cheap bench grinder at big lots
Discussion in 'The Hokey Ass Message Board' started by hotrod54chevy, Jan 12, 2007.
  1. hotrod54chevy
    hotrod54chevy
    from Ohio
    well,i was out with the little woman today lookin at junk and whatever else i could fit in my grubby mitts before we got a cart and what did i find?a bench grinder for $25! yeah yeah,it's some no-name-made-in-taiwan stuff but for the price it'll be decent if it lasts for a few uses.beats bustin out the hand grinder and worryin about losin my 5 best friends!!i havent used it yet so i cant comment on the quality.anyone else pick up one of these?
    creepy
  2. Kustomz
    Kustomz
    You have to watch the cheap power tools. I bought a chinese angle grinder and it doesn't carry hardly enough amps to carry a good load on the disc and it gets really hot, but what did I expect for $10?
  3. Never Die
    Never Die
    I have an el-cheapo 3/4HP bench grinder... I think I paid $25 for it and the stand. It was cheap and a no-name, but it works just fine and is actually built pretty solid feeling, metal casing and such. Pretty powerful, I've never bogged it. The only gripe I have is that I had to bolt the stand to floor because it vibrates itself around like crazy, it would literally dance all over the garage.
  4. FastJaggersSC
    FastJaggersSC
    if had no real complaints w/ my cheap harbor freight tools. Even better now that a lot of the tools there have that lifetime guarantee for an extra $10.
  5. Redneck Smooth
    Redneck Smooth
    from Cincinnati
    I have that Big Lot's bench grinder, must be an Ohio thing. I also got a $10 drill there that works great...
  6. Soviet
    Soviet
    I got a 20 gallon contractor ShopVac, 20$. Freaking amazing.
  7. Jimv
    Jimv
    alot of times if your using something ( a tool) once or twice a week you can get away with the cheaper tools,when you have a shop or make a living with them you have to get better quaility.
    I had one of those cheapo bandsaws where i work for ever & its fine.We get those "traveling" tool shows going thru & i buy **** all the time from them, no problems yet.(knock on wood).
    Druss32 I bet if you looked at a few things on that grinder you could get it going. Probably just a pinched wire or disconnected.
    I noticed that alot of the chinese tools aren't bad, we give them specs they build it to those specs, if the workers **** up over there they shoot ya!!!! Thats great quaility control!!Very insperational!!lol
    At those traveling tool sale you can even buy a chinese pellet gun for $20 that pretty good for keeping strays outta you garbage!!
    JimV
  8. You can put an eye out with that gun Jim.....................................
  9. I've got one of the same bench grinders...had it about 5 years. It will bog down pretty easy but if you take your time it'll do ok.
  10. I don't like to cheap out on tools, always get the best tool you can afford.
    I have to admit, I bought a cheap benchgrinder about 8 years ago for $50, it still works but it isnt exactly my first choice since I had my 50 year old Baldor grinder I bought 3 years ago, for $30 used.
    Tools were made so much better back in the day.
  11. Shifty Shifterton
    Shifty Shifterton
    I just did a $20 chineese bench grinder pedestal. Castings on both ends, and a single 3 inch tubing leg. Welded the pieces to make the whole thing stable, and added about 25 lbs of lead wheel weights to the tube before sealing it up. Did a great job of putting the m*** low and damping vibration. Nicest freestanding grinder pedestal I've ever used, and a great budget solution. Probably lots of **** you could drop in the tube for the same effect.
