mag wheels on a 54 chevy
Discussion in 'The Hokey Ass Message Board' started by cretin, Jan 15, 2007.
  1. cretin
    cretin
    anyone got pics of mag wheels on a 54 chevy 2 door? trying to decide if i want to put mags on it or keep the steel rims.
  2. chevrolee
    chevrolee
    Hello
    Unless you have changed the front end,stay with the steelies, I had mags on my 54/210/2dr, you have trouble keeping the lugs tight for one thing and it will steer alittle harder. I brokehalf dozen studs off/ the wheels were not unilugs. I went back to steelies and everything is kool again
    Chevrolee
  3. zman
    zman
    from Garner, NC
    Hunhhh? Did you have the proper lugs? Were they a different size than stock? Sounds like the wheels weren't to blame....
  4. chevrolee
    chevrolee
    I stsrted with 14"s on the front and 15" on the back, you know "big and little" then I went to 15"0n the front because of the steering. But the wheels were chev bolt pattern and the lugs were the right ons according to the tire center guys, but now I'm running the same size tires on steelies rims and all's well
  5. Your post is so ignorant and ill informed that I don't know what to say? Obviously, you need some more wrench time. Zman was nice, I just call you a dumb***.
  6. ray
    ray
    from colorado
    but but but the tire center guys said...
    :D
  7. 53burb
    53burb
    Go with this setup. Makes mags look like **** in my books. KNUX!
  8. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    steel wheels!
    unless yer after a street rod look?or stuck in the 70's
  9. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Depends on the rest of the car's look. Hot small block and a four speed? Torq Thrusts. Six with split exhaust and lowering blocks? Steel wheels and full covers.
