What Year is This CHEVY?
Discussion in 'The Hokey Ass Message Board' started by Relay, Jan 18, 2007.
  1. Relay
    Relay
    so far i've found out the cab is 41-46 and the frame is 36-40?
    is there a way i can figure out the exact year?
    i already tried the VIN decode off stovebolt.com... didn't work it said it was a 1950... any others that you might know about?
  2. LUCIFR
    LUCIFR
    from Seattle
  3. tommy
    tommy
    Well if you are asking about the frame with the fenders and headlights on it...I'd say 28-29ish
  4. Royalshifter
    Royalshifter
    Moderator
  5. scottybaccus
    scottybaccus
    That is a 38 to 42 cab. look at my photo album for 360* views of mine. If there are X shaped beads rolled in the firewall, it will be a 40 to 42. The 42 model cab was used up to 46 due to WWII.
    That frame is much earlier. Tommy is in the ball park.
  6. rusty1
    rusty1
    39 Chevs had a flat dash, 40 and up had a curved dash from top to bottom...
  7. scottybaccus
    scottybaccus
  8. Relay
    Relay
    The Firewall has the "Xs" stamped into it so that means its a 41 and newer cab.
    the dash is rounded with a square gauge cluster.
  9. Relay
    Relay
    after checking that web site... the truck is probably 42-46 the right outside door lock is below the handle.
  10. LUCIFR
    LUCIFR
    from Seattle
    yeah I noticed that after my prior comment that side shot of the fire wall is sort of funky how it v's also it seems that your missing raingutters?? unless its just the pic/my eyes
  11. LUCIFR
    LUCIFR
    from Seattle
    the frame looks to be late 20's poss 28.. cool headlights though
  12. Relay
    Relay
    additional pics...
    LUCIFR what did you mean by the firewall V's?
  13. 29bowtie
    29bowtie
    The cab is 42-46,the ch***is is 1929,28 didn't have 6cyl although frame would be the same.
  14. Relay
    Relay
    are you positive? bc i'm not... the motor and mounts didnt look like there was any fabrication or custom install of a six it looked factory.
    also i measured the frame end to end it was 150.5 inches and axle to axle 105.5 inches if that helps.
  15. youngrodder1929
    youngrodder1929
    the frame is a 29 car frame truck frame was just flat defetly 29 cuz it was the first year of the stovebolt 6
  16. LUCIFR
    LUCIFR
    from Seattle
    Relay this cab is no older than 39 I belive it did not come on that frame I have a 38 and it has lines up and down the fire wall and a less of a v on the side were the hood mounts it is some were between 39-41 you might be able to find out for sure on the stovebolt page or try the filling station website they deal with all old chevs all day &night they have suttle differences between 1/2t and 3/4 sizes too!!
  17. Ornery37
    Ornery37
    from Texas
    36,37,and 38 if I am not mistaken (do not know if 38 did a 1/2 year) have smooth fire wall and one solid flat windshield
    the pic is of my 37
  18. Relay
    Relay
    acording to stovebolt.com and other sites the cab is definitly a 42-46
  19. LUCIFR
    LUCIFR
    from Seattle
    where's squirrel when you need him
  20. swade41
    swade41
    from Buffalo,NY
    There is also a difference in the fuel neck between a 42 and a 46. The 42 should be leather and in 46 it will be rubber. Another good way to narrow it down would be to remove your headliner braces and see if the back side is olive drab or not. The olive drab still could have been used on a 46 though as a left over.
  21. Relay
    Relay
    in 41 the right door lock was in the handle, in 42 the moved it down below the handle
  22. 29bowtie
    29bowtie
    I'm positive,they developed the frame for the new stovebolt six,which was to be introduced in 28,but was delayed till 29.the headlights & bar also confirm 29.I compared your measurements to my stock frame,they're the same.Good referance book for these early Chevys,A Pictorial History of Chevrolet 1929-1939 by John D.Robertson,he worked for GM Media Archives.I still have my original six too.The frame didn't change till 33 when wheelbase became 110"
  23. Relay
    Relay
    Great thanks for the info and refrences!
