How does it look so far?
Discussion in 'The Hokey Ass Message Board' started by dieselc, Dec 27, 2006.
  1. dieselc
    dieselc
    from ohio
    Well here it is so far what do you guys think. Iam runnin a 9 inch rear 41' front axle,split bones, and brakes. a 57' olds 371 want to put a standard behind it if I can find a flywheel. Its chopped 4" channeld 4". Just keep workin on it when I get the time to.
  2. 32chevysedan
    32chevysedan
    from Texas
    Lookin good..............
  3. Royalshifter
    Royalshifter
    Moderator
    Looks good man other than watch bone clearance under the cowl.
  4. dieselc
    dieselc
    from ohio
    I have 1" clearence between the cowl and the wishbone I think that should be enough. I would also like to put a different dash in it something in the 40's-50's not sure though.
  5. jetmek
    jetmek
    so far so good...hope your gonna box that frame
  6. Danimal
    Danimal
    Nice. Plus you get to work indoors...I'm still working on that one.
  7. Talky
    Talky
    from Calgary
    looking good...
  8. Dirty2
    Dirty2
    Looks mighty fine .
  9. Lowbrow52
    Lowbrow52
    Looks awesome. Keep us updated!!!!!!
  10. Grinderspark
    Grinderspark
    Looks like decent progress. I just wouldn't want to hit a bump in that thing and smack those frame horns all to $%#@.
  11. AHotRod
    AHotRod
    Your making great progress!
    How much suspension travel do you have in the front?
    From the angles of these pictures, it appears as though you'll need to put a spacer between the front leaf spring and the ch***is to keep the front axle from hitting the ch***is.
  12. brandon
    brandon
    was this sitting in ky for a little while.....? brandon
  13. dieselc
    dieselc
    from ohio
    Yeah I was in a shop ther for about a year but I had a disagreement with the red neck next door and he brought over a gun so I figured it was time to move on.
  14. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    looks good so far.
  15. Wildfire
    Wildfire
    Keep going - it is coming together.
