Projects 1960 Starliner field find
Discussion in 'Traditional Hot Rods' started by SuperKONR, May 26, 2026.
  1. SuperKONR
    SuperKONR
    from Earth
    It's not a hi-po, it's a 2bbl 352 and it doesn't have the heavy duty suspension package.
  2. Erwin
    Erwin
    Tinted gl*** looks reel. Good looking machines, they were.
  3. SuperKONR
    SuperKONR
    from Earth
    Last night I got the engine ready to pull. I'm pretty sure it's going to be junk internally, we'll see once I can get the pan off. I'll probably be playing musical engines and sticking a Windsor in it for now.
  4. SuperKONR
    SuperKONR
    from Earth
    The 2bbl 352 is all complete at least. I have an iron 1960 4bbl intake for it in the stash if the engine is salvageable. There's a big mouse nest in the pan and the dipstick is rusted in place.
  5. Sharpone
    Sharpone
    Dang
  6. patsurf
    patsurf
    hang it in the barbecue!
    chryslerfan55 and Outback like this.
  7. SuperKONR
    SuperKONR
    from Earth
    I pulled the 352 today and discovered a rod hanging out of the block.
    This afternoon I managed to pick up a complete early FE in good shape for a really good deal. It has Mercury valve covers as a bonus. Now it's cleaning time...
  8. Wanderlust
    Wanderlust
    She gave her all! Now it makes sense as to how the mice were able to get in the pan;)
  9. Outback
    Outback
    from NE Vic, Oz
    That will do it! Glad to hear you found a replacement
  10. Paladin1962
    Paladin1962
    whooopsie... is my slip showing?
  11. frnkeore
    frnkeore
    image3.jpeg '60 Stock Car.jpg I just got a '60 Startliner, a little over a year ago. It's my second '60. I had a Galaxie Club Sedan when I was 20, in 1964. I looked for this one for 10 years before I found in in WA.
    Mines a 300hp 3 speed OD, with a 3.89 rear gear. It was originally a 3.56. I'm only the third owner. Sold new in Portland, then to the guy's son in WA.
    I've spent a lot of time on the rust. '60 and earlier Fords didn't have zink plated rockers so, there almost always gone.
    Here is a picture of mine and a picture of Ned Jarrette's but, I don't think it's a H&M car.
  12. cabong
    cabong
  13. deathrowdave
    deathrowdave
    from NKy
    I think 352/360 HP had aluminum 4 barrel intake also . A really tough one to locate years ago
    chryslerfan55 and Sharpone like this.
  14. Scott Younker
    Scott Younker
    I have a buddy who has a complete 1960 352 hipo engine. Not sure if you are interested since you just bought the Merc FE but if interested, I can ask him if he’s ready to sell it.
  15. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I'm a little shocked that there is no roll cage - not even a roll bar - in Jarret's car! When did roll bars on hardtops become mandatory?
    chryslerfan55, Sharpone and Outback like this.
  16. SuperKONR
    SuperKONR
    from Earth
    I dug out a '65 3spd toploader to put in the car until I can find the original trans. I machined down the input retainer to fit the smaller center hole in the earlier bellhousing, now I'm just waiting for a clutch disc and throwout bearing to show up and everything should bolt together.
  17. SuperKONR
    SuperKONR
    from Earth
    I got the clutch and trans all put together. I had to cut 1/8" off the tip of the trans input shaft to make it fit the FE, since for whatever reason Ford decided to make the FE toploaders use a shorter input than all the rest.
    I replaced all the core plugs in the engine block with br*** ones, then got everything stuffed in the car. It was dark by then so no pictures yet.
  18. sidevalve8ba
    sidevalve8ba
    I'm lovin' those Mercury FE valve covers. Hard to find around here.
  19. SuperKONR
    SuperKONR
    from Earth
    I appreciate the offer, I'm just going to stick with this Merc engine for now and scrounge hipo pieces for it as the budget allows.
  20. SuperKONR
    SuperKONR
    from Earth
    This thing still had the original nylon tooth cam gear on it, still in one piece! I put a double row set on it, and built a transmission crossmember while I'm waiting for parts...
  21. SuperKONR
    SuperKONR
    from Earth
    I haven't hooked up a fuel system yet but I did get the engine to fire for a second. There were no clanking noises so that was encouraging.
  22. SuperKONR
    SuperKONR
    from Earth
    I started cleaning out the interior and removing the carpet. There was a newspaper and a magazine from 1972 so that's probably the last year it ran. I was excited to find a gas receipt with a name on it, more insight to the car's history.
  23. Hot Rods Ta Hell
    Hot Rods Ta Hell
  24. Pontmerc
    Pontmerc
    from Finland
    63 Mercury engine.
    62 dont have plastic timing sprocket and 64 dont have that gas lingake spring bracket.
    302GMC, Squablow, 3blapcam and 2 others like this.
  25. SuperKONR
    SuperKONR
    from Earth
    Thanks! That lines up with what I found on Howard. He was a farmer, born in Rigby in 1928. There was a Dairyman magazine in the car so that matches. He moved to Boise at some point. He p***ed in '99 and his obituary lists a daughter named Betty.
  26. cfmvw
    cfmvw
    If you reach out to her, let us know! Always interesting to learn about the people who used to own our cars.
  27. frnkeore
    frnkeore
    I thought that everyone might find it interesting to see the original Invoice for my car.
    porkshop, 61Cruiser, Squablow and 5 others like this.
  28. frnkeore
    frnkeore
    Checking the inflation rate from 1960 to now ($11.32) it would make the invoice price $36,927 in today's dollars!
    porkshop, 61Cruiser, LCGarage and 4 others like this.
  29. I like it. It’s outstanding, in a field, by itself. Hehe
    porkshop, SuperKONR and Sharpone like this.
  30. 3blapcam
    3blapcam
    Cool car, and I am enjoying the progress! Keep it up!
    3blap.
