Projects So this is how it starts T RPU turned Roadster
Discussion in 'Traditional Hot Rods' started by chlsnk, Jun 5, 2025.
  1. chlsnk
    chlsnk
    One of our most trusted elected officals
  2. The mayor of Westport?
    chlsnk likes this.
  3. Guess after seeing this car in person today I'll have to keep on you to get it done like I do timm. ;)
    Outback, chlsnk and Tim like this.
  4. chlsnk
    chlsnk
    20260823_162356.jpg 20260823_162327.jpg 20260822_084619.jpg Successful weekend of buying at the springfeild swap meet. Found a few small items I was after and met a few Hamb members. I was suprised to find afew folks who where familar with the car from here and Instagram.
    Outback, Okie Pete, Deutscher and 5 others like this.
  5. Tim
    Tim
    from KCMO
    Good stuff man!
  6. chlsnk
    chlsnk
    Yesterday the new clutch disc came in the mail that a fellow hamber graciously sent me and I tore down to the shop after work today to install the clutch and stab the engine in. Hub on the clutch is too small, dang back to the drawing board.
    Okie Pete and Deutscher like this.
  7. Tim
    Tim
    from KCMO
    At this point would it maybe seem a better route to machine the trans side to make a more common clutch disc fit?
  8. chlsnk
    chlsnk
    Screenshot_20260825_203124_Chrome.jpg Well I found the first good use for the A/I computer; searching rockauto for parts by spec. I found a 1982 4cyl camaro clutch disc. It's 1/8" larger in diameter than I need but the right hub. I figure I can chuck it up in the lathe and grind off some or just run it with some sticking out.
  9. Tim
    Tim
    from KCMO
    There we go!
    Okie Pete likes this.
  10. chlsnk
    chlsnk
    Clutch disc saga continues. The disc I ordered had the wrong hub I miss read my measurement as 1 1/8" when I really needed a 1 1/4" hub. After some help from a other hamber I found a triumph stag used the disc I need. Ordered one from Moss Motors last week only to check on it today and find my payment never went through. Maybe next week I can make some progress.
    In other news did some DIY screen printing for some club shirts and rags.
    Outback, Okie Pete, J.Ukrop and 3 others like this.
  11. Tim
    Tim
    from KCMO
    Man what a saga, you’ll
    Glad when you can put it behind you…. Or under your feet actually I suppose.
    t-shirts/ rags look neat!
    Outback likes this.
  12. chlsnk
    chlsnk
    Worked on mounting the fuel tank late into the night only to be unhappy with how high is would sit and left it. Came back today and looked at how it was sitting and I think I will weld my saddle mounts directly to the cross bars I put in. This keeps it low slung but dang all that time making the saddles and I never thought of this as an option. Always chuckle when the solution is staring you right in the face.
    Outback, Okie Pete, Deutscher and 3 others like this.
  13. Tim
    Tim
    from KCMO
    Frustrating but I guess you got it figured out one way or another!
    Outback, Okie Pete and chlsnk like this.
  14. chlsnk
    chlsnk
    Holy smokes I never thought it would happen the weird 9" clutch disc finally arrived today. Boxed as a AP clutch the disc is marked borg and beck.
  15. Tim
    Tim
    from KCMO
    Crossing my fingers for good luck over here!
  16. Okie Pete
    Okie Pete
    It seems that you have a beer can opener affliction as I do . Lol
    Outback and chlsnk like this.
  17. chlsnk
    chlsnk
    Im always hunting for Hamms openers I haven't seen before.
    Okie Pete and Outback like this.
  18. Tim
    Tim
    from KCMO
    So did this latest clutch fit the bill? And if so what’s it supposed to be for?
    chlsnk likes this.
  19. chlsnk
    chlsnk
    Havent had a chance to bolt it up but it fits on the trans splines and measures 9" across. I ordered it from Moss Motors it was the clutch used on Triumph Stag motor cars
    Tim, 26 T Ford RPU and Okie Pete like this.
  20. chlsnk
    chlsnk
    Had what seems like a rare free day anymore and chugged away at the roadster water outlets and marrying the trans to engine.
    Turned two water outlets from .125 wall tubing and lopped off the existing undersized spigots in preparation for welding.
    Install of the clutch was okay although the input shaft needed polished to accept the pilot bearing. This was possible using red scotch Brite pad inserted into a deeper socket ran at speed on an impact. The Mac clutch alignment tool worked well for getting everything centered up.
    Engine and transmission install went relatively smoothly other than needing to move the front motor mounts forward around 1/4-5/16" which was accomplished by slotting the frame holes giving the mounts the needed adjustment. Glad I went with a bolt on mount rather than welding, not sure where the misalignment came from as it bolted together fine in mockup?
    Once the engine and transmission where inplace I was sure the shifter would interfere with the dash, too tall and too far forward but with some stroke of luck the shifter ended up in a pleasing location with no need for modification at this time.
    Played dress up with intake, radiator and hoses making sure everything was still working together with the engine moved forward and called it a wrap for the day.
    20260912_105343.jpg 20260912_120129.jpg 20260912_113910.jpg 20260911_163901.jpg
    View attachment 6815711 20260912_144838.jpg 20260912_155908.jpg 20260912_174040.jpg 20260912_173608.jpg
    Tim, roadwarrior84, J.Ukrop and 4 others like this.
  21. Tim
    Tim
    from KCMO
    **** yeah dude!
    that scotch bright and impact trick is clever! Your getting pretty dang close to being rowdy in the street!
    chlsnk likes this.
