Projects Occam’s Razor
Discussion in 'Traditional Customs' started by flynbrian48, Sep 16, 2026.
  1. flynbrian48
    flynbrian48
    The simplest explanation is always the correct one, at least for this. I had upgraded the brakes last year along with the Borgeson steering box, but at the time couldn’t get them bled. Then I busted the windshield and walked away from the car until now. Today I got my power bleeder out and tackled it.
    Fronts bled easily, clear fluid right away, the rear bleeders cracked but no fluid. I started at the front, cracking fittings, fluid everywhere, nothing past the rear flex line . What? 20 years ago when I pulled the car into the garage it had brakes…
    Turned out to be the flex line. I’ve had them fail and let fluid through under pressure but collapse and not let fluid back, hanging up brakes. This wouldn’t let fluid either way.
    Oneball, Cosmo49, Besty34 and 16 others like this.
  2. Clydesdale
    Clydesdale
    Isn’t it Occam’s Razor?
    aaaaaanywho glad you diagnosed it quick, gotta love an easy win after some time away.
    looking forward to reading about more progress on this!!!
  3. flynbrian48
    flynbrian48
    Yes, it is! Thanks, imma fix that too! :oops:
  4. gsnort
    gsnort
    Occam's Razor is correctly spelled.
  5. squirrel
    I had the same problem on an OT car recently...open the bleeder, nothing comes out...loosen the fitting between the metal line and rubber hose, lots of fluid. I was able to poke a piece of baling wire through the hose and get it to work. The hose is only about 20 years old
  6. jaracer
    jaracer
    I remember poking a wire through a plugged flex line to get fluid to go through. I was going to replace it, but it worked so I drove it for a couple of years and sold it.
    Algoma56 and chryslerfan55 like this.
  7. It’ll buff out. Hehe
  8. flynbrian48
    flynbrian48
    So will I, but it'll have brakes...;)
    Okie Pete and anthony myrick like this.
  9. flynbrian48
    flynbrian48
    Well, yeah, NOW it is! :oops:
    05snopro440 and ClayMart like this.
  10. ClayMart
    ClayMart
    I thought it was Occam's Cat.
    And Schrodinger's Razor.
    :oops:
    osage orange and flynbrian48 like this.
  11. Now that's thinking both inside and outside the shaving soap box. I guess it's how you end up with one of those bald, hairless cats that never cough up a hairball.
    flynbrian48 likes this.
  12. 19Eddy30
    19Eddy30
    from VA
    I have dealt with a hand full of
    Blocked rubber line ,
    I cut one one time curious to see why
    I was unable to poke a pick threw the hard crude , but drilled semi
    soft & sticky
  13. ClayMart
    ClayMart
    Well I don't think there's anything else to wring out of that gag! :(
    However . . .
    Okie Pete likes this.
  14. twenty8
    twenty8
    Don't be so sure...........[​IMG]
  15. ClayMart
    ClayMart
    Cole's Law: Thinly sliced cabbage.
    :rolleyes:
    Okie Pete, RodStRace, SS327 and 5 others like this.
  16. bchctybob
    bchctybob
    This clogged brake hose thread is way too intellectual for me…..
    Okie Pete, twenty8, Besty34 and 3 others like this.
  17. flynbrian48
    flynbrian48
    Schrodenger’ brake line can be open and plugged at the same time.
    RodStRace, twenty8 and osage orange like this.
  18. 69fury
    69fury
    from Topeka
    If the job got done in a reasonable amount of time and the OSHA man wasn't there to see it, was there actually a violation?
    This is Schrodinger's Inspection
    -rick
  19. hotrodA
    hotrodA
    NOW I know why I liked machine shop cl*** better.:rolleyes:
    Okie Pete and lothiandon1940 like this.
