How wide is the wide 5 pattern on 36-39 Fords?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Sep 15, 2003.
  1. Roothawg
    Roothawg
    Is it 5-1/2"?
  2. cadlights
    cadlights
    from Hooper, Ut
    9 1/2 inches across. 6 inches bolt to bolt next to each other.
  3. Mart
    Mart
    It's a 5 on 10.25" pcd.
    I did some measurements and got the trig wrong and had an adaptor plate drilled at 10". WRONG. Had to have it redone at 10.25".
    5 on 5.5 is the standard early ford bolt pattern, sometimes called large ford bolt pattern.
    More modern fords are 5 on 4.5", sometimes referred to as small ford bolt pattern.
    Limey know-it-all.
  4. Roothawg
    Roothawg
    Holy Frijoles...I had no idea. I guess that idea is out. I was gonna try and find a set of 36 wheels for my 36 of all things. Don't think I wanna run mechanical brakes.
  5. NealinCA
    NealinCA
    [ QUOTE ]
    [/ QUOTE ]
    For the front, you can put the 36-39 drums on 39-48 hydraulic brakes, and the rear you can either do the same or use adapter plates to run a later rearend. The circle track guys sell the adapters.
    The neat wheel is the 39 3/4 ton wheel. It is 16x5 and is not scalloped. 50Fraud has a set on his 36 3W.
    Neal
  6. Roothawg
    Roothawg
    Well, I am prolly gonna run disc on the frt that is why I doubt I can run em. I like the look but don't know if sacrificing the stooping power is worth it.... [​IMG]
  7. Disc brakes and wide 5's are very common on stock cars. Should be no problem coming up with what you need used and cheap.
  8. Roothawg
    Roothawg
    When you guys are saying stock cars are you talking about vintage stock cars or what? I didn't realize there were so many of these wheels available.
  9. NealinCA
    NealinCA
    Here is some info on adapter plates from a question Eyeball asked. They still use them.
    And there are some pics and discussion of the wheels on 50fraud's 36 here.
    Hope that helps.
    Neal
