model b engine score THE HARD WAY
Discussion in 'The Hokey Ass Message Board' started by Sawracer, Jan 13, 2007.
  1. Sawracer
    Sawracer
    from socal
    Thanks to my friend Norm I scored a model b engine for my model A. Amazingly it was still in it's original home nestled in between the hard working framerails of this 32. Yes it had a cherry grill on it. There was no way to get a cherry picker to the truck. The good news was there was enough old rigging and "car guy safe" 1/2" line on the owner's property to get it up and out stone henge style. This was taking "old school" to new heights or should I say new lows?
    I haven't a clue what a model b engine weighs with the flywheel but it's safe to say (now) that the pathetic old tree branch over the engine is good for more than twice that! Once removed with the help of a fire wrench, chisel, and the usual suspects we had to drag it through at least 50 feet of soft sand to the waiting bed of my loyal elcamino, only to leak a gallon of 60's crude in it. Why did I ***ume it wouldn't have any oil in it? It actually snowed the morning of the pull too. All in all it was a great car guy day and the pull only took a couple hours. Now, when are we going back for those bones? Oh yeah that's chopped50ford in the funny hat.[​IMG][​IMG][​IMG]
  2. Job Well Done Goes To Show You How Far A Hotroderwill Go For The Love Of There Hotrod Tell Me Ive Always Used Sbc In My Rods One Flathead What Are The B S And Parts Going For Are They Hard To Get Tim
  3. Sawracer
    Sawracer
    from socal
    They aren't hard to get at all, The A motors range from free to maybe a thou for a used stock rebuild. The B motors are a little pricier due to a little more reliability engineered in. Like anything else you can spend as much as you want, mild to wild. I have owned fast cars and they were fun, a banger will never be quick in the modern sense of the word but they are fun in a different way. I got the complete B and an extra block and crank for $600, that would be considered a good deal if they aren't cracked to hell. But even some cracks aren't the end of the world in the case of an ovh valve conversion or a sleeve repair.
  4. The37Kid
    The37Kid
    Nice score, Great story! Have you s****ed the crud off the area above the side timing gear cover to see if you got a Diamond block? I'm betting you do.:D
  5. Sawracer
    Sawracer
    from socal
    No, do I look for a diamond shape embossed I presume?
  6. Sawracer
    Sawracer
    from socal
    Check out this ****py old tank the guy was using for a portable air tank, I mean what is that from WWII? LOL. What a redneck! wink.[​IMG]
  7. The37Kid
    The37Kid
    I think the Diamond came cast and stamped, can't remember for sure. it will be right were the X is on this block, Fords way of telling you there is a "C" crank in it.
  8. Sawracer
    Sawracer
    from socal
    I'll run back out in the cold and have a look see! Thanks.
  9. Sawracer
    Sawracer
    from socal
    just a number stamp, I do have at least one c crank. I gott yank the pan on the truck engine. Too cold for now.
  10. Sawracer
    Sawracer
    from socal
    Brent from ten un c- there is the radiator.
  11. Montechris
    Montechris
    Next time you do that, its easyer to unbolt the motor and lift the car up.
  12. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    that was one great time. It was almost effortless w/ the pulley system we rigged up.
    The cool thing is, of all the pieces we torched off (nuts, bolts and screws); we didnt damage any original parts/or sheetmetal in the process.
  13. CoalTownKid
    CoalTownKid
    good job guys,....!!
  14. scootersnpie
    scootersnpie
    Actually the "Diamond" cast into the block is an indication that the block was manufactured for industrial purposes or after production year 1934. Nice find and well worth the work. I went to the trouble of shipping NOS "B" Blocks back to the USA in the 70's in oil drums while overseas.....should have held onto more than I did!
  15. Sawracer
    Sawracer
    from socal
    That B is still in my elco sans oil slick as I pressure washed it. I hit True Value this morning to get some hardware to hang it in a stand. The pressure washer illuminated a myriad of fractures in the C head I planned to recondition and peddle. Bummer. It will now become an integral part of my pressure testing equipment for bangers. Those go for around 150 so even steven I guess. I 'm gonna go hang it in the stand, pull the pan and see what's hot and what's not.
  16. Sawracer
    Sawracer
    from socal
    NOT a counterbalanced crank. That's hot rodding.:rolleyes:
  17. jonski und29
    jonski und29
    Ha ha! Ive done before with a pontiac motor on a 32 frame. It works really well
  18. titus
    titus
    the guy must have put the 33/4 cab on the 32 ch***is?
    jeff
  19. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    cab is expected to go up for sale. Its solid except the roof. It has small "feet" prints on it. Still looking for doors.
  20. dirt
    dirt
    hey norm is that from the guy that we got the paint cans from? he had a cool place.
