Hot Rods Update v12 Linclon ignition problem solved
Discussion in 'The Hokey Ass Message Board' started by two couped up, Aug 31, 2026.
  1. two couped up
    two couped up
    from pa.
    If any of you guys that responded to the thread at the beginning of the month about my v12 having spark bind problems when starting, here is an update. I sent the distributors to Third Generation Auto and Mike put them on their machine and adjusted them. They both start the car now with just a touch of the starter ****on, just like my v8 cars do, no more spark bind. If you need your flathead distributor rebuilt or strobed send them to Mike he can make them perfect. I didn't even have to do a vacuum brake adjustment for 87 octane gas. Thank you Mike and Third Gen. Auto, for a job well done.
  2. Doublepumper
    Doublepumper
    from OR-WA, USA
    Good news! Glad it worked out for you.
  3. 19Eddy30
    19Eddy30
    from VA
    What was the Issue ?
    To much Advance ?
