?
    chryslerfan55 and Moriarity like this.
  27. Find a young person to post the pics
    that’s how I fix technical issues
  28. 6 Shooter
    6 Shooter
    Great idea...
  29. 6 Shooter
    6 Shooter
    Wow... Are you accusing me of being a lying, BSer?
  30. coupe33
    coupe33
    I find this very interesting. I have to wait until I see the coupe.
    chryslerfan55 and 41 GMC K-18 like this.
