I'm rebuilding the tailigate on my '53 chevy wagon and would like to replace the hinge while I'm at it. It's a 52" long piano hinge. Since you can see the hinge from the back of the car, I'd love to replace it with a chrome one, but I'll settle for a painted steel hinge. Anyway, does anyone know a good source for large piano hinges?
I thought I seen where someone was repop the 49-54 chevy wagon hinges. Unfortunately I can not remember who
I found what I was after, in stainless with no holes. I can drill it to match what I've got and then polish it. Thanks for the help guys.
Check this place out. http://www.austinhardware.com/ Great source for hinges, latches. A lot of fire truck / mobile vehicle manufactures use stuff from them. McMaster Carr and Grainger would be good as well.
I used to use them on the hoods that I build. I tried the hardware store ones. They are nickle plated or br***. But better yet are the ones from McMaster-Carr. A large industrial supply house in Chicago. You can buy any kind you want. Folded Offset Hinges with Offset Leaves When the hinge is folded, the distance between the leaves is larger than the pin diameter. Commonly used for gasketing applications. See pages 2844-2845 . Surface-Mount Piano Hinges Don't see the piano hinge you need? Just tell us what you're looking for and we'll get it for you. Unfinished Steel Piano Hinges without Holes You decide how to surface mount these hingesthey don't have mounting holes. Spot weld them in place or drill holes for rivets or screws. Hinges can be cut with a hacksaw. Pins are made of steel. From the folded position, the range of motion is 270° . Open Pin Knuckle 3-ft. Length 6-ft. Length Wd. Dia. Lg. Each* Each* 0.025" Thick Leaf 3/4" 1/16" 1/4" 15665A209 $1.36 15665A212 $2.18 1" 1/16" 1/4" 15665A211 1.39 15665A213 2.42 0.035" Thick Leaf 3/4" 5/64" 1/4" 15665A162 1.86 15665A105 3.10 1 1/16" 5/64" 1/4" 15665A164 2.04 15665A115 3.10 1 1/4" 5/64" 1/4" 15665A165 2.31 15665A123 3.29 Open Pin Knuckle 3-ft. Length 6-ft. Length Wd. Dia. Lg. Each* Each* 0.035" Thick Leaf (Cont.) 1 1/2" 5/64" 1/4" 15665A166 $2.48 15665A128 $3.76 0.040" Thick Leaf 1 1/16" 3/32" 1/2" 15665A145 2.26 15665A136 3.22 1 1/4" 3/32" 1/2" 15665A2 2.24 15665A143 3.44 1 1/2" 3/32" 1/2" 15665A3 2.44 15665A151 4.70 2" 3/32" 1/2" 15665A4 2.84 15665A156 4.38 * Prices are 15% to 20% lower if you buy 10 or more hinges of the same size. Open Pin Knuckle 3-ft. Length 4-ft. Length 5-ft. Length 6-ft. Length 8-ft. Length Wd. Dia. Lg. Each* Each* Each* Each* Each* 0.050" Thick Leaf 1 1/16" 1/8" 1/2" 15665A167 $3.03 15665A172 $3.78 15665A186 $4.21 15665A163 $4.47 15665A187 $5.95 1 1/4" 1/8" 1/2" 15665A5 3.10 15665A8 3.92 15665A9 4.30 15665A168 4.86 15665A1 6.05 1 1/2" 1/8" 1/2" 15665A6 3.31 15665A174 4.12 15665A175 4.39 15665A176 5.19 15665A11 6.45 2" 1/8" 1/2" 15665A7 3.58 15665A181 4.39 15665A182 4.83 15665A183 5.54 15665A12 6.73 0.060" Thick Leaf 1 1/16" 1/8" 1/2" 15665A13 3.47 15665A802 4.32 15665A41 5.10 15665A215 5.15 15665A54 6.61 1 1/4" 1/8" 1/2" 15665A219 3.95 15665A29 4.82 15665A42 5.54 15665A223 5.65 15665A225 7.49 1 1/2" 1/8" 1/2" 15665A14 4.01 15665A146 5.16 15665A43 5.80 15665A231 6.11 15665A233 8.02 1 1/2" 3/16" 1/2" 15665A15 4.21 15665A236 5.41 15665A237 5.97 15665A238 6.91 15665A241 8.24 1 1/2" 3/16"1" 15665A16 4.60 15665A31 5.97 15665A44 6.58 15665A112 7.06 15665A113 8.55 1 3/4" 1/8" 1/2" 15665A171 4.42 15665A178 5.45 15665A185 6.13 15665A246 6.43 15665A188 8.47 2" 1/8" 1/2" 15665A17 4.91 15665A32 6.27 15665A45 6.82 15665A253 7.35 15665A255 8.78 2" 3/16" 1/2" 15665A18 5.55 15665A258 6.78 15665A259 7.49 15665A261 8.10 15665A262 9.58 2" 3/16"1" 15665A19 5.74 15665A33 7.16 15665A46 7.82 15665A114 8.48 15665A117 10.09 2 1/2" 1/8" 1/2" 15665A264 5.45 15665A34 7.37 15665A47 8.28 15665A267 8.84 15665A269 10.13 2 1/2" 3/16" 1/2" 15665A22 6.27 15665A35 7.78 15665A48 8.55 15665A275 9.23 15665A55 10.39 2 1/2" 3/16"1" 15665A23 6.44 15665A36 8.00 15665A49 8.79 15665A118 9.37 15665A119 11.08 3" 1/8" 1/2" 15665A24 6.60 15665A37 8.04 15665A51 8.87 15665A283 9.52 15665A285 11.17 3" 3/16" 1/2" 15665A25 6.74 15665A288 8.48 15665A289 9.43 15665A291 10.16 15665A292 11.83 4" 1/8" 1/2" 15665A26 7.00 15665A38 8.78 15665A52 9.60 15665A296 10.33 15665A297 12.97 4" 3/16" 1/2" 15665A27 7.42 15665A39 9.68 15665A53 10.61 15665A298 11.45 15665A56 14.40 * Prices are 15% to 20% lower if you buy 10 or more hinges of the same size.(Continued on following page)2840
