stock model a steering ?
Discussion in 'The Hokey Ass Message Board' started by zimm, Dec 30, 2006.
  1. zimm
    zimm
    from iowa
    is any one runing stock A steering
    im thinking about runing a stock setup w/ a 2.3 ford and t5
  2. Stock is ok if it is in good shape. All the parts to rebuild are easly obtained from your local A parts house. We often shorten the pitman arm 1 1/2"- makes steering a little easier.
  3. peanut
    peanut
    they suck i have one and it blows. get a f1 or something else.
  4. Ace Brown
    Ace Brown
    from OH
    i've been running an A box in my A sedan for a little over a year. i plan on changing mine over to something else soon. my starter is on the drivers side so clearance is my biggest issue and why i used the A box in the first place. i ended up moving it forward 3 1/2" and had to angle it back a few degrees. it's worked well, just a little sloppy. the F-1 works well but the steering shaft enters the box at the bottom, whereas the A enters from the top. sometimes you will have clearance issues. The F-1 would definitley be better than the A box, or even a later F-100...or reversed corvair...or i hear toyota boxes work nicely too :)
  5. 5window
    5window
    Gee,I am just not sure I'd trust my steering to something 75 years old. Even if it was a new repro unit, it wasn't designed to run at your speed or horsepower. Just a thought.
  6. BRENT in 10-uh-C
    BRENT in 10-uh-C
    That's a wierd statement!
    A stock Model A steering box (7 tooth or 2 tooth) can more than capably handle the speed and thrust of what Zimm is wanting to do. It is evident you have never been around a rebuilt one. Maybe you should drive down to Tennessee and let me educate you & Peanut on how they should be.
