Technical we need a dedicated 261 thread.
Discussion in 'Traditional Hot Rods' started by hotdamn, Apr 5, 2011.
  1. wuga
    wuga
    It was said when I sunk my intakes, that I was giving away compression. I don't think I removed as much as the relief in those pistons. That being said, I would love a set of those pistons. I am currently running a McGurk roller cam.
    Warren
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    They're the only ones that I've seen in the flesh. It's unfortunate that there aren't six of them.
  3. Cosmo49
    Cosmo49
    Need to get this set of 261 standard bore in the For Sale section.
  4. Casual 6
    Casual 6
    from Great NW
    Since we're on pistons, here is one of my spare Ross 261 High Compression pistons:
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    They weren't cheap!
    Cosmo49 likes this.
  6. Timchek
    Timchek
    Just found this thread! Picking up two 261 cores in a couple of weeks. Incredible amount of information posted here over the years! Hope to replace my 216 in the roadster in a year or two with 261 built with a bit of at***ude, something that mighta been found in an early 50s rod. :eek:
    Baumi, LAROKE and tractorguy like this.
  7. Timchek
    Timchek
    So on my way home pulling a UHaul box trailer. Picked up my two complete EBay 261’s, one with the full flow filtration capability, one without. Turns out the gentleman had a complete 848 head in the shed as well, that’s also in the trailer! Scored a 12v starter and generator, flywheel and bell housing for the engines as well.
    Pretty excited about it all, going to have to have to set this stuff aside for awhile as I really want to get the Pontiac roadster on the road this spring and the 216 currently in it runs well.
    I think all the bolt on speed equipment on my 216 aside the center bolt valve cover fits these engines, but as I’m intending to sell the 216 complete I’m going to be looking to acquire new parts for this engine. Carlisle swap next week, I’d like to find a triple single barrel manifold instead of the dual intake I have on the 216, I like the idea of a IMG_8129.jpeg IMG_8131.jpeg IMG_8132.jpeg progressive linkage.
    Appreciate any thoughts!
    Al
    jimmy six and tractorguy like this.
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    You can use the 216 valve cover on the 261 by using the early retaining studs.
    Cosmo49 likes this.
  9. gassersteve
    gassersteve
    216 intake ports are smaller than the 235/261 so you will need a set of adapter rings
  10. Timchek
    Timchek
    Heathen, thanks for the info, I’ll havta find a set of those studs as I won’t want to steal them out of my 216.
    G***erSteve, I had the mistaken impression that all the manifolds for these stovebolts were the same. Proves once again why ***-U-me is spelled as it is. I’ll havta find the later model triple intake, did some research on the Speedway site and educated myself on the differences. Thanks!
    Al
  11. Gofannon
    Gofannon
    216 intakes use small base carbs, 235 large base. For a triple carb intake, you'd be better to use a 216 intake with adapters, or machine it for larger ports. 3 large base carbs are way too much unless you've extensively modified your engine.
    Robert J. Palmer likes this.
  12. carbking
    carbking
    Al - if you put on a 3 carb manifold, consider NOT using progressive linkage!
    How many Austin Healeys, Jaguars, or other performance inline six cylinders engines can you find with three carbs AND progressive linkage???
    Size the carbs to the engine, and use solid linkage.
    Jon
    302GMC likes this.
  13. Timchek
    Timchek
    Jon, my thought was that with a centrally located primary carb and two secondary’s on the ends that the driveability would be better off idle. Back in the day had experience with two different tripower setups on v8’s, one a factory Pontiac unit the other a small block with an Offy and that’s how they were set up.
    Been over 40 years since I worked in a shop with jags n healeys and the occasional triumph, and I don’t ’member a lot of details but some of those I think were variable venturies like motorcycle carbs and not sure they all had common manifolds?
    This 261 will not b stock, hope to get the compression up to around 9 to 1 and put a decent cam in it so it has a bit of an at***ude and a significant lope at idle.
    To your point, I do have a concern about driveability off idle, especially with a bit of a cam in it and hence my thought to use the center carb as a primary with progressive linkage?
    Al
  14. carbking
    carbking
    The only way for you to know for certain is to try it both ways. If you do an honest set of tests, I am pretty sure how you will end up doing it.
    If we were still restoring carbs and building multiple carb setups (in 60 years, I built a few, still have a few dozen) and you asked us to do it progressive, we would have politely suggested that there might be others that would do that for you.
    The V-8's with tripower do indeed run better with progressive linkage than with solid (but never as well as a single 4 or dual 4's).
    Let us know how it turns out.
    Jon
    tractorguy and Gofannon like this.
  15. Gofannon
    Gofannon
    I'm hoping to fire up my GMC with Rochester Tripower soon. I modified a stock GMC manifold with 5 1/2" carb spacing so I could use off the shelf linkages etc. If it's too much carb, I'll switch to 1bbls, either Carter W1s or Stromberg BXOVs. I can't see how fuel distribution is any worse than a single 4bbl that a lot of guys are running successfully. A guy down here that has run a GMC dragster for a number of years thinks the small base 2bbls won't be enough carb. I figure they flow about the same as 5 x 97s. My thoughts are the same regarding running progressive 1bbls with secondary carbs, but that will require a lot of mods including making thicker throttle plates for the secondary carbs. I have a 261 I want to build someday, although a bit milder than this GMC.
    tractorguy and Robert J. Palmer like this.
  16. 1968pickup
    1968pickup
    from ND
    This is supposed to be a 261 but I have my doubts with no captains bars what are your guys thoughts
    Cosmo49 likes this.
  17. There are supposedly some 261s without Captains Bars
    I have a 261 with a single Lieutenant’s(?) bar
    However a 1961 should have a full flow full pressure oil filter.
    tractorguy and Cosmo49 like this.
