Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. 57 Fargo
    57 Fargo
    Man if you weee closer I’d be a buyer.
  2. Come on Lane.....
    Spend the money for a transport & meet one of us at the border! LOL I personally have been to the Sweetgr*** border crossing probably a dozen times over the years:D
    Lloydfest 4 is next week! Still waiting for you to make the long voyage!!!!
    God Bless
    Bill
    https://www.jalopyjournal.com/forum...ar-transport-hauling-open-or-enclosed.614419/
    porkshop, Okie Pete, MMM1693 and 2 others like this.
  3. alanp561
    alanp561
    Got the rear wheel cylinders replaced this morning. Got to wait 'til tomorrow when Alyn is off to bleed them. Then, on to Lloydfest IV:).
  4. Clydesdale
    Clydesdale
    Finally wired in the additional bumper lights on my 51.
    Might help to stop some zombie in a Chinese appliance from running into the back of me.
    01Jazz, 210superair, Robdski and 17 others like this.
  5. 57 Fargo
    57 Fargo
    Bill, I’m going to come one of these years, I’ve been on a few car related adventures this summer and work is busy setting up a new shop in a new town. I’m all out of excuses now!
  6. Lane.
    Myself, Lloyd or one of the others will continue to "rattle your chain" until such time that you are standing in front of us shaking our hands!:p
    God Bless
    Bill
    porkshop, Okie Pete, enloe and 4 others like this.
  7. kls50
    kls50
    No pics today but I got some more done on the wiring. I just hope when I get done and turn the key I don't smell electricy!
  8. Zottel
    Zottel
  9. enloe
    enloe
    from east , tn.
    I have been working on the wiring on the Corvette today. 1 Step forward 2 steps back. I had to take the p***enger side header off because one of the header bolts was cross threading. I got that taken care of. Hopefully I can get it started tomorrow.
  10. 51504bat
    51504bat
    There is always this but don't know if it comes in negative ground or not:cool:
  11. kls50
    kls50
    I don't need to buy any. I always make my own!
  12. atch
    atch
    Alan,
    If you don't get them bled just drive it to LF without brakes and we'll bleed them Saturday.
    Lane,
    I'll be "one of the others."
    I'll be looking for it in Camargo.
  13. 57 Fargo
    57 Fargo
    Mike, I know, I know!!!
  14. Zottel
    Zottel
    Wow, the original stuff from the inventor of darkness himself:p:rolleyes:
    enloe, porkshop, saltflats and 2 others like this.
  15. alanp561
    alanp561
    New wheel cylinders and shoes are in. Re-checked all the brake line fittings. No leaks and the car stops. I think I might have done something right:). It's after noon, I think I'll have a beer:).
    mad mikey, Okie Pete, enloe and 9 others like this.
  16. enloe
    enloe
    from east , tn.
    I’m heading out for Lloydfest tomorrow. We have a few issues to fix on my car
  17. saltflats
    saltflats
    from Missouri
    I just got a truck load of NOS ignition tune up kits and some ***orted other parts. So I started going through the boxes to see what I have figure out a way to market this stuff. Looking like most of this stuff goes as new as early sixty's.
  18. mgtstumpy
    mgtstumpy
    I just had this column shift bracket 3D printed for my 46 Olds from an original, keeping a spare OEM column shift mechanism as I have spare 3D printed shift ****ons. Added Park and OD positions to column. a 3/32" drill bit will be the new locating dowel pin. Today's technology is amazing when replicating obsolete parts. 9OwUtfbB.jpg ZaSAQzN4.jpg _3DPVJbJ.jpeg mVbY4dnW.jpg 7QjgDpcI.jpg ofkOkqsl.jpg
  19. deathrowdave
    deathrowdave
    from NKy
    IMG_0852.jpeg Just switched this one today from positive earth to negative earth and calibrated it for 8 cylinders
  20. hrm2k
    hrm2k
    P***enger side requires no more work other than the hot pipe and the blow off valve. Hard to believe but we are finally getting there. I am so stoked to be at this point in the build. Both sides would have been done if I had not ran out of Argon for the TIG welder. still need to run the oil lines and returns. We still have to do the new distributor and spark plug wires IMG_7234.jpeg
  21. HOTRODNORSKIE
    HOTRODNORSKIE
    Stabbed the the rocket in the Olds for the first time since 2018 when I pulled it to paint the car. 20260912_144440.jpg
  22. Got my rough running/hard starting/dying engine figured out. Changed out the condenser and everything's back to normal. I recall leaving the ignition on overnight some time ago and from then on it was just not running right, or most times not at all. Note to self: pull the damned key out of the ignition when you walk away from the hotrod!
    Changing out the condenser took all of 10 minutes. The rest of the afternoon I spent on the drill press, the grinder and the cutoff wheel making a crude, threaded pill to hang the p***enger-side rearview mirror. It's primitive but effective. I'm thinking of taking the '29 Model AA for its first drive tomorrow down my 3/5ths of a mile driveway and back. My son's coming in from Chicago and I'll ask him to ride shotgun on the maiden voyage. I've actually driven it up the driveway once after getting it off the rollback when I took it to my transmission guy to fine tune the TV cable. That was over a month ago now and I've been fighting the ignition battle since then. I also tightened up the steering box and adjusted the brakes - two things that alarmed my transmission guy during his test drive.
  23. saltflats
    saltflats
    from Missouri
    That sounds like good news. Have fun with the kid.
    enloe, mad mikey, porkshop and 4 others like this.
  24. Finally dropped the Desoto Hemi into the Deuce.....
    rod1, Deke, alanp561 and 20 others like this.
  25. rod1, Bill's Auto Works and porkshop like this.
  26. swade41
    swade41
    from Buffalo,NY
    I trimmed my drag link spacer almost in half that I added to the steering arm during my build process
    Couple years ago when I removed half the springs to free up the suspension it made it run uphill, but drove fine
    I always zeroed in on that when looking at it from the front, so I finally took care of it.
  27. kls50
    kls50
    No pics, but I managed to install the turn signal switch and wiring, new circuit breaker, ignition switch, cigar lighter, door jamb/switch wiring harness and other replacement part under the dash. What a pain. I also didn't have brake lights when all was said and done so checked the brake master cylinder and it was low on fluid. Filled the brake fluid and replaced the brake light switch and all is good. Only burnt 3 fuses! I'm starting to install the rebuilt steering box and painted column/parts/wheel/tomorrow. I might get a ride in yet this year1
  28. deathrowdave
    deathrowdave
    from NKy
    Nice lookin TIG weld there my friend . Looks like you didn’t pick it up a week or two ago
  29. deathrowdave
    deathrowdave
    from NKy
    I’m pushing for next week Tiger heart transplant
  30. swade41
    swade41
    from Buffalo,NY
    My ch***is builder friend (same guy who built the ch***is as a matter fact) did that for me, "A man's got to know his limitations" lol
