Projects A tale of an English lakes coupe
Discussion in 'Traditional Hot Rods' started by Equipped28, Oct 30, 2024.
  1. AHotRod
    AHotRod
  2. Baumi
    Baumi
    That is both, a great build and first race experience! Sorry you had that door mishap, but from here it looks like you´ve got the perfect skill set to fix it. Beautiful car btw!
    porkshop likes this.
  3. 22 track
    22 track
  4. Equipped28
    Equipped28
    The trunk lid removed itself the first run!
    There is a drop in the dunes along the beach and a crosswind hits at that point if the wind is in that direction which is the same point the door was unlatched. both the doors and the trunklid are un reinforced fibregl*** and extremely flexible. Hence why when the body was on its previous race car they were purely cosmetic and glued shut. But it is in our plans this winter to install new doors with full inners to add some rigidity to them and convert over to bearclaw latches.
    the perils of a belly pan, it stops most of the air getting in, but whatever air does get in then wants to get out too! And finds the quickest way!
    jet996, prez, loudbang and 2 others like this.
  5. Equipped28
    Equipped28
    Small update, currently in the throws of moving workshops so most is halted but we’ve got big plan’s and some updates a foot ready for the next beach race
    But a super cool thing happened, with lots of Tom Cobb chatter on here now there is even more, a while back Joe sent us over a good luck charm in the shape of the original shifter Tom ran in his time with the Pierson coupe! To have something from the car that inspired this whole thing for me all them years back is honestly such a killer thing. And to be something tactile like that shifter complete with what’s believed to be the original shift knob. It’s great to have it be back in a race car and not sat on a shelf! Now we need another transmission AGAIN!
    Kiwi Kev, jet996, Outback and 13 others like this.
  6. Dave G in Gansevoort
    from Upstate NY
    With your transmission experience, you should consider starting your own repair business specializing in those.
    jet996 and porkshop like this.
  7. DDDenny
    Nuth'n more tactile than a clutch pedal and a stick shift handle!
    porkshop and CSPIDY like this.
  8. Tim
    Tim
    from KCMO
    So rad!
  9. Equipped28
    Equipped28
    I already have a full time business repairing rotten early fords!
  10. Equipped28
    Equipped28
    We dont have so much progress on this that can be photographed just yet but plans are afoot for this years race with a bit of a change. I will get back on the updates in the coming months in the mean time I’ve just got another project on the road that I had on the sidelines. A pre war styled 34 roadster, Gl*** body again and stock running gear so far it’s been lots of fun.
    weeman, Baumi, plan9 and 15 others like this.
  11. 22 track
    22 track
    I like seeing what you have in projects and what you have planned for the coupe.
    rod1, Deutscher and Outback like this.
  12. Equipped28
    Equipped28
  13. Mindover
    Mindover
    from England
    I was impressed with the coupe at Pendine. I never saw this thread until now. Only a few weeks until the next Pendine.
    I drove the "Lowflyers" version 37 years ago when it was owned by Tony Cardy. I took my now wife out for a spin in it.
    jet996, rod1 and Deutscher like this.
  14. 22 track
    22 track
    I did not see your lakes coupe in this Pendine video. Was it not ready or did you expect the meet would be rained out, as it apparently was? There appear to be lots of interesting vehicles though.
  15. Equipped28
    Equipped28
    We didn’t make it this year, been abit hectic this end I moved into a new shop for my work so been busy with that, but we are still working away at it. With the upgrades/cl*** change we’ve undertaken on the car, a new motor has been built along with a re configuration of pretty much everything else on the car. But it should be fun. IMG_3653.jpeg
    TheGame, CSPIDY, Dedsoto and 3 others like this.
  16. CSPIDY
    CSPIDY
    Quite the contraption, very kool indeed
    rod1 likes this.
  17. AmishMike
    AmishMike
    Love explanation of all those parts. Guess: New ( bigger? ) blower & drive. Can not see distributor drive? Water pump front of blower. One water pipe under blower to US driver side to back of engine where up & splits to two heads. Feed to water pump from? Nice build!
    22 track likes this.
  18. 22 track
    22 track
    Very Tom Cobb influenced look to the engine. I look forward to your explanation on all the changes after you have finished them and have time to elaborate.
