fuel tanks in Model A's
Discussion in 'The Hokey Ass Message Board' started by FWilliams, Dec 12, 2006.
  1. FWilliams
    FWilliams
    what have you guys done for fuel tanks in your coupes, I want to put it in the trunk area, but havent found one that I like the fit.....I dont care for the round dune buggy style, and I would like something I could possibly put a sending unit in.maybe fuel cell?
    thanks,
  2. flt-blk
    flt-blk
    from IL
    If you run fenders you can use the TANKS brand ones that go behind the running board aprons.
    I have a friend that made a wierd shaped tank under the floor with a notch for his battery. I made him put in a driveshaft loop just in case.
    On my truck I made my tank under the bed and the back of it is the rolled pan.
  3. jetmek
    jetmek
    the problem with the tanks-tanks is you have to rock the car to get the one on the far side full....btw flt blk that stude in the cl***ifieds is wicked. just sold my 53 resto-rod champion and got very close to that price. yours is a bargain with all the mods!
  4. Chopperman
    Chopperman
    I'm using this in my 31 5w A coupe
    75.00 w/ sender. Keeping the stock tank cause it's cool.
  5. Crusty Nut
    Crusty Nut
    Chopperman, where did you get that for $75?
  6. hot rod wille
    hot rod wille
    I used a Tanks 14 gal universal tank in my 29 roadster---used a ski-boat filler in the back panel--tank has sender--fuel line from the top plus a roll-over vent-- www.tanksinc.com ----the tank I used is a US-1
  7. HotRodHon
    HotRodHon
    Same question. Where'd ya get it and how many gallons do it hold?:eek:
    Craig:cool:
  8. peanut
    peanut
    i have a repop T oval tank in my A.with some old air comressor tank feet.
  9. Chopperman
    Chopperman
    Fellow Hamber willing to part with it.
  10. Slag Kustom
    Slag Kustom
    look in a bone yard for a jaguar xjs. tank is the perfect shape to fit in the front of the trunk from what i remember
  11. Roothawg
    Roothawg
    Fred, look at Rolf's tank. I think it may be the way we are heading with ours.
  12. Roothawg
    Roothawg
    Fred. Here it is.
  13. yblock292
    yblock292
    Not only that but the guy at "tanks" is the ****s to deal with!I had one and only dealing with them, will never go back!
  14. Gator
    Gator
    from Statham Ga
    I have a model T oval tank in mine, sat down low behind the rear diff. I think it's 10 or 11 gallons.
  15. Ran a couple of in trunk tanks in my coupe. Finally changed it out with a 32 style tank. Liked it better, no smell and nothing in the way to fill it. Back to running a inside tank on the hiboy roadster though.
  16. Attached Files:
  17. Yo Baby
    Yo Baby
    Ideas that are slightly outside the norm.
    A Volkswagon tank has a nice shape on the bottom that would prolly fit the contour of a rear end pretty well.Has center bottom outlet and a gauge.If it was mounted right in the floor it would only take up a little space (Oh hell you've seen a Volkswagon Beetle before you know what the profile above the foor looks like)and would let ya use the trunk for what it was meant for.LOL
    Or how about the stock A tank with no gauge just reserve style valve like Motorcycles and early Volkswagons.
    I always liked the way the cap looks in the center of the cowl especially a flip top.
  18. Fred, try Overton's, they are a boat supplier. I think it is www.overtons.com
    They offer many poly tanks at a good price, SW sender included.
  19. bobbleed
    bobbleed
    from Awesome
    Sidevalve the owner of the Hot Rod Company sells an oval model T tank that is great...... he has them in stock laid down position and custom stood up positon.... they are really nice and with the two styles there are alot of options for placement...
  20. AnimalAin
    AnimalAin
    My roadster has a tank that fills the footwell for the rumble seat. Limits the rumble to kids only, but the tank holds substantially over 20 gallons.
  21. Gator
    Gator
    from Statham Ga
    Great guy to deal with too, and is an Alliance member to boot.
  22. usmc50lx
    usmc50lx
    from St.Louis
    Using a T oval tank it fit between my seat and rise in trunk floor and have a sender in the top of it
  23. HotRodHon
    HotRodHon
    You da man.:D
    You just saved me about 100 bucks.
    Craig:cool:
  24. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Hi Fred
    here is mine
    I wanted it m***ive... So I could drive distance.... not much room except for a few tools and some bevrages.
    I travel alone, so my duffle bag sits up front.
    All aluminum.
      80.9 KB
      80.4 KB
  25. Jeff Norwell
    Jeff Norwell
    MODERATOR
    As a side note Fred..I now have early bucket seats, where as I had a bench seat before.......and I could prolly get alot more room in the trunk.
    I believe the capacity is around 20-25 gallons.
    works good for me.
  26. This is a question I've thought of a lot. I realize the risk of running the fuel in the stock gas tank... but does anyone do it? Don't mean to high jack the post, just something I've wondered about. Probably a pretty stupid question, but what the hell.
  27. Gotta give credit to my pal Dean, he turned me onto them.
  28. atch
    atch
    i've never owned a model a, but i have several friends who've run the original tanks in hot rods. at least a couple were built back in the 70's and have about a zillion miles on them. not one that i know of has ever had any problems with utilizing the original tank.
  29. FWilliams
    FWilliams
    I dont know Jeff, that kinda looks like a canadian moonshine running tank to me:D
    thanks loads guys that gives me plenty of avenues to check out, much appreciated.
    Fred
  30. Yankeyspeed
    Yankeyspeed
    I picked up an OLD Ford and sons tractor tank. It holds about 10. Nice shape too.
