Hot Rods Aluminum Rad Vibration/Movement Isolation
Discussion in 'The Hokey Ass Message Board' started by 2935ford, Sep 3, 2026.
  1. 2935ford
    2935ford
    '29 Tudor w/SBC rad issue.
    What are you folks doing with aftermarket aluminum radiators to isolate vibration and movement?
    I blew out mine (after 7 years) at all 4 corners and the firewall to rad support rod area due to movement. I have a puller electric fan attached with the through the rad holders.
    I have another rad to go back in but would like to know a way to help isolate this one better.
    Ideas?
    Thanks.
  2. Ziggster
    Ziggster
    Most factory rads have rubber isolators where secured to the ch***is. If your mounts are failing, I would look for something similar. Another option would be to mount the fan separately.
  3. lostone
    lostone
    from kansas
    I also built a bracket for my rods to connect to at the radiator end that ties the radiator and the radiator shell together.
    This way I have the shell helping to support the radiator and the radiator isn't taking the entire load.
  4. 2935ford
    2935ford
    Thanks. Yes, I will be mounting the fan separate from the rad
  5. 2935ford
    2935ford
    Thanks. Now there's a thought!
