I started Tatooing my Hot Rod
Discussion in 'The Hokey Ass Message Board' started by ratman, Jan 27, 2007.
  1. ratman
    ratman
    Well not really but we have started to emboss all of the new panels I've made.
    So far we have done the floor, trans tunnel and firewall.
    Hood and doors along with pickup bed will be embossed next.
    Flames flames flames apart from the vampire skulls in the floor
    yes I know skulls but so what I like em
  2. T Hudson
    T Hudson
    Damn, thats HOT!:D
  3. How the hell are you doin that? Lets see some tech on that...Those flames are perfect! :cool:
  4. xderelict
    xderelict
    cool but if your going to tattoo your car do it with two ts
  5. attitudor
    attitudor
    from Finland
    Bead roller or press?
  6. looks trick...how about some text and pix on how you are doing it
  7. Brandy
    Brandy
    from Texas
    Wow! Look it's the ****ing SPELL CHECK POLICE.
    More involved with the guy's SPELLING TECHNIQUE then his ability as a CRAFTSMAN.
    Way to go OFFICER SPELLMAN, I almost didn't recognize you without your DICTIONARY and RED CORRECTION PEN.:rolleyes:
  8. langy
    langy
    Very cool.
    Steve.
  9. noboD
    noboD
    I like the satin backround polished highlight effect. Are you going to paint it that way? Maybe flat and shiney?
  10. Spade
    Spade
    from Texas
    very cool man!
  11. ratman
    ratman
    The embossing is done with a bead roller. The secret is that the bead roller is hydraulic and there is a foot control that alters the speed from 0 upwards.
    This means one guy can steer the panel and control the speed resulting in a better flow.
    We will post a tech I just need to get pics done of us on the machine
  12. Ratstu
    Ratstu
    The work looks great & I dig the grille!
  13. ratman
    ratman
    The panels that have satin / buffed have had the embossed areas buffed up with a 3M conditioning disc. I waas just goofing around to see what it would look like.
    I am considering satin paint and then buffing again as this really makes the embossing stand out, but at the moment I am thinking of 1200 wet sand all over then buff the embossing and then apply Nyalic which is a clear dam near bulletproof coating.
  14. TT66'
    TT66'
    Man that rocks!:cool: I've gotta get one of those bead rollers.
  15. Merge
    Merge
    Do you have a pic of that stack setup on top of the carb? Looks unique.
  16. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    It's lookin' real good ... I really love the red artillery wheels with the whitewalls. Real sharp. :D
  17. ratman
    ratman
    I cant afford triple carbs so I decided to make the down tube set.
    The base is made from stainless steel tube with a domed end welded on, then I split the tube in half length ways.
    The risers are made out of stainless steel polished hand rail tube.
    The hood of the car will be just above the bottom of the base tube so it will look a lot different when the hood is fitted.
    Its pretty basic but thats the theme I have gone along with on this project.
  18. noboD
    noboD
    Bead roller?? So you drew the flames on and steered around the shape with a bead roller? Now I'm doubley impressed. I thought you made a pattern and hammerformed the flames. I like it.
  19. Man, it's good to see Brandy hasn't lost her charm! :D
    By the way Ratman, Nice work on the flames.
  20. xderelict
    xderelict
    Thanks for setting me straight Randy.;)
  21. Wild_47
    Wild_47
    Flames look awesome. Wish i had the patience for something like that :)
  22. Squablow
    Squablow
    He is spelling it with two t's. Tattoo has three t's in it.
    I win!
  23. tattooedup37
    tattooedup37
    hahahahahahahahahaha
  24. ratman
    ratman
    My mate draws the flames on by hand and does them with one p*** perfect everytime. I cheat on some of them though. The skull was a picture I found on the net so I printed it off and traced it onto the panel with carbon paper.
    Then hit it the bead roller and bingo
  25. Big Tony
    Big Tony
    Damn thats kewl
  26. Svenny
    Svenny
    Hmmm........that should be one c, two o's, and no kew...... :rolleyes: :D
    I'm not the spelling police, I'm just a deputy....
  27.
  28. JPMACHADO
    JPMACHADO
    from Not Listed
    Thank you for not building the same car 90% of everyone else is. It's very different and unique. I like it a lot.
  29. Brandy
    Brandy
    from Texas
    What? I'm the sweetest girl I know.:D
    I'm HIGHLY impressed that work came from a bead roller. I was thinking "ohhh hand pressed thru".
