My first bodywork job
Discussion in 'The Hokey Ass Message Board' started by Ajtofelfa, Nov 25, 2006.
  1. Ajtofelfa
    Ajtofelfa
    Thought I'd share with the board that I did my first bodywork job yesterday. I didn't have great expectations knowing my talents towards these kind of things, but in the end it turned out quite nice. I made replacement panels for the trunk in my 48 Olds. The original trunk is mostly gone, I'll have to build a completely new one. I used my brother's planishing hammer and it did a great job.
    Here's the original marked where the new panel should be made:
    And here the patch panels I made for both sides:
    I've already cut the big flat part, too, just don't have a photo of it. This is the right side of the trunk pan as it is now:
  2. rodrelic
    rodrelic
    Can't think of a better place to start out with it. Slow and thoughtful and it will work out. I have had to go back and cut something back out, slice it and re-tack to take out a wrinkle, etc... ain't and won't be an expert. But good enough for my girlfriends. They do the paint, "putty" work, I get to sand it.
    Impatience, speed will spoil the job and fear will keep it at a standstill, I stay somewhere in between.
  3. CptStickfigure
    CptStickfigure
    from Urbana, IL
    Dumb question time!
    How did you bend the pieces in the second picture? The stairstep-shaped ones. I've bent up a few pieces like that, where you've got one bend running perpendicular to the others, and they never seem to come out right.
  4. Ajtofelfa
    Ajtofelfa
    First I bent the edge on the side that's a bit shorter, then the one with the wider sides. Then I made a notch along the marking using a cut-off wheel in a grinder and bent it on an anvil with a hammer.
    The hard part in making this piece was that the angles are steep so it's completely flat on one end and almost rectangular on the other. So I bent the whole angle first and then flattened it progressively with the planishing hammer.
  5. hudsoncustom
    hudsoncustom
    Looks real good.
  6. 49ratfink
    49ratfink
    they got 48 oldmobiles in Hungary?
  7. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Great job on your trunk floor. do you have any pictures of this
    project completed, and especially any pictures of your brothers
    planishing hammer . What brand is it?
    thanx,
    s****ey devils c.c.
  8. Ajtofelfa
    Ajtofelfa
    "They" don't. I do. :D
  9. Ajtofelfa
    Ajtofelfa
    Hi,
    It's not finished yet, I still have to fabricate the rear part of the pan and then weld it in. I'll keep you posted in this thread. The hammer is nothing special, just an ebay pick I bought last year. It's more or less the same as this one: http://cgi1.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260056575507
  10. abonecoupe31
    abonecoupe31
    from Michigan
    Ah, another Project "Big Olds"....
    Nice looking parts!
    Keep up the good work...
