Flathead + Mustang T5 trasmission
Discussion in 'The Hokey Ass Message Board' started by sutn, Dec 10, 2006.
  1. sutn
    sutn
    The S10 T5 bolt pattern is different than the Mustang T5. All of the adapters I could find are for the S10 bolt pattern.
    Are there any adapters for the Mustang transmission to a 32-48 flathead?
  2. 50shoe
    50shoe
  3. Flat Ernie
    Flat Ernie
    Tech Editor
    I believe Vern Tardel sells an adapter. There's also one from Australia I think - Macs or something like that??
  4. LIMEY
    LIMEY
    I picked one up from Squeek Bell in Bakersfield......he stocks both the GM & Ford type made by Macs, nice heavy casting & uses the stock Ford release arm & shaft.
    Kev.
  5. krylon32
    krylon32
    from Nebraska
    Shadow Rods, the guys with the 27 roadster on roids makes a nice piece.
  6. sutn
    sutn
    I couldn't find a website. Do you have a link?
  7. LIMEY
    LIMEY
  8. kantgetnun
    kantgetnun
    you need to be carfull i have a mustag t5 and the in put shaft was too long so I had to make a spacer let me know if you need one plus I have a spare stamped bell housing
  9. Flat Ernie
    Flat Ernie
    Tech Editor
    What year Mustang? The '94-95 Mustangs used a .75" longer input shaft. These are fully interchangeable with earlier input shafts as long as it has same gear ratios (approx '89-up)
  10. sutn
    sutn
    The one I plan to use is an 87-93 (shorter input shaft)
    Do the S10 tail housings simply interchange, or is there some modification needed?
  11. Flat Ernie
    Flat Ernie
    Tech Editor
    You need both the S10 tailhousing AND the S10 top cover to complete this conversion. Also, there's a little plastic funnel at the end of the countershaft behind 5th gear that sits into a machined recess in the tailhousing. They are different between WC & NWC and need to match the tailhousing, so if you can get the one from the S10, get it.
    Your speedometer hole will no longer line up with your speedometer gear - see the inliners.org site in the other post to see how one ingenious rodder got around that.
    Somewhere, I have a list of speedo gears for the Ford application & what's needed to get your speedo close...
