Hot Rods is this a factory 32 ford gas tank?
Discussion in 'The Hokey Ass Message Board' started by drumyn29, Aug 17, 2026.
  1. drumyn29
    drumyn29
    Is there a way to tell who manufactured this tank?
  2. 19Eddy30
    19Eddy30
    from VA
    There should be a drain on bottom
    yr picture looks to have pick up & sender to fair to left
  3. drumyn29
    drumyn29
  4. alchemy
    alchemy
    Henry made that one.
  5. HOTRODPRIMER
    HOTRODPRIMER
    Looks like it's a Henry Ford original with the bottom drain plug. HRP
  6. drumyn29
    drumyn29
    Life is good! That to me was a telltale sign also. That does not look like aftermarket to me.
  7. 19Eddy30
    19Eddy30
    from VA
    I have only had a few Henry tanks ,
    The one Op posted just looks like both the
    Sender & pick up to fair to left ,
    Why ?
    & tank I have had not dimpled like one shown .
  8. alchemy
    alchemy
    The OP and Eddy’s pics both show the original pickup/sender location right next to the little bolt holes in the rear lip. The other sender hole on each was added by some dad-gum hot rodder wherever he damn well pleased. No wonder they are both in the “wrong” spot.
    Fogger and deuceman32 like this.
  9. 19Eddy30
    19Eddy30
    from VA
    @alchemy
    Yes Du!!
    Me working on & having stock some modified parts forgetting that 32 only had pickup & bub in one & I walk by a pick up each day 3-4 times on shelf
  10. ct1932ford
    ct1932ford
  11. Fogger
    Fogger
    I had to drill out the drain plug out on my original tank. The above tanks look like original. The best reproduction tank was made by Vintique and could p*** as original, but the current one is not close.
