Brake light problem
Discussion in 'The Hokey Ass Message Board' started by 48bill, Jan 17, 2007.
  1. 48bill
    48bill
    In my 48 F-1 pick up I have a weird situation with the brake lites.
    I have a Centech wiring harness kit installed and have had no problems for 30,000 miles until this week. The directional switch is an aftermarket "Signal-Stat" unit.
    The 1157 bulbs are both good and the bright light element works with the right and left directionals and the hazard flashers. The problem is that the left (driver's side) brake light doesn't lite when the pedal is depressed. The brake light switch is a mechanical one from Wire Works.
    Any ideas as to why I have no left side brake light?
    Thanks for your help.
    Bill
  2. If the right side brake light works fine when you push the brake pedal, then there's probably nothing wrong with the brake pedal switch. It sounds like maybe a bad switch contact in the turn signal switch.
  3. rusty1
    rusty1
    ...ditto what Rustybolts said, I had a similar problem, turned out to be a bad contact in turn signal switch.
  4. Enginetuner
    Enginetuner
    Check your grounds
  5. Paul2748
    Paul2748
    Check the wire from the column to make sure it didn't come loose at the union.
  6. jackandeuces
    jackandeuces
    Check the ground,causes many funny problems
  7. rodknocker
    rodknocker
    check the socket,&make sure you have continuity all the way through
