Marine 3x2 rochesters
Discussion in 'The Hokey Ass Message Board' started by ditz, Dec 2, 2006.
  1. ditz
    ditz
    I have just aquired what I believe is a matched set of the small Rochesters and I think they came off of a boat. The base of each carb has 2 adjusting screws and there is no choke. Other than rebuilding them, are they useable as they are for automotive? If not, what needs to be modified for automotive use?
  2. sixpac
    sixpac
    from Courtenay
    The car tripowers only have idle crcuits on the center carb. There is a choke on the center carb only. The front and rear carbs only drop fuel and air. There is no vacume ports on the end carbs. I would suggest doing some research on the internet or maybe find someone with a tripower set up for you to look at. All the best John
  3. tommy
    tommy
    Other than the flame arrestor aircleaners(very cool), there is nothing different in the carbs. They work exactly the same way.
  4. ditz
    ditz
    Thanks Tommy, that is what I wanted to hear.
