Featured Hot Rods Pickup bed/box floors. Show me what you did
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Sep 16, 2026.
  1. Roothawg
    Roothawg
    Mar-K went out of business. :(
    VANDENPLAS and bchctybob like this.
  2. guthriesmith
    guthriesmith
    Man…I didn’t know that!
    Roothawg likes this.
  3. Roothawg
    Roothawg
  4. You should repeat that.
    Okie Pete, bchctybob and Roothawg like this.
  5. Roothawg
    Roothawg
    That’s what the wife said.
  6. bchctybob
    bchctybob
    I drove past our local wrecking yard yesterday and thought to myself that I oughta stop and see Gary, he might have a truck bed that I can cut the floor out of. Like some of the others, my pickup will get a tonneau so it doesn’t need to be real pretty.
  7. 2devilles
    2devilles
    Around here a fella can buy a whole non-running '70s-'90s square body/CK or late model Ford or Dodge for a few hundred bucks. Might be able to pick up a later bed or whole truck and cut out a section the size you need out of it, gotta be about as functional as a fella could get, and it'll look "factory".
  8. Roothawg
    Roothawg
    I started looking for marine grade plywood around here....apparently it is made of unobtanium. I need to call my buddy that owns a lumber yard and see if he has a source.
    Okie Pete and Algoma56 like this.
  9. Bandit Billy
    Bandit Billy
    I saw this at a car show a while back and was impressed enough to waste some cloud space on it. The fabricator used tie down bars to separate the wood. Easily insert rings anywhere you like to secure your load or remove them and throw them in a bag behind the seat door a clean look when not needed.
  10. swade41
    swade41
    from Buffalo,NY
    I did a red oak with stainless strip bed in my 57 that's destined to be a shop truck. My intentions were to get the Amish to rough cut some lumber, use painted/powdercoated steel strips and coat the wood in used motor oil. After some thought about the Amish being 2 hrs away, hoping they could cut it right for the strips, doing the drive 4 times, I decided to just price out a kit.
    While researching, I found Brothers parts had a deal going on the oak/stainless kits for cheaper than the pine/raw steel kit plus it had free shipping ! So I unintentionally ended up with a "fancy" bed for my shop truck.
    My t-bucket floor is wood, I used 3/4 marine grade then coated it with epoxy resin, 20 yrs later it's still just as strong as the day it was installed.
    What about using that plastic composite decking material ?
  11. Roothawg
    Roothawg
    Take a gander at the seat track, the next time you fly. I use it on all my trailers. It's been used in commercial aviation for decades. Good stuff.
    Okie Pete, Algoma56 and Bandit Billy like this.
  12. Bandit Billy
    Bandit Billy
    I ran it down the walls of my car trailer, comes in handy to strap stuff to.
    Okie Pete, Algoma56 and Roothawg like this.
  13. Probably just gonna use 5/4 deck boards in mine
    It’s a beater
  14. Roothawg
    Roothawg
    I love it. when I worked in aviation, if it was out of tolerance, it was trash. I would scavenge every piece that got tossed. I used to have tie straps that went over my slicks on both sides of the trailer. Just a safety system. Redundancy is your friend.
  15. Roothawg
    Roothawg
    Where did you find the Ipe? I called all of the local speciality wood stores in OK and no bueno.
    Okie Pete and bchctybob like this.
  16. willys36
    willys36
    Been many years ago but I found suppliers for both Ipe and Tigerwood in a NET search for decking lumber. These aren't Rockler quality cabinet woods, they are literally decking lumber. I mail-ordered the boards. Shipping is a LOT higher nowadays!!
    I just typed in "Ironwood decking suppliers" and here is what Duck Duck Go gave me for suppliers in my area (Greater Dallas Texas);
    If you mean ironwood-style tropical hardwood decking—usually sold as ipe, ***aru, or garapa—these suppliers serve the Van Alstyne/North Texas area:
    • Lee Roy Jordan Lumber — Dallas
      Stocks or sources ipe and other tropical hardwoods for decking. Their Dallas yard is at 11529 Emerald St., Dallas, TX 75229; phone (214) 357-7317. lrjlumber.com
    • Brazilian Lumber — ships to Dallas–Fort Worth and across the U.S.
      Offers ipe, ***aru, garapa, jatoba, tigerwood, decking accessories, milling, and delivery to jobsites. Phone (877) 606-3306. brazilianlumber.com
    • Brazilian Ipe Wood — ships to Texas
      Specializes in Brazilian ipe decking and accepts custom milling requests. brazilianipewood.com
    • Iron Woods
      A national premium hardwood supplier offering ipe, ***aru, garapa, deck tiles, railings, and custom components. Phone (888) 932-9663. ironwoods.com
  17. 2deuces64
    2deuces64
    My 33 is going to be a daily so I'm using late model bed floor thumbnail (42).jpg
  18. Roothawg
    Roothawg
    So, did you have to cut the floor out in the salvage yard? Or did you have to buy a complete bed?
    Okie Pete, bchctybob and osage orange like this.
  19. 2deuces64
    2deuces64
    I bought this one from a friend who has a body shop, it was a take-off that was hit on the side. I cut it out at my shop. I paid $100 for it. I have purchased another bed from a salvage yard that was closing. Paid $50 for it. I have plans for it.
  20. Friend of mine needed a floor for a mid 60s ford.
    Trimmed out a floor from a mid 90s. Looks great
  21. swade41
    swade41
    from Buffalo,NY
    On my 41 I was building (back a couple + decades ago) the bed from scratch to actually haul a load. I made a frame work for the floor out of 1/8 inch angle iron
    Then built the floor out of 16 or 18 guage (don't remember), recessed angled floor in back to get all the gas out the rear facing outlet
    Then shaped the rest with my crude angle iron brake again
    Then plug welded it all to the angle iron sub-structure
    It's plenty heavy enough to haul an engine but in the end there's not much room to haul anything, but ***. In hindsight I could've saved some weight by using 1x1 for the sub-structure and aluminum for the floor.
    The truck turned into a monster, more race than anything else, the heavy bed materials do even out the front/rear weight bias, but it's still 320 lbs heavy on the nose even with a full 15 gallon fuel tank.
    But anyways just showing you can make a bed floor out of just about anything you want, depending on what you think you need.
    1pickup, Okie Pete, Damon777 and 4 others like this.
  22. Roothawg
    Roothawg
    Theres a local guy here on marketplace that has a square body beed floor. He wants $200 for it. I can't imagine a huge demand for bed floors. I need to investigate that a little more.
  23. K13
    K13
    What makes it indestructible also makes it very destructible to blades. It's very difficult to work with as it contains a ton of silica. Also means you should use proper PPE when cutting it as well.
  24. That’s a good price if it’s decent.
    And c10 parts are probably in higher demand that your f100 theses days
    Okie Pete, Roothawg and bchctybob like this.
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    those chevy pickup bed floors are available reproduced for about 500 bucks
    https://www.cl***icindustries.com/p...b7DR7AqSGvEwpVD2o9B2YurHDeERR8qRjrlOAxSJhbXYo
    no sandblasting, no ding and dent repair etc... better yet see your local body shops for take off smashed late model boxes . the floors are probably ok... In any event if you are going to haul stuff what will you do to keep from scratching the paint? put a rubber bed mat in it? in that case It probably doesn't really matter what kind of floor you use???
  26. swade41
    swade41
    from Buffalo,NY
    I will say on my old daily pickup I had the bed sprayed with Line-X, that stuff was impervious to just about anything and everything ! The only thing that ever phased it was using the tailgate as a plasma cutter table, and then it only effected a few small bb size things.
    The bad is that you are not sliding anything in the bed on it, nothing slides on it. I always had to lay cardboard or wood down to slide engines and rear ends in, that stuff was like a glue trap and lasted the whole 22 yrs I owned it.
  27. Roothawg
    Roothawg
    I think if I use a late model bed floor, I will spray it with Raptor. If I use wood, it will probab ly get a rubber mat. There is a high probability that it will never be seen, once installed.
    Okie Pete likes this.
  28. 700-800 chipped on the c10 floors
    Still not bad if you were paying a shop to fix an old one
    Okie Pete and Roothawg like this.
  29. I looked at this photo far longer than I should have trying to figure out why the left wheel house was 6” inbound of the bedside!
  30. 56don
    56don
    Ha, then realized it was a reflection on beautiful black paint. ;)
    deathrowdave and Okie Pete like this.
