Technical Needing small GM clutch disc
Discussion in 'The Hokey Ass Message Board' started by chlsnk, Aug 13, 2026.
  1. chlsnk
    chlsnk
    Why not? 10 spline and 1.125" hub?
  2. 427 sleeper
    427 sleeper
    LaSalle input shafts are 1 1/4", not 1 1/8", like the disc you're looking to get.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    Here’s your picture from page 1. An inch and an eighth is 1.125. What you measured is just under an inch and a quarter
  4. Fordors
    Fordors
    Even if the OD of the spline was machined there is what’s known as the minor diameter on splines, that will need machining as well.
  5. chlsnk
    chlsnk
    Boy howdy if that's not a big woopsie. I've been reading that as 1.123 this whole time. Im about to hang it up with this trans and go back to the ford.
  6. patsurf
    patsurf
    why would you care about .002 ??
  7. 19Eddy30
    19Eddy30
    from VA
    @chlsnk
    How about a broach ? Key way maker
    Or
    Change centers & re rivet / bolt back together
    chlsnk likes this.
  8. chlsnk
    chlsnk
    The shaft is 1.23" 1/4" larger that I had it in my head.
  9. squirrel
    you mean 1/8" larger than you had in your head.
    I'll go get my clutch book and see what they show.
    Moriarity likes this.
  10. squirrel
    Borg Warner 99344 or 99377 are 9" with 1-1/4" x 10 spline
    99344 fits British cars. 1952-68
    99377 fits British cars early 70s.
    The only one I've found close so far is early 70s TR-6, but it's 8.5" diameter disk, 1-1/4 x 10 spline
    still looking
  11. patsurf
    patsurf
    1/2 sherlock holmes and 1/2 bloodhound---= 1 squirrell
    High test 63 and chlsnk like this.
  12. squirrel
    this one might be 9" diameter, call them and find out. Or just ask if they have one that's the right specs.
  13. chlsnk
    chlsnk
    I confirmed this is a 9" disc
    Algoma56, squirrel and 51 mercules like this.
  14. 51504bat
    51504bat
    Back when I had my MGTD I dealt with a guy at Moss (parts manager?) who was more than helpful with oddball questions and requests. Don't know if he is still there but my guess is that someone there could help.
    chlsnk and Algoma56 like this.
  15. chlsnk
    chlsnk
    Case closed. Triumph Stag clutch disc. Thanks for all the help.
    Tim, SR100, pprather and 4 others like this.
  16. squirrel
  17. chlsnk
    chlsnk
    Yes a perfect fit. Thank you for the help tracking that down.
    Tim, squirrel, Algoma56 and 1 other person like this.
