I've been told I have bad gas ?
Discussion in 'The Hokey Ass Message Board' started by Big Dad, Jan 20, 2007.
  1. Big Dad
    Big Dad
    I have a hot rod truck that does not get driven as often as I'd like
    but, sometimes it goes a month till I start it up again
    It seems to lose PRIME ..ok up to like 3 weeks, but 4th week
    will not start ..
    Is anyone else expericance this ..guy that I know says
    the fuel gets bad and does not have enough left in it
    to fire truck
    Should I call bs on this or ?
  2. rusty1
    rusty1
    ...several of my friends and myself have experienced the same thing,...they say the gas evaporates out of the carb as it sits unused. What I've been doing is to just dump a trickle of gas into the carb and it usually fires rite off . It smoothes rite out after the float bowl gets full. Try this, see if it works for you.
    ...a friend says if you put a small amount of gas in a contaner with no lid, it will be gone (evaporated) in a couple days; don't know if that's normal or not.
  3. Big Dad
    Big Dad
    well, maybe he is right ..guess fuel is so poor this day and age
    it has shelf life
    I try to remember to fire it every so often
    but when its cold..don't want to gas myself out
    in garage
  4. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    B.S.-I've gone a lot longer than that between startups and I just have one word for you: 'ether' (starting fluid)
  5. Casey
    Casey
    It`s probley just bad mexican food ! yuk yuk yuk ? with a electric pump I let mine run till I here it stop , give the gas pedal two pump`s and it start`s right up . after 6 month`s or more after it`s been apart for awille ? I have only had bad gas once and that was from that pancho`s all you can eat buffet / I mean after I let one sit for 3 years ! I don`t think you have bad gas ? but Im staying up wind !
  6. 4tford
    4tford
    I had it happen on my last car it seemed every time I let it sit for a few weeks it would have to crank a long time to get fuel to the carb. My current car has a electric pump and does not have this problem. Both carbs were and are eldebrock 4 barrels. I think the gas evaporates after a few weeks out of the carb.
  7. OldSchoolObee
    OldSchoolObee
  8. Eagletucky
    Eagletucky
    does it burn when you fart?
  9. HEATHEN
    HEATHEN
    from SIDNEY, NY
    It wouldn't happen to have a quadrajet on it, would it? They're famous for the well plugs in the bottom of the main body leaking, and if you run the vehicle regularly, you'd never notice it. When my '68 LeMans sits for an extended period, the gas leaks out and I either have to give it a shot, or crank the hell out of it until the bowl fills back up.
  10. Big Dad
    Big Dad
    Eldelbrock performer carb
    Carter mechanical pump
    I need a cute 20 something leggy blonde (female)
    to hang around, start my cars, run errands
    So, if you know anyone .. have them send resume'
  11. rixrex
    rixrex
    the un-leaded gas we have now can go bad in 2 to 3 months..I put a little of that Sta-Bil product in my tanks, it helps....
  12. JohnnyP.
    JohnnyP.
    had this happen with california gas. it seems like we have more "****" in our gas for polution. when i bought my oldsmobile if ft collins, CO all it needed was a little ether and a new battery, ran like a champ after sitting for a couple yrs. when i got in ca and it sat for 2 months it had the hardest time starting, change the gas, fierd right up. so i think they are changing **** on us.
  13. 47 Tudor Guy
    47 Tudor Guy
    I have a 75 Dodge truck that does the same thing. After sitting for a few days it won't start until the carb get a fresh dose. If I run it everyday it is not a problem. I think my trouble a combo of the carb losing fuel and also with the fuel pump leaking back slightly and not holding fuel between pump and carb. I rebuilt the carb, and replaced the pump, but it still does it. I just live with it cuz I hardly ever drive it.
  14. Toystoretom
    Toystoretom
    My 55 Buick and 66 Caddy both do this... they both have Eldelbrock's, which doesn't really matter... If you shut the car off hot the big old cast iron engines will help some of that fuel evaporate and the foat bowl goes dry. I usually have to crank it for 30 seconds or so to fill the float bowl back up it the car sits for a long time...
  15. Big Dad
    Big Dad
    Has a aluminum intake
    I never keep cranking but, I do not think it will go without
    dumping fuel down its throat
    It is just a PITA
  16. Sticher1
    Sticher1
    from Ct
    Hey People the GAS that they now give us they say has a shelf life of about 30 days then starts to go south... Sta Bil works but have heard too much and it starts to gel not realy sure about the latter
  17. rodknocker
    rodknocker
    is it possible you have the wrong size carb for the motor? too much or too little?
  18. Big Dad
    Big Dad
    Should be dead on .. 440 with a 750 eddie spaggatti
    runs fine, starts up fine if you crank every 20 -25 days
    go 30-32 days .. nope
    The ****ty gas idea seems logical
  19. 51 MERC-CT
    51 MERC-CT
