Gasket Maker (How long does it take before..)
Discussion in 'The Hokey Ass Message Board' started by crusader, Dec 9, 2006.
  1. crusader
    crusader
    How long does it take before I should drive? I put this on my rear of my oil pan in front of the flywheel. It says 24 hours to fully cure but do I really need to wait that long? :confused:
      43.6 KB
  2. Anderson
    Anderson
    If it says wait 24 hours...I would wait 24 hours.
  3. Thirdyfivepickup
    Thirdyfivepickup
    dunno, how easy is it to pull the pan down and fix it if it leaks?
  4. seymour
    seymour
    from PNW
    No, the mfg know nothing about it's product. Drive that ****er! :rolleyes:
    I've seen worse questions here, but I just can't remember when.
  5. crusader
    crusader
    WTF? Just because a MFR puts a recommendation doesn't mean it's always the same amount. Most company's do a lot of CYA by making the number a lot larger then the real time.
    Maybe I should reword my question. Has anyone ever used this RTV before and driven it in less time than the MFR recommendations? If so, what were the results...
  6. seymour
    seymour
    from PNW
    While we're on the subject, my Motor's manual tells me that I need to torque my flattie to 65-70 ft/lbs and to work my way up to the final torque in 2-3 steps. Can't I just reef 'em down once and get it over with already???
  7. FWilliams
    FWilliams
    if your trying to cure a leaking oil pan seal by using that stuff on the outside of the pan, you better wait as long as you can...and I still dont think it will work for ya, you would be better off to drop the pan and replace the seal
  8. Anderson
    Anderson
    You're right. I'd guess you could drive it in 12 hours. When it starts leaking, re seal it, then wait 13 hours and drive it. When it starts leaking again, reseal it and drive it in 14 hours. When it starts leaking again, reseal it and drive it in 15 hours. When it starts leaking again...
    let us know what happens.
  9. crusader
    crusader
    Thank you for answering my reworded question with the maturity of a 10 year old.
  10. crusader
    crusader
    Again, maturity comes into play...
  11. seymour
    seymour
    from PNW
    Dumb questions have dumb answers. Maturity?................ hahah.... hey neophyte, go turn some wrenches.
  12. s.r.i.
    s.r.i.
    from Hell
    ****Hides for cover***** INCOMING!!!!!!!!!!!!!!!!
  13. seymour
    seymour
    from PNW
    Where's 3WLarry with that stolen pic of the baby? :D
  14. Thirdyfivepickup
    Thirdyfivepickup
    he stole it from me... and I stole it of the interweb
  15. crusader
    crusader
    That's one of the biggest problems with the internet and forums in general. You get too many people who will write things they would never say in to your face. Internet courage, just a mouse click away...
  16. bulletproof1
    bulletproof1
    from tulsa okla
    take it back and get RITE STUFF made by the same folks.let it set a long enough to clean up your mess,put up your tools .
  17. Mr. Creosote
    Mr. Creosote
    Patients Gr***hopper.... Be tolerent of the silicon.. allow it to have its own time before trusting it to hold back the torrants of hot oil. 24 hours will p*** before you know it.
  18. seymour
    seymour
    from PNW
    Yeah, most people don't call others immature when they're asking a question.
    "When arguing with an idiot, make sure they're not doing the same." That's why I refuse to argue.
  19. Anderson
    Anderson
    I think even a 10 year old would have been smart enough to read and follow the directions. Good call on that one...
  20. jusjunk
    jusjunk
    from Michigan
    **** it torque it drive it .. them people dont know ****.
    Dave
